Would a 308 window motor work in a400 ? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Part Time, Feb 5, 2019.
  1. Part Time
    Part Time Formula Junior
    500
    Port St. Lucie, Fl
    Gary Shore
    Just in case anyone ever wondered……would a window motor from a 308 fit a 400 ?
    Almost, with a little work, however, I was able to repair my original motor, so now I do have 2 working window motors for a 308 series car, if anyone out there needs one.
    308 motor on the right, with the thermal switch inside the red box. Mounting stud center to center is the same, would need some nut/washer stacking to get the correct depth of drive shaft into the gear sleeve. Or, you could just cut off the extra length of shaft and recut the flat, but it could work.
    Gary
    willrace and wrxmike like this.
  2. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,207
    Gold Coast, Aust.
    Patrick
    I'm predicting problems
