[WTB] Clutch cable for F400 GT | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Andrew-400i, Sep 24, 2007.
  1. Andrew-400i
    Andrew-400i Karting
    Sep 22, 2007
    186
    Andrew
    Hello Everyone.
    I have posted this in the Australian forum aswell. My hope is that someone in the 365/400/412 'community' with the parts will see this message.
    I am after a Clutch Cable for a 1980 Ferrari 400 GT. I took it out for a drive this morning, and It stretches so quickly, and I have virtually no clutch pedal after a 20klm drive. If anyone has one (or two) of these, and would like to offload them, or know where I can find such parts in Australia, I would appreciate it if you could let me know.
    Thanks, Andrew :)
    dedo tanzi likes this.
  2. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,163
    MA
    Are you saying that the car drives normally after sitting for a while but that the clutch starts slipping after 20km or so on the road? If so, that sounds to me more like your clutch might need replacement as it starts to slip after it heats up with driving. I've never heard of a clutch cable that "stretches" and then shrinks back.
  3. Andrew-400i
    Andrew-400i Karting
    Sep 22, 2007
    186
    Andrew
    It just gets progressively worse. It has had a new clutch put in it in the last 3000mi, so I highly doubt there is a problem with it there. I think I have found someone with a new clutch cable, so I will see how it goes. I'll keep you updated.
    Andrew
  4. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    Part number 110020.
    Eurospares = 65.5 pounds
    McCann = $125 dollars
  5. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    ....but I doubt that the cable is the source of your trouble.
  6. Ashman
    Sep 5, 2002
    33,163
    MA
    In that case I would check the adjustment to make sure that is set up correctly.
    Good luck
  7. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    this would not be first bad clutch. i have to redo a clutch job at least once a month at my shop
  8. dedo tanzi
    dedo tanzi Karting
    Dec 16, 2013
    52
    Lugano - SUISSE
    DEDO - Alfredo
    Cari colleghi !
    Provo a scrivere nella mia lingua madre, spero che GOOGLE vi possa davvero aiutare !
    Dopo aver cambiato frizione, disco e spingidisco, ho sostituito anche il cavo della frizione !
    Il mio abituale fornitore - inglese - mi ha fatto avere un nuovo cavo, ma si allungava ancora di piu' di quello vecchio!!! :(:(:(
    Dopo averlo sotituito nuovamente con un altro, sempre arrivato dall'Inghilterra....idem...la stessa storia !
    Poi ho fatto rifare il cavo da una officina specializzata, ( errare e' umano, ma perseverare e' diabolico !!!! :pazzo::pazzo::pazzo:... ) mi hanno confermato che il cavetto in acciaio non era assolutamente adeguato...per una 400 GT !
    Rifatto, montato per la terza volta...PERFETTO !!!
