Working 'Model' Ferrari Engines | FerrariChat
Discussion in 'Mondial' started by Bell Bloke, Sep 24, 2015.
  1. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Em and I are such sad petrolheads that tonight we've been looking at all kinds of engines running on Youtube, from trains to aeroplanes even ships!.......anyway we stumbled across this....
    https://www.youtube.com/watch?v=uzPvPowrm6M
  2. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    It's a work of art! Can you image the skills necessary to build that?
    Anyway - since you started this thread, I'll offer up this contribution. It's on the other end of the size scale. Very cool engine:
    https://www.youtube.com/watch?v=iw72YcUOCR0
    Sid
  3. Indyjones
    Indyjones Karting
    Jan 28, 2009
    219
    Pacific NW
    Nice! Imagine putting that into a kid's Testarossa ride-on toy car :)
  4. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    Both very cool, how often do you have to change the timing belts?
  5. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Nifty little v12 :D I only have a 1 cylinder F40 :) so.. now who will start the body work?
  6. Bell Bloke
    Dec 6, 2012
    1,839
  7. Bell Bloke
    Dec 6, 2012
    1,839
  8. Bell Bloke
    Dec 6, 2012
    1,839
  9. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    sitting for 30 years?
    The gasoline/petrol is probably like varnish.
    I would change the engine oil first before attempting the turn the engine.
  10. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    "All we did was check fuel and pressure".
    If I had a valuable engine, that had been sitting for 30 years, I would have:
    1. Changed all fluids
    2. Borescoped cylinders
    3. Replaced all fuel lines.
    4. Replaced spark plugs
    5. Replaced ignition leads
    Of course, these guys may have done all this. In fact, since they seem to be a Porsche shop, I'd guess they did.
    Other things I'd do:
    6. Hooked up external fuel and oil pressure gauges, external temp gauge, so that I could monitor everything without having to duck into the cockpit.
    7. Had a fan blowing fresh/cold air into the engine fan
    8. Hooked up ducting so that exhaust would flow outside the shop.
    Finally, I probably wouldn't have a bunch of guys leaning over the engine during fire-up.
    Sid
  11. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    There are some people that have truly awesome talent.
    This guy should open shop, producing unobtanium parts for rare cars.
    Sid
  12. Bell Bloke
    Dec 6, 2012
    1,839
    Well all of the above Sid, Jonathan but I know what I'd do at the very least after doing all the fluids (except water) is:
    1. pull the plugs
    2.spray in penetrating fluid into all the bores, leave for a couple of days
    3.turn engine over by hand checking rings are not frozen in.
    4.turn engine over on the starter without plugs clearing the bores of penetrating fluid and until oil pressure is registering.
    5.replace the plugs and only then go for an engine start.
    Oh just played this to Emily, she nearly had an orgasm and she's not even into Porsches.
    She said and I quote: 'Oh my god that's a sound that could chew your ..... off!'
    Think she's a petrol head.....
    https://www.youtube.com/watch?v=FkP5Svl16Qg
  13. Nathan76
    Nathan76 Formula Junior
    Jun 20, 2013
    344
    Leicestershire, UK
    Wrong answers above
    What it needed was a stack of 'start yer bastard' squirted directly into the carbs to get it turning over.
    Once this is achieved tap the carbs with a 13mm spanner to adjust.
    No further action required.
  14. TheMac
    TheMac Formula Junior
    Sep 5, 2009
    452
    Alberta
    Jon Mac
    I remember going to Monterey one year once about 20 years ago or so, and a guy had built a working model engine of a 512BB, a bit smaller than the one in the video Bell uploaded. Everything was there, and everything was miniaturized, except the starter. He said he couldn't make a real starter motor that small, so he started it with a drill, I think. But it was brilliant, quite something to see in person.
