What is this Mondial worth? | FerrariChat
Discussion in 'Mondial' started by Birdman, Aug 4, 2004.
  1. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    OK, I'm talking to a guy about a Mondial I haven't seen yet. It's an '82 Mondial 8. It has terrible paint, needs to be repainted. Lousy interior. Hasn't been driven in 10 years (!) but he claims it starts and runs. Basically, we're looking at a project car here. Minimum, it will need seals, belts, hoses, tires, a paint job and upholstery work. Then the other stuff that crops up. Here in MA it would need to pass smog until 2006 when the car is 25 years old. The guy is asking $12K which is rediculous in my opinion. What's it worth? I can do all the work myself except paint and upholstery. I'm considering it if I can get it cheap enough that its worth the effort to fix it. Then there is my wife to convince...
    I'll hopefully have a pic to post shortly.
    Birdman
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I almost forgot, 16,000 miles. (Obviously this guy needed to be out driving this car a hell of a lot more).
  3. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    Needs paint, interior& unknown amount of mechanical work?
    I'd say it's worth about nothing.
    Be better of to find a good one (or at least decent) rather then trying to fix that one up.
    It's not worth it. The parts and labor will offset the final value (which for a Mondial 8 "2 valve" is way low).
  4. tifosi
    tifosi F1 Veteran
    Sep 5, 2001
    5,382
    texas
    Tom D
    agreed best 8 is worth low 20's on a very good day, more like high teens - he should be lucky to get 5k
  5. dretceterini
    dretceterini F1 Veteran
    Apr 28, 2004
    7,289
    Etceterini Land
    Dr.Stuart Schaller
    Well, since you can do most of the work yourself...and paint and interior will cost at least $7,000....maybe $3,000....
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Would agree that the best car in the world is $20K, maybe a bit more on it's very best day. The car you describe, well, is pretty much a shell.
    The work is pretty straightforward. The parts will be expensive though. There are cheaper aftermarket components that may save you some if pure concours stock is not an issue. Would not worry much about emissions because it will be 2006 before you may finish...
    good luck
    rt
  7. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    i've seen and heard of a very similar run down Mondial
    it isn't black is it ?
    i think the car is worth $6k
