What is this shim for? | FerrariChat
Discussion in 'Mondial' started by Cadillacbart, Jul 13, 2016.
  1. Cadillacbart
    Cadillacbart Formula Junior
    Nov 26, 2013
    436
    Denver, CO
    #1 Cadillacbart, Jul 13, 2016
    I found this laying in the passenger footwell if my 1988 cab. The one I found was bright metal( this picture is from eBay). Searching the part number only results in "shim". Any idea where this belongs?
  2. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    That's a fetzer valve shim I believe. It secures the valve against the firewall, while you are up in there you might want to get some 3 in one oil on it to stop it from squeeking.
    Regards Bell Bloke
  3. Alden
    Alden F1 Rookie
    2,913
    Central Florida
    Try to get one made in the US, they are better than the Chinese copies out there now.
    Of course, it also looks like a poindexter shim, I dunno, been a while since I have seen one, they usually don't fall off if installed correctly.
    Alden
  4. ronfrohock
    ronfrohock F1 Rookie
    3,941
    MA
    Ron Frohock
    Are there shims under the mounting plate?
    Just a long shot....
  5. Bell Bloke
    Dec 6, 2012
    1,839
    Alden, if memory serves me correctly I think you maybe right, the poindexter shim is indeed situated in the passenger footwell area and actually the fetzer valve is in the trunk on the Mondial cars.
    I stand corrected, many thanks Bell.
  6. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    Thanks Gordon.
  7. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    Could be Ron, I'll take a look.
    Thanks.
  8. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    What's a Fetzer valve, and what is it used for?
    Sid
  9. Bell Bloke
    Dec 6, 2012
    1,839
    Sorry Guys, it was a quiet day and I was feeling mischievous.....
    Anyway if nothing else knowing your fetzer valves is to know your 80s classic that is 'Fletch'.... since we all own 80S cars here.
    Regards Bell
  10. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    absolutely one of my favorites - and most quotable.
    The shim is still a mystery though. Cannot figure it out, and it just appeared on the floor one day.
  11. Alden
    Alden F1 Rookie
    2,913
    Central Florida
    As Ron said, it looks like part of the top latch mechanism, I would look up there and see if something looks like it is missing or misaligned.
    Dimensions or a rule laid next to the part in a pic to give us the size would help too.
    Alden
    (Blinker fluid, muffler bearings, 710 cap, what else?)
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    I assumed it fitted behind the wuffle plug- there is such a thing
  13. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    I've been breaking up several Mondials and never came across this. Maybe it comes from something else?
  14. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    And then I said to myself......
    "Time to put work aside and go watch a movie and have some fun!!!"
    Sid
    P.S - was it the 6th or 7th Fetzer valve?
  15. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    #16 Cadillacbart, Jul 15, 2016
    Can't find anything amiss with the latches, but yes, the piece would seem to fit there:
