Woe is me... | FerrariChat
Woe is me...
Discussion in 'Mondial' started by paulchua, Oct 10, 2016.
  1. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    :( doing some spirited driving up on skyline, before I could break the black terror (with white stripe) darted across the road... too late.....
    The smell was so bad that I thought I would throw up on my way home..
    Any advise my friends to get that smell out? I'm afraid to use the hydrogen peroxide, baking soda thing since I don't know if that will hurt the paint.
    Thanks in advance.
  2. BOKelley
    BOKelley Formula 3
    2,071
    Au'n Colorado
    Brock
    Well that stinks!!
    For pets, a combination of peroxide and baking soda does the trick....I am assuming that the belly pan took a direct hit? Probably not much down there to worry about in terms of peroxide, which you would dilute regardless. I am sure a quick Google search would yield a recipe that you could spray on...
    Brock
  3. NYC Fred
    NYC Fred F1 Veteran
    9,713
    Fort Lauderdale, FL
    Fred C
    Thought tomato juice was the go-to for this?
    Works on dogs...rinse after, prob acidic.
  4. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    Be careful if there are any remains of the critter. They do carry rabies.
    As for the smell, I don't think anything works. Other than time.
    Although, if you removed your cats, perhaps the smell of unburned gas would overwhelm the other odor?
    Sid
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Thanks All!!!
    So it hit the front left tire, driver passenger trim, and under tray, part of the problem is that I don't have a lift, I was able to 'clean' it best I could, but there are some parts I can't really check. I talked to a professional detailer, unfortunately he said in the end only time fully removes the smell - he said about 1 - 2 months.
    ugh...
    again, thank you for all the replies.
  6. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I seem to recall that Pepé Le Pew was actually Italian. ;)
  7. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    hahaha
  8. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Time and breathing. Lots of driving to let the garage air out.
  9. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    This happen to my dog once, it was late night and I let them out - they chased the critter and then shabbam - full blast.
    That was rough - had to do the whole bath - even then it took 1 month (at least) for the smell to fully dissipate.
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Thanks Sid - didn't think about the rabies thing...good call. I just this old broom and tried to power wash as best I could.
    But if I do a 'detail' i will wear gloves.
    Cheers
  11. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I had a dog get it as well once. Tried all the remedies with the same results. 😕
  12. BOKelley
    BOKelley Formula 3
    2,071
    Au'n Colorado
    Brock
    tomato juice is useless...the peroxide/baking soda combo works very well. I know this from experience with both!!
    How do you remove skunk odor from your dog?
    Wash immediately with the following mixture:
    1/4 cup baking soda
    2 teaspoons of a dish washing liquid
    1 quart hydrogen peroxide
    Use a hose to get your pet wet, then begin to shampoo the hair of your dog thoroughly. The mixture will fizzle when the baking soda and peroxide are mixed. Avoid getting any of this mixture in your dog's eyes or on its nose.
    References:
    dogs.about.com/od/caringfordogsandpuppies/ht/deskunking.h…
    The key for dogs is "To wash immediately"....otherwise the oils soak into their hair and lingers for quite some time.
  13. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    I did that mixture on the dogs, and it definitely took most of the smell out. I still had that lingering smell for a month though.
    hahaha
    I hope all of you never suffer the black white striped terror!!!
    Be well all.
  14. blownfuse
    blownfuse Karting
    Jul 16, 2012
    104
    Campbell, California
    There's your problem.
  15. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    #15 paulchua, Oct 11, 2016
    Yeah, I've seen all sort of animals up there...although the scariest thing was when a buck jumped in front of a 430 I was behind - this was up in North bay - we both swerve last minute - that was a heart attack moment for sure. When you drive in rural back roads, you have to always on guard for wild animals. (and other dangers of course)
  16. srephwed
    srephwed F1 Veteran
    6,471
    street,md
    fred brown
    Ammonia smells bad but better than Pepe. Go to the dollar tree where everything is a dollar. Couple bucks later you can remove the clothes pin from your nose.
  17. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    Paul, it's an oil so the baking soda trick should work. Probably just the lower panels right? Baking soda is gritty so you might need to polish it a bit if it causes micro scratches in the paint. I'd imagine the grill is more resilient. My 2c. Good luck!
  18. TGIF
    TGIF Karting
    Mar 7, 2016
    86
    Milpitas, CA
    Paully
    Paul, have you ever been or know of "Pit Row" down in Santa Clara? You can rent lifts by the hour and comes with tons of tools and others that can be browed in shop. Check it out if needed for a lift (call ahead if the smell is still pretty bad).
  19. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Pepe Le Pew was French ha ha ;-)
  20. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    #20 sidtx, Oct 12, 2016
    Only us old timers have any clue as to who/what "Pepe Le Pew" is!!!!
    I asked my kids (28 and 23) and they had no clue.
    Somehow, I feel that we our loosing a bit of our culture. Or maybe I'm just becoming an old fart.
    Sid
  21. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    haha - agreed
  22. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    I've read and heard that place and hearing nothing but great things!
    Thankfully the smell seems to be dissipating quite well. I figure I'll just wait it out, thank goodness I have a convertible!
    haha
    Thanks all for your tips and advice - it is appreciated!
