Why does a plane have to 'dump' fuel before landing? | FerrariChat
Discussion in 'Aviation Chat' started by 96redLT4, Jan 17, 2020.
  1. 96redLT4
    96redLT4 Formula Junior
    Feb 20, 2009
    507
    California
    Jim
  2. ChadR
    ChadR Karting
    Jun 19, 2019
    249
    Central Florida
    Taj B
    They dump fuel for a softer, safer and easier landing. Less fuel = less mass, which means they can go slower with the flaps extended without stalling, and also slow down faster with less stress on the spoilers when touched down.
  3. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,190
    CA & DC
    Also less demand on the engines.
  4. 500drvr
    500drvr Formula Junior
    267
    So Cal
    #4 500drvr, Jan 17, 2020
    Structural damage... Most aircraft have a maximum fuel landing weight. Fuel dumping usually occurs when an aircraft must return shortly after take-off when its at its maximum fuel weight. The max fuel landing weight is unaffected by passenger and cargo weight.
    jcurry likes this.
  5. mikesufka
    mikesufka F1 Veteran
    6,621
    Crosslake, MN
    Mike Sufka
    Just curious how many gallons they'd dump ? 100 ? 1000 ? I have no idea. What's the cost / gal ?
    MDS
  6. 500drvr
    267
    So Cal
    #6 500drvr, Jan 17, 2020
    At 6.5 lbs per gallon, the dump amount could be thousands of gallons to get below the maximum fuel landing weight. Airlines negotiate long term contract prices for their fuel. I’ve heard as low as < $1.00/ gallon compared to retail of up to $7.00 /gallon.
    https://www.boeing.com/commercial/aeromagazine/articles/qtr_3_07/AERO_Q307_article3.pdf
  7. Jaguar36
    Jaguar36 Formula Junior
    Nov 8, 2010
    841
    Cherry Hill, NJ
    747-8's Max takeoff weight is 987,000 lbs. However its max landing weight is only 688,000 lbs. So they could theoretically have to dump close to 300,000lbs (46,000 gallons) of fuel. This would normally be done above 10,000ft, with exceptions of 7,000ft in the winter and 4,000ft in the summer, down to as low as 2,000ft in an emergency. At the normal altitude the fuel will all evaporate before it hits the ground under normal conditions.
    Overweight landings are allowed as well, however they may reduce the airframe life or require additional inspections.
  8. mikesufka
    6,621
    Crosslake, MN
    Mike Sufka
    That's incredible when you think about it
    MDS
  9. 96redLT4
    Feb 20, 2009
    507
    California
    Jim
    Interesting....thanks for the info!
  10. jcurry
    21,578
    In the past
    Jim
    I think it is just Max Landing Weight (MLW), and is irrespective of fuel, passengers, cargo.
  11. Nate2046
    Nate2046 Rookie
    Oct 15, 2006
    32
    Took off last year from Hong Kong in a 747-8 and couldn’t retract the landing gear. Had to dump almost 100,000kgs to get down to MLW. Kind of a strange feeling to open the valves and dump all that out into the atmosphere, but what’re you gonna do?
  12. BJK
    BJK F1 Rookie
    Jul 18, 2014
    4,792
    CT
    Also they are not supposed to dump fuel below 8,000? ft, so it evaporates before reaching the ground. They dumped at only 2,000 ft !!!
    Tower asked if they wanted to dump fuel, pilot said NO, then dumped anyways. I'm sure tower would given them different path/instructions.
    carguyjohn350 likes this.
  13. ChipG
    ChipG Formula 3
    May 26, 2011
    1,722
    Santa Monica, CA
    I thought I read the 777 was 186,000 lbs over max landing weight, jet fuel weighs 7lbs a gallon so about 26,000 gallons had to go.
  14. 500drvr
    267
    So Cal
    Depends on the aircraft. Some airplanes can have no passengers, be well below the maximum gross weight, and still have too much fuel to land without causing possible structural damage.
  15. 500drvr
    267
    So Cal
    That would be a violation of FAA rules which is being investigated now.
    BJK likes this.
  16. jcurry
    21,578
    In the past
    Jim
    I think that is what I said.
    You originally wrote "maximum fuel landing weight". I said it is actually "maximum landing weight". Amount of fuel has nothing to do with it other than that is the only thing that can be expelled to remove weight on commercial passenger aircraft. Military aircraft have same thing, i.e. maximum landing weight, but they can also off-load passengers, cargo, and ordinance to reduce weight in addition to fuel.
  17. ChipG
    ChipG Formula 3
    May 26, 2011
    1,722
    Santa Monica, CA
    It'll be interesting, I can't remember a case like this but last I checked when you declare an emergency you can do anything it takes to save your plane, crew and passengers.
    I read this morning a lawsuit was filed against Delta by the school victims and their parents.
  18. 500drvr
    267
    So Cal
    Nope. Maximum fuel in the wings can cause structural damage to the airframe on landing regardless if the plane is at gross or not.
  19. 500drvr
    267
    So Cal
    Nothing stopping a pilot from landing above maximum landing weight for reasons he believes are urgent. His call. An example would be a medical emergency where time matters. The aircraft would then be taken out of service, inspected and depending on what damage repaired. The inspection alone would be $$$.
    Axtellboy likes this.
  20. jcurry
    21,578
    In the past
    Jim
    Looking right now at a W&B manual for a B777.
    Under Certified Weight Limits the following are listed
    Maximum Taxi Weight (MTW)
    Maximum Takeoff Weight (MTOW)
    Maximum Landing Weight (MLW)
    Maximum Zero Fuel Weight (MZFW)
    Minimum Flight Weight (MFW)
    That is all.
    If you can find a reference to "maximum fuel landing weight" please provide a link.
    kylec likes this.
  21. 500drvr
    267
    So Cal
    I said “most” not all aircraft. Do you just like to argue or are you an expert?
  22. jcurry
    21,578
    In the past
    Jim
    yes;)
    Ferrari 308 GTB and Boomhauer like this.
  23. ChipG
    ChipG Formula 3
    May 26, 2011
    1,722
    Santa Monica, CA
    Yea, I get that, an overweight landing needs an inspection, most take 30 minutes but at 186,000 lbs over max landing weight, I'd think the gear would break if it wasn't an absolutely perfect 1 engine landing.
  24. jcurry
    21,578
    In the past
    Jim
    or the tail;)
    note: this was flight test and part of certification, and far exceeds what anyone here as likely experienced. That sink rate far exceeds what would be expected with a landing at excess weight.
    ChipG likes this.
  25. tazandjan
    38,085
    You do not want to land on a single engine at max landing weight unless you really have to.
    Boomhauer, killer58 and ChipG like this.
