Vacuum hose to ignition module? | FerrariChat
Discussion in 'Boxers/TR/M' started by JohnMH, Jun 30, 2021.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Can I ask, what would be the effect of disconnecting the vacuum hose from the ignition module on the left side of the engine bay? Does the level of vacuum determine the ignition advance?
    I have my engine out and seem to have forgotten what the hose from the module connects to.
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,402
    Alabama (was Mich.)
    Jeff
    Hi John....if my memory is right...yes....vacuum does influence the ignition advance. I think the hose goes from the front-left intake plenum to the ignition module.
    Steve Magnusson and turbo-joe like this.
  3. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Thanks. You would have thought I could have taken a photo.
  4. Steve Magnusson
    25,148
    See the engine advance curve on page D63 in the TR WSM. With the vacuum line disconnected from the Microplex ECU, A=0, so only ignition curve 1 would always be used.
    They left it out of the graph, but A = the vacuum level in the intake plenum in units of millibar.
    Also, the graph is with the idle thottle micoswitch open. Having the idle microswitch closed retards the whole graph by 4~5 deg IIRC.
  5. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Thanks. So… where does the other end of the vacuum line plug into?
  6. Steve Magnusson
    25,148
