tracked? | FerrariChat
tracked?
Discussion in 'Ferrari Discussion (not model specific)' started by Thorleif, Feb 26, 2021.
  1. Thorleif
    Thorleif Rookie
    Aug 29, 2016
    2
    Williamsburg, VA
    Thor Barbru
    I am considering buying either a 458 Spider or perhaps a Speciale. Is there any way a technician can pull the data and see if the car has been tracked? I had a Lotus Elise at one point where they could see it had most likely been on the track, but they also told me they could erase that data.
  2. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,285
    Colorado
    Dave
    IIRC, you could pull engine data from the Elise and see how many times it was redlined. Perhaps that's what you are talking about? I don't think 458s store that type of data but could be wrong. 430s definitely don't. In any event, probably the best way to tell if a car has been tracked is to put it on a lift and check for bits of tire compound stuck in hidden areas. Not many 458s ever see a track and I wouldn't worry about it anyway. Modern Ferraris are built to take that type of use.
    Dave
    VAF84 and jag-oo-r like this.
  3. fatbillybob
    Aug 10, 2002
    26,427
    socal
    Why does that matter? I'm a racer at the highest level of amateur racing. The very few owners who take their ferrari on track barely stress the cars beyond freeway speeds on a surface that is much kinder on the cars than unpredictable street surfaces.
    Jeffg11, FerRrari, Meister and 8 others like this.
  4. itsablurr
    itsablurr Formula 3
    Dec 9, 2005
    1,010
    Carlisle, MA
    Matt
    What's wrong with a Ferrari thats seen some track time?
  5. HotShoe
    HotShoe F1 Veteran
    7,524
    Lake Worth, FL
    Anthony Lauro
    IMO it should be a requirement to ownership. :)
  6. jag-oo-r
    jag-oo-r Formula Junior
    423
    Oh Amen to this. AMEN!
  7. Ellena
    Ellena Rookie
    Apr 20, 2020
    26
    Chanhassen, Minnesota
    J. Anderson
    Indeed. Track days should be requirements with these cars. ALL of them.
    FerRrari and HotShoe like this.
  8. 4_Eff_Sake
    4_Eff_Sake Formula Junior
    Jul 30, 2016
    761
    Australia
    Scott
    If you don’t ever track your Ferrari, how will you actually know everything’s working properly?
    FerRrari, 430tdf and EnzoItaly like this.
  9. becker
    becker Formula Junior
    Feb 20, 2001
    340
    Arlington VA
    Becker Cuéllar
    When I got mine brand new took it to next track event available after a couple of months
    MacNugget and FerRrari like this.
  10. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Anot
    Would this be a deterrent to buying either or just a curiosity?
  11. Jeffg11
    Jeffg11 Formula Junior
    552
    Michigan
    Jeff Grabowski
    In most cases a car that has seen track usage is often better maintained than a car that sits in a garage all year.
    On top of that, the consumables and fluids are refreshed often.
  12. 3POINT8
    3POINT8 F1 Rookie
    4,433
    I might be concerned about track usage if the car was a three pedal or single clutch and clutch wear was an issue but you can get a read out for that. I wouldn't worry about that much with a 458. I may be worried about over revs but I believe the DCT will shift for you and generally not allow this. I've made some shifting mistakes on track but the computers always jump in and save my ass.
