TR/512Tr Valve Cover and End Cover Torque and Order | FerrariChat
Discussion in 'Boxers/TR/M' started by tf308, Mar 22, 2020.
  1. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
  2. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Bueller...Bueller...Bueller
  3. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Anyone know of a TSB that has this?
  4. Rifledriver
    34,119
    Austin TX
    Why? At some point common sense need to prevail. Not singling you out here but are we so helpless we need step by step instructions for everything?
    peteficarra and turbo-joe like this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,691
    Central NJ
    Dominick
    The wsm says 8.8 nm for valve cover torque
    Sent from my moto g(7) using Tapatalk
  6. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Brian...I hate leaks. I’m just curious what you do. If they weren’t already seeping...I wouldn’t be asking!
  7. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #7 vincenzo, Mar 23, 2020
    Just make ‘em evenly snug in a star pattern - start in the middle and work outward and around.
    First round, just enough to secure the cover.
    Second round, just enough to lightly compress the gasket.
    Third round, nice and snug.
    Use a small 1/4” drive ratchet, hold it around the head with a single hand and give it a good, firm single handed torque.
    none of that two handed 3/8” drive grunt.
    those are small m6 studs.... easily broken with a two handed grunt. Excess torque is not a leak solution. .
    Lesson learned:
    Apply torque with your head rather than your muscles.
    Recommendation:
    Go to the hardware store and buy a dozen or so 1/4” bolts, nuts and washers. Get a few larger nuts that can be slipped down the bolt’s shank outside of the threads. Secure the bolt in a vise and lube it up.
    Run the 1/4” nut down to the larger nut/washer. With lots of lube, torque to failure. Do this a dozen times and ‘feel’ how it fails.
    torque will increase in a linear manner with rotation until the bolt starts to yield. Then, the torque will no longer increase but the rotation will continue. If you just ‘start’ to reach the initial yield point, you can likely stop there without damage. Do it with your eyes closed... a zen meditation exercise.
    from that point on, you will always be able to feel your fasteners and prevent damage. That ‘feel’ plus a good torque wrench will go a long way in making you more skilled.
    PS: Just to be clear... i am not recommending you torque your cover’s studs to yield!
  8. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Ha! I get it. I always wondered if people like Brian (who I have all the respect in the world for) did an OCD torque approach or the Zen feel.
    I’m doing an oil change now and thought I would tackle the valve covers. It’s always fun to learn from the group.
  9. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Both zen and ocd methods are needed in your arsenal! Any decent mechanic has a bunch of torque wrenches in their drawers. The good ones have annually certified wrenches.
    one last point of note... many applications call for torque values significantly below a bolts yield strength - OEM torque specs must always be your first choice.
  10. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,388
    The Cold North
    Tom
    8 to 10nm working from the center out in a criss cross pattern also making sure the gasket ends at the corners do not get displaced. A finger keeping the gasket in place under torque works wonders.
    turbo-joe likes this.
  11. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
  12. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Here is the pic as soon as I pulled the old cover off. Any thoughts on the use of the old sealer, especially around the cam seals? Image Unavailable, Please Login
  13. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    All new gaskets... cut extremely carefully to fit. A paper hole punch works well to scarf the new gasket around that cam o-ring.
    New o-rings at the plugs. Clean the old pia silicon in the plug o-ring grooves out with a wooden pic that is sold for a hand manicure. You can dig it out without damaging the soft aluminum. Now you know why I use hylomar instead of silicon.
    spotlessly clean...
    Carefully wipe down with carb cleaner. on sealing surface only (via a rag - not spray). Not on o-rings.
    Many disagree.... but I recommend hylomar with a dab of silicon at the cam’s o-ring interface. See those white silicon worms hanging off your plug o-rings? They are begging to be let free to clog your oil screen... or worse yet, plug an oil hole at a bearing. Hylomar will not do that.
    Chase your stud threads to allow free torque (not the head... just the studs). Where the stud came out of the head by accident, clean the stud hole carefully & inspect the threads. Don’t mess up those threads in the head! Think twice before you consider running anything in that stud hole. A q-tip soaked in carb cleaner is about the only thing beyond the stud that should go into that hole... unless it is already damaged! Use blue locktite on your studs where they enter the head. Permatex etc is crap - use locktite. No locktite on the cover nuts.
    Use something like this... consider it a ‘must’ at 35$ on amazon:
  14. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Love the response. I was thinking all of the same. Thanks for the input.
    I’m thinking Loctite 518 anaerobic sealer.
    I’m honestly shocked at what I saw in here.
  15. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #15 vincenzo, Mar 25, 2020
    Just to clarify... that lang set is NOT a tap & die set. It will clean and deburr threads but will not cut threads.
    no experience with 518 on gaskets.
    hmmm... as long as you are in there, you might as well check your clearance. You never know until you personally check. The previous service may not have been done well.
  16. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
  17. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
