TR Engine out service | FerrariChat
Discussion in 'Boxers/TR/M' started by ria, Feb 8, 2018.
  1. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    Ready to take the engine out who has step by step information I can not find any good information on the search thanks.
    Sent from my SM-J700T1 using FerrariChat.com mobile app
  2. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    WSM gives a good directions on engine removal. Get zip lock bags and label all the bolts etc.
  3. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    What is wsm?
  4. ago car nut
    5,267
    Madison Ohio
    David A.
    Work Shop Manual. You can buy online as CD. One thing, I did mine twice without a lift, it is possible. Check out some of my prior posts. If you get stuck PM me.
    Dave
  5. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    Ok thanks I do have a lift maxjax I just wanted some more information that way I know what I am getting in to.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,692
    Central NJ
    Dominick
    Sorry to high jack the thread ..but any instructions for a 512tr which is different than a TR
    Sent from my Moto G (4) using Tapatalk
  7. ago car nut
    5,267
    Madison Ohio
    David A.
    Never did a 512TR, I know the engine has to come out from the top. The frame does not drop out like a TR. Do a search, Someone has done it!
  8. tvu
    tvu Formula 3
    1,310
    Southern California
    Trieu
  9. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,907
    Troy, Michigan
    James
    there is a link on here to somebody's instructions. It's what I used. just search for tr engine diy or something along those lines. Only problem is that those directions were for a euro TR without the air pump. I missed that step and it got hung up on the air pump bending my shifter rod.
  10. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,907
    Troy, Michigan
    James
    also, make your own engine cradle. I used someone elses instruction that let you adjust the cradle up and down. they made mating the engine so much easier.
  11. ago car nut
    5,267
    Madison Ohio
    David A.
    I did the same on first engine drop! second time removed the shifter rod. Before re installing the engine I removed the air pump, and made nice block off plates of stainless. Saved all the air pump stuff nice and tidy. If someone wants to put it back on, very easy.
  12. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    If you put the shifter on second gear before you drop the engine it will be ok as far as i know.
    turbo-joe likes this.
  13. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    the wsm has a very good (but brief) set of step by step engine removal procedures.
    they are taped up on my wall and referenced many times while removing the engine.
    they will keep you from forgetting something and doing an “oh, ****”.
    Go slow - use care - ask questions - never force anything.
    Cheers,
    Vincenzo
    raysur likes this.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,692
    Central NJ
    Dominick
    It is strange that Ferrari put that in wsm for the testarossa but did not include the same in 512tr wsm
  15. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    i have to find the info first on how to remove the engine and print the info.
  16. ago car nut
    5,267
    Madison Ohio
    David A.
    Yes, if you are careful.
  17. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,388
    The Cold North
    Tom
    I posted a step by step a while ago. Years ago in fact. It should come up with a search..
  18. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    Try can not find.
  19. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
  20. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    thank you for all your help i can use this.
