Wheel paint | FerrariChat
Wheel paint
Discussion in '206/246' started by omgjon, Oct 16, 2010.
  1. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    I know there have been many threads on this subject and Tom S. had posted a Ferrari bulletin on the process. Has anyone tried to to get a color match of this. It was from Glasurit line 54 which has been replaced. I've tried several places all coming to a dead end. This is something we all should know and some help would be appreciated. You guys are going to hate me. Ever since I got the 206 I now have a hangup on authenticity can you believe that! Anyways here is what Tom S. had posted.
    shaughnessy's Avatar
    shaughnessy shaughnessy is offline
    Formula 3
    Full Name: Thomas E Shaughnessy
    Smile The Official answer
    > Ferrari tech bulletin from 1971
    > Technical Information no. 182
    > Ref./Cromodora Magnesium Wheel Rims
    > When a respray of magnesium wheels is required, the products to be
    > used are the following:
    > - Acrylic metallized paint - gray 2427078
    > (smalto metallizzato acrilico grigio ghisa 2427078)
    > [ed: literal translation is metallic cast iron gray acrylic enamel]
    > which can be ordered directly to:
    > - ITALVAR - Via Privata Bolla, 27 - Milano (Italy)
    > The paint should be applied with viscosity 37" (Ford type viscosity
    > meter - orifice 3), and baked at 212°F (100°C) for 40 min. in the over
    > or under stoving lamps.
    Tom Shaughnessy
    San Clemente CA
  2. dm_n_stuff
    Jon,
    My guy here on the east coast did an excellent job of getting the color right on my Dino.
    Might want to contact him. Maybe ship him the wheels for painting.
    Mike at Delphias Collision in West Chester, PA. Don't recall the number.
    D
  3. Italian Lover
    Italian Lover Formula Junior
    Oct 26, 2006
    553
    Italian Lover
    Strange things do happen, Jon. I believe. w/ smiles Jimmy
  4. ajmarton
    ajmarton Formula Junior
    May 3, 2004
    305
    Los Angeles
    Jon,
    Talk to Gary Bobileff - tell him Andrew with the Fiat Dino referred you. His shop is amazing and he is a good source for information. Good luck! Andrew
    http://www.bobileff.com/
  5. dm_n_stuff
    Found it: 610-431-1660.
    Mike Franz, Delphias Collision.
    He's done probably 10-15 Dinos over the years and owns a very nice GTS.
    DM
  6. Sal Manzur
    Sal Manzur Formula Junior
    Sep 12, 2004
    282
    Upland Ca
    Salvador Manzur
    steve beckman in costa mesa ca 949-574-2557 he did the wheels for my dino.
    you usually see several 1950's ferraris undergoing frame off restoration.
    Tom S knows him well
  7. shaughnessy
    shaughnessy Formula 3
    Apr 1, 2004
    1,847
    Wolfeboro NH
    Guy we are not looking for painters
    BUT paint color and finish matchers
    Glassurit 54 line was replaced with 55 line
    need to compare differences, 55 line may also be discontinued
    Most painters are using a 2 stage Mercedes wheel paint color, with little to no pigment
    John's question is quite specific.
    Beckman and David Carte whould be asked what manufacturer, product and color code they are using.
    A semi gloss clear coat is highly recommended.
    Strip the wheels with a media, and prime accordingly zinc chromate works well
    Devil is in the detail and prep
  8. dm_n_stuff
    Tom,
    He can call any of the shops above and ask for that info, right???
    D
  9. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    Beckman gave the code he uses. I'll post it tonight.
  10. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    Here is what Beckman gave me.
    PPG global
    Ultra fine aluminum Toner
    #767. He wasn't sure of the# but with the rest of the info the paint supplier can look it up.
    This is a base coat with semi-gloss clear.
    I'm going to try 1 wheel next week and we'll see how it looks.
  11. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    #11 omgjon, Oct 23, 2010
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    How did it turn out?
    I bought a set of the Dino Cromodoras from Kurt, aka Turtle55, in Escondido and he had painted them very nicely. Very skilled car guy with several sets of dino wheels.
  13. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    I would suggest the PPG Global.
  14. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,066
    Seattle, WA
    Keith Mitchell Wintraub
    I bought new XWXs for the Dino and thought I would take this opportunity to strip, crack check and repaint my original magnesium wheels before I had the tires were mounted.
    I had a very knowledgeable shop order the paint based on the Ferrari Technical Bulletin information supplied in this thread.
    The paint arrived and after testing the paint on a strip of metal, the shop confirmed that the color does not come close to matching the Dino wheels on my car or two other Dinos in the shop. The color is clearly a darker gray than used on the Cromodoras.
    Perhaps Jon's PPG formulation is the way to go or just leave it to your local expert to find a close match but I just spent $400 invalidating the Ferrari bulletin paint code.
    FYI...Keith
  15. Maeter
    Maeter Karting
    Nov 13, 2001
    136
    This is interesting as I took my L-Series (and therefore magnesium) wheels to the UK best know wheel refurbisher (http://www.pristinealloywheels.co.uk/) and they could not strip them as it seems the current products being used are too strong for older Ferrari wheel in addition to having to remove the attached chrome bezel prior to stripping. I would love to learn how Keith's wheels will be processed.
    Pascal
  16. BigTex
    79,218
    Houston, Texas
    Bubba
    What code did you use?
    And it's possible the mixer %$^&ed it up, send it back and tell them to tint it....
  17. BigTex
    79,218
    Houston, Texas
    Bubba
    Stripping them is a hugely bad idea, IMO.
    Just sand them out and PAINT them, unless you see areas where the Factory coating has failed.
  18. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    the "new" paint color is different from the original color for the seventies. I have a set of new nos 15x9's that were kept in a house since new and the orignal paint is matt and poorly applied. The "restored" cars are trully over done compared to original spec.
  19. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,066
    Seattle, WA
    I'll ask the shop if I can post their process. They've done it for many of their customers with great results. Suffice to say, it's not just blast and squirt.
    Cheers,
    Keith
  20. BigTex
    79,218
    Houston, Texas
    Bubba
    Agreed, matt and 'casually" applied might be a better word, it has stuck on there over 30 yeras!
  21. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #21 synchro, Oct 4, 2012
    Is the paint color for the Campagnolo wheel the same as for the Cromodora wheels?
    Thank you,
    Scott
  22. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,156
    Iain
    #22 isuk, Oct 4, 2012
    Argento 101 is the wrong colour IMHO. It is too bright a silver and more akin to what was used from the 355 onwards. Many cars appear to have had their wheels restored over the years and bright silver has become the norm. My car's wheels were in untouched original condition prior to the restoration but were flaking in places. They were colour matched to a FIAT dull silver which looks almost grey with a hint of blue in dull light. In bright light is has more of a silver appearance.
  23. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Kingston upon Thames
    Chris O'Connor
    I think I remember seeing a thread about the colour spec for Dino rim paint.
    Does anyone have a record of this please? Chris
  24. rynoshark
    rynoshark Formula 3
    1,021
    Pacific Northwest
    Ryan
    What is the final consensus on the correct paint to use? The PPG Global recommendation from Beckman?
    Keith, which shop in Seattle redid your wheels? Did they go all the way to Mag and properly retreat the bare Mg before painting...or did they just go down to primer?
    Thanks.
  25. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Is there a different color for different versions? If so whats an "e"
