360 - white Exhaust powder? | FerrariChat
360 white Exhaust powder?
Discussion in '360/430' started by 550nitis, Feb 15, 2020.
  1. 550nitis
    550nitis Formula Junior
    Feb 3, 2016
    717
    Houston
    Is this this dreaded white exhaust powder seeping through the weld that everyone talks about when your exhaust is on the way out?
  2. imahorse
    imahorse F1 Rookie
    2,778
    WI
    Dustin
    There is an insulation in the muffler that breaks down and leaks out. That is harmless. The failure point is the pre-cat in the exhaust manifold.
    Sent from my SM-N950U using Tapatalk
  3. Rifledriver
    34,119
    Austin TX
    The muffler is not sealed. It is 2 big cans designed to slide together and apart to allow for thermal expansion. When the insulation starts breaking down it gets pumped out like air from an accordian. Except for the mess it has no negative impact.
    If it is coming from the exhaust manifolds that is a different matter and requires different diagnosis.
    KC360 FL and E60 M5 like this.
  4. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,701
    Melbourne Florida
    KGC
    I've had the same situation for over 2 years now. Nothing to worry about. But it does kind of make the engine compartment look dull when everything gets "powder coated" ;)
  5. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,701
    Melbourne Florida
    KGC
    Just curious... how do the aftermarket exhaust offerings deal with the heat expansion? I've not looked hard at them but most seem to be completely sealed units (?)
  6. Zanny1
    Zanny1 Formula Junior
    991
    Arizona
    A;ways had the same thoughts.
    Still have original exhaust on my '99 and it sounds great. Know a few people that installed Tubi exhausts, which don't allow for thermal expansion.
    Wouldn't that lead to cracked exhaust manifolds?
  7. Rifledriver
    34,119
    Austin TX
    OE exhaust gets hotter because it is insulated to keep engine bay cool. Aftermarket exhausts radiate their heat into the engine bay.
    one4torque likes this.
  8. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    That raises the question of, how good can all that extra heat from an after market exhaust be for all the electronic components, wiring, etc. in the engine compartment?
  9. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    Two words: Challenge Grill.
    up4speed likes this.
  10. Rifledriver
    34,119
    Austin TX
    It helps but not enough. Even with stock exhaust Ferrari considered making Challenge grill standard configuration from the very beginning but it just didn't help that much. For air to go out, it needs to get in and there is no air inlet for that to happen. Not my opinion.....Ferrari's.
  11. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    #11 up4speed, Feb 19, 2020
    Out of memory, I thought that the 360's had air inlets on the rear of the rocker panel area to feed the engine bay, that typically exits through the vents on the side of the glass?
    Or do the vents "dead end" into the wheel well for the brakes? I don't remember, I haven't seen that part of a 360 in over 2 years.
  12. Rifledriver
    34,119
    Austin TX
    You know how small those are. At any speed we are allowed to drive the amount of air from those is tiny. Ferrari knew heat was a problem but aerodynamics is what drove the design and air flow through the engine bay causes drag.
  13. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    Interesting
  14. Rifledriver
    34,119
    Austin TX
    How can something the size of the Challenge grill be of benefit to air flow when you have the vents around the rear window plus the vents in the rear bumper only fed by 2 vents the size of my fist feeding them? At 150 MPH but at 60? Like I said, not my opinion.
  15. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    I'm not sure, I'm not an engineer. Maybe it creates a vacuum behind the car that essentially "Sucks" the air out? Who knows.
    Or maybe if the challenge grill is in place, and the car is moving, the side of the window vents become an intake to move the air out of the rear grill. Air can do funny things at speed, without a wind tunnel we can speculate all day. I guess we have to trust Ferrari to do wind tunnel testing for us and design the car properly. But we all know how that goes
