360 - Window does not open | FerrariChat
360 Window does not open
Discussion in '360/430' started by Vegas CS, Feb 18, 2020.
  1. Vegas CS
    Vegas CS Formula 3
    1,176
    Vegas
    James
    #1 Vegas CS, Feb 18, 2020
    Hey all,
    BLUF.....I did a Google search/Fchat search and tried a couple things brought up by the results to no avail.
    I recently picked up another CS and have a question. The drivers side door window will not open that 1/4" when pulling the inside door lever. I immediately thought it was the microswitch and I changed it out with a new part with no change to the issue. I disconnected the battery for 30 mins and did a window relearn with no success. I'm hoping it's not the green box in the left side of the drivers side footwell as it's almost $1k.
    Additionally, the window does do the small drop when opening from the outside.
    Any thoughts?
    tia,
    Jim
  2. mello
    mello F1 Veteran
    5,482
    CA Bay Area
    Steve
  3. 24000rpm
    24000rpm F1 Rookie
    there are 3 microswitches. which one you replaced
    its either
    1. the microswitch is bad
    2. the microswitch's position need to be adjusted
    3. like the previous gentleman mello pointed out, the hinge harness area
  4. Vegas CS
    Vegas CS Formula 3
    1,176
    Vegas
    James
    Thank you for the replies!
    I replaced the micro switch that is inside the interior door panel. When you pull on the lever inside it makes the “click”. I checked the lever is in contact correctly, no corrosion observed in the door jam connector.
  5. Vegas CS
    Vegas CS Formula 3
    1,176
    Vegas
    James
    Additionally, the window does go down that little bit when the door is opened from the inside. Again, operates normally from the outside.
  6. 24000rpm
    24000rpm F1 Rookie
    If the pre-drop you have from outer door handle is 1 inch , the pre-drop is 1/2 inch from inside?
    if it is like what I described , it maybe something mechanical, something is blocking the window somehow
