News
What company can redesign my 2012 FF seats into a Diamond Design plus provide some other tweaks .nee
Discussion in 'FF/GTC4Lusso/F12/812S' started by Actualizer, Oct 30, 2019.
  1. Actualizer
    Actualizer Karting
    May 24, 2017
    98
    Qld. Australia
    I need my FF seats to be diamond designed and redone by better foam and cushion to make them more like Lusso seat . Both me and my daughter have had back surgeries , and considering that FF is a bit crude and brash in daily driving stops and braking ,we feel still in our lower back even after short distances . This was not the case in our Lussu ride comparison . Is there any specialist shop who can modernize and upgradege my FF seats design and ergonomics ? Thanks
  2. Il Co-Pilota
    Il Co-Pilota Formula 3
    May 29, 2019
    1,827
    Copenhagen
    A.B
    I can't answer the shop part, but here's a few thoughts.
    Sounds like you need a Lusso. One of the big differences between the Lusso and FF is the ride itself. The Lusso is MUCH more compliant, especially at lower speeds around town etc. You can venture into this, but there's absolutely no guarantee that it will solve your issue, and in the end it might just cost you a lot, including cost for added devaluation. You take a gamble with such a modification, because there's no guarantee that the colour will match, nor that the seats will be as comfortable as you hoped. If you think it's the Lusso seats that somehow are the fix, then I suggest you get a set of Lusso seats. I'm quite sure they will bolt right in. With those you stay OE and have a good chance of matching leather, pattern and stitching. But that being said, the Lusso and FF seats themselves aren't that different. I suspect that what you feel is the different between the Lusso and FF, because those two cars a very different in the ride comfort department due to chassis changes.
    Actualizer and ANOpax like this.
  3. Actualizer
    Actualizer Karting
    May 24, 2017
    98
    Qld. Australia
    Unfortunately Lusso seats don’t fit Ff.
    Buying a Lusso is dead money.
    Was hoping to find an expert upholsterer on these forums.
    Could Novitec spring lowering and maybe wider wheels might tighten the bouncy ride ?
