What is harder on a Ferrari, hot or cold? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Husker, Aug 1, 2020.
  1. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    So I am keeping my new 360 garage at 75 in the summer, 60 in the winter.
    If it wasn’t temp controlled, it would reach 100 or more in the summer, and 20s in the winter.
    Which of those extremes is harder on a car - paint, leather, seals, rubber, etc?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,872
    Central NJ
    Dominick
    Temp is not the biggest concern .. humidity is the biggest probably ..if you keep the humidity from 40 to 50 percent you should be ok...that being said 20 degrees probably worst than 100 degrees
    Sent from my moto g(7) using Tapatalk
    PhilNotHill likes this.
  3. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,778
    Weston, MA
    Paul
    Clearly heat is is harder on any car than cold. As long as you have proper antifreeze, windshield washer solvent and oil, cold isn't a problem.
    crinoid, LVP488 and 308 milano like this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,872
    Central NJ
    Dominick
    I think the UV is the second biggest issue next to humidity
    UV destroys paint leather rubber etc
    100 degrees in a covered / enclosed garage is really nothing for a car ..think about the temp a black car gets even in a 70 degree day ..I would say the interior gets to over 130 and the paint even more ..so a garage with 100 degrees at 45 percent humidity is not that bad
    The third thing the affects material is the change in temp ..like going from 20 to 100 etc ..
    I hope that gives you a little insight
    Of course keeping a 45 humidity and 55 to 75 degrees always would be the best
    That is why airplanes and cars store better in Arizona
  5. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    isn’t Arizona also low humidity overall ?
    F1 Tico likes this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,872
    Central NJ
    Dominick
    #6 flash32, Aug 1, 2020
    Exactly ..my point is that the heat is crazy but humidity is low and cars do not suffer the problems of corrosion etc
    The dry humidity is a little harsh on leather etc and that is why I stated that if 100 degrees and humidity 45 percent and inside ..non-issue for car
    To answer the OP question ..having a hot garage is better than anything below freezing especially if humidity is around 45 or so
  7. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Have a heated and aircon garage. Keep the temp at 51F in winter. Reason is that is the perfect temperature to keep wine.
    We keep paint and other stuff that we don’t want to freeze.
    tantumaude likes this.
  8. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,324
    Montana
    Kim
    Owned a body shop for many years. Hands-down, heat does more damage to exterior paint and interior leather than cold weather..
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,872
    Central NJ
    Dominick
    I think we are talking about two different things ..sunlight and outdoor heat is different than 100 degrees indoors
    Yes sunlight (uv) and heat which gets amplified by the sunlight definitely causes extreme damage .. believe me I know . But a hot indoor garage is not the same ..
    Bringing this thread "outside" adds a different dimension to this equation.. both cold and hot
    rumen1 likes this.
  10. Solid State
    Solid State F1 World Champ
    10,563
    Maximus Decimus Meridius
    Humidity, followed by heat, followed by cold. But mice have to be the worst!
    AlfistaPortoghese and flash32 like this.
  11. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    IN my experience , my 328 runs best when its warm or even hot outside, would I leave my car outside in the heat, no, only if I have a car cover.
    Thank you
  12. the_dan
    the_dan Karting
    160
    Hong Kong
    Heat is a problem in terms of UV and direct sunlight destroying paint, leather, exterior trim, everything.
    I can’t see any problem with 100F in an enclosed underground garage though. At least I’m hoping not because mine reaches that temp most of the year.
  13. jag-oo-r
    jag-oo-r Formula Junior
    424
    So can we be more clear on the original question, so the answers get some context? We all know sunlight / UV is a killer. (I'm a fair-skinned red-head.... I know better than most, haha)
    Assuming indoor storage (no UV) and low-relative-humidity; is 100°f better or worse than say 20°f?
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,872
    Central NJ
    Dominick
    I thought I had given my thoughts above . 100 degrees low humidity is better than freezing
    F1 Tico and jag-oo-r like this.
  15. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,939
    Phil,
    Really good point, I like your thinking!
    Do you have two garages, one for white and one for red?
    jag-oo-r likes this.
  16. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,830
    Bulgaria
    If you use the car often, hot is much better for cold starts obviously, as the engine oil is not so thick. And as someone very accurately pointed - the sunlight is the actual problem, and not the heat itself. And on second place is of course is the humidity. Other than that - it's just a car, it doesn't need to be perfectly warmed all the time.
  17. SVCalifornia
    SVCalifornia F1 Rookie
    2,567
    Silicon Valley
    Keith
    At that temp, has to be white!
    SV
  18. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    We have some temperature controlled wine cooler refrigerators. The overflow goes in the garage which is only white wine. The red wine is always in the wine cooler refrigerators.
    Life is good.
    F1 Tico likes this.
  19. Themaven
    Themaven F1 Rookie
    Nov 2, 2014
    4,361
    Eastdown
    Darius
    I have my wine cooler refrigerators in a garage, next to the garages housing my Ferraris. The Ferraris don't have bubbles or refrigerators, but they have heaters to ensure the temperature doesn't drop below around 10C/50F in winter. I tried dehumidifiers but they were too fiddly. The cars are always happiest mechanically in warmer weather. I certainly feel the paint and leather hasn't suffered any degradation in the cool temperatures the cars are stored in. But I don't have any reference points to compare to.
    For wine, 51F is good for storage for either colour. the most important thing is to avoid fluctuations in temperature.
