Tornado visiomatic connection diagram? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by raemin, Aug 31, 2019.
  1. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    Judging by the older photos I have, my car was upgraded from single vitaloni tornado to dual visiomatic.None of my mirrors seem to work. I do have the "joystick" for a single mirror, some kind of harness was provisioned for the second mirror but I will have to sort it out.
    Any idea on how these red, blue, yellow black wires are supposed to be connected in order to slide the mirror up/down/left/right?
  2. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    The "joystick" is a BMW part from an early 3-series. I posted part number for the 2-mirror switch about 11 years ago. BMW has switch for both one and two mirrors. My wires go to switch via a flat plug connector. Ken
  3. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    I've got a serie 1 400i, so it's not the BMW button (saw your older post), it's the >$400 vitaloni "joystick". Well my car actually has the <50$ single mirror joystick, but I am trying to figure how to modify it for 2 mirrors...
    Fortunately I've just received an email from a Pontiac Fiero enthusiast, explaining how to wire these, It lacks clear indications on which wires to enable in order to move the mirror in a specific direction; however the diagram suggests that inverting two wires could do the trick.
    All in all the plan is to use the "hidden" unused keystroke of the existing button so has to enable a ($20) Flip Flop circuit which would hopefully toggle the control from mirror 1 to mirror 2. Additional Vitaloni information would help, as none of my mirrors do work and as initial step, I'd rather experiment on a "stock" working setup...
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    #4 raemin, Oct 12, 2019
    Took me quite a while, but here are a few notes I've collected from FChat, plus a few hints from the Pontiac Mera's forum as well as my own findings. The resulting diagram is as follows, but one should read the whole post as there are quite a few color variations one should be aware of.
    Mirror disassembly
    "To remove the mirror from the door, gently remove the rubber boot, which covers the front screw (you can also tighten the mirror pivot), then with an exacto knove remove the triangle shapped plastic on the back of the mirror. This triangle hides the mirror rear screw. Once both screws are removed you can detach the mirror from the body."
    "To remove the motor, just unscrew the two black countersunk screws [that face the asphalt when the mirror is on the car]. [Although not mandatory, you should consider removing the glass and store it in a secure place as it is fragile]. Once the motor is loose it is easy to move the mirror and force an exacto knife (or something else as thin as possible) between the glass and the plastic backplate. The glass is attached to the frame with double sided tape."
    The actuator is made by Eaton IKU Montfoort BV Netherlands
    If the motor and solenoïd do not work you may have to disassemble the mechanism. Note that removing the 4 screws is not enough: you will also have to disconnect the cables as the thin blade connectors (on the black brown white blue cables) are very stiff and "lock" the motor on the black frame.
    Based on wolftalk experience I was expecting n challenge with the harness. Needless to say I wasn't disappointed!
    Black Yellow Blue Red Harness
    Mirror connection
    • Black wire harness goes to any of the solenoid cables (i.e white or brown)
    • Yellow wire harness goes to the other solenoïd cable (i.e brown or white)
    • red wire harness goes to blue wire of the motor.
    • blue wire harness goes to black wire of the motor.
    In order to reverse the mirror direction you may have to swap red/blue (ie blue>blue red>black instead of red>bue blue>black)
    dual mirror switch connection
    Depending on the switch type (there are two models I am aware of), the pinout of the dual mirror switch is as follows (from left to right when the switch is on the console with the cable exiting toward the gearbox shifter)
    • pin1: black/white (or black)
    • pin2: blue/white (or red)
    • pin3: yellow
    • pin4: blue
    • pin5: blue/black (or yellow/black)
    • pin6: red (or blue/black)
    All in all one should not trust the colours of the wires directly attached to the switch, and check the pins. Here is how each pin should be connected to the Ferrari mirror harness
    • pin1: ground > Bat- & both black cables from the mirrors (*)
    • pin2: bat+ > light-blue/black cable with inline fuse
    • pin3: both solenoids > Both yellow cables from the mirrors
    • pin4: both motors > Both blue cables from the mirrors
    • pin5: left motor > red cable from right mirror
    • pin6: right motor > red (**) cable from left mirror
    (*) if your mirror has 2 yellow cables instead of one yellow and one black, consider one of the yellow as a black cable.
    (**) some mirrors have green/red & red cables instead of two reds in order to distinguish cables from left and right mirror. red green should be for left mirror.
    single mirror switch
    Unlike the dual switch, this switch relies on a 4pin connector (connected to the mirror) plus a separate 1pin connector that provides the voltage from the battery. So you may have to cut the connector in order to use single switch with two mirrors or a single mirror with a dual switch.
    Cables of the 4 pin connector
    • brown : ground > Bat- & Black wire from miror
    • white : solenoïd > Both yellow cables from the mirors
    • green : motor > red/green cable from miror
    • black : motor > blue cable from miror
    spare cable
    • brown wire : bat+ > white/blue cable with inline fuse
    If you have a single mirror switch and two mirrors, you can make it do with a switch that toggles the appropriate (left or right mirror) red wire, and connect together the remaining cables (both blacks together, both blues, and both yellows)
    I've also included the vitaloni PDF manual (courtesy of Nelson Thompson from the Mera club). I've added the appropriate colours to the black and white drawings.
  5. Jagerocks
    Jagerocks Karting
    Sep 29, 2019
    82
    JASON
    I'm in the same vote, why does this seem so hard. So to confirm if anyone knows. My yellows go together..blues go together...power to red....ground the black...? Any help would be greatly appreciated . Image Unavailable, Please Login Image Unavailable, Please Login
  6. Jagerocks
    Jagerocks Karting
    Sep 29, 2019
    82
    JASON
    On the mirrors the wiring is only. 2 yellow...1 blue....1 red.
    The switch is...
    1 blue
    1 blue blk
    1 yellow
    1 yellow blk
    1 red
    1 blk
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    The round soft connector is not used on our cars: in the door you will find a 4 pin fastin/faston connector (square shape), next to the window motor. Except for the so-so connector, the connection does seem correct though. Your lucky: all your cabling colours seem compliant with the old drawing I posted.
    As far as your button is concerned, have you checked it before connecting it: I had to open mine, thoroughly clean it, and apply lots of dielectric grease before it could work properly (lots of false contacts due to the ageing grease). So check with a multimeter that the wires are properly toggled when the joystick moves up/down left/right. If you do not have such grease, you can use baby grease (petrol jelly).
  8. Jagerocks
    Jagerocks Karting
    Sep 29, 2019
    82
    JASON
    Ok thank. I have ordered another switch..(alfa) from ebay and should have it here this week. Hopefully all will match.
  9. Jagerocks
    Jagerocks Karting
    Sep 29, 2019
    82
    JASON
    Am I right with red goes to power and black to ground on the switch? Do you know.?
  10. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    That's pin num2 ( red on yours) . By the way you listed the pins in reverse order in your previous post. Black is pin1 in my description, red is pin2 etc...
  11. Jagerocks
    Jagerocks Karting
    Sep 29, 2019
    82
    JASON
    Thanks. it all worked out well.
    Now on to the next repair...lol
    Window cables loose....ahhhh
    raemin likes this.
  12. Theruse
    Theruse Karting
    Jan 17, 2014
    189
    Maryland
    Prescott Russo
    I am in the process of adding a dual mirror switch on my series 1 as I have installed an electric mirror to the passenger side. In the schematics, diagrams etc in this thread it mentions all different colors of wires that may exist. What is not clearly explained is which of the four wires from each mirror ( two for the motor and two for the solenoid) is attached to each pin from the dual mirror switch. Since each mirror has only one motor, when the solenoid is engaged, changes the movement from left or right to up or down. My understanding of the switch is if you move it to the left or right only the motor should be activated to move the mirror right or left If you move it up or down, both the motor and solenoid should be activated to make the mirror go up or down. The schematics don't show which wires from the switch go to the motor or solenoid. As well trying to figure out, which wire powers only the left mirror and which wire powers the right mirror. I have used my multimeter but stil not sure how best to wire.
  13. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    Both solenoïds are operated together, so if you want to pull up left mirror , both left andn right solenoids are activated, but only left motor will operate. In other words you hear an audible click on the wirror that is not supposed to move.
    So both solenoids do share the same harness.
  14. Theruse
    Theruse Karting
    Jan 17, 2014
    189
    Maryland
    Prescott Russo
    That is most helpful. Do you know which Pin(s) on the switch is used for the solenoids. Once I know that, then I can figure out which pins work for the motor. I am assuming one Pin will work for left motor and another pin will work for right motor.
  15. raemin
    raemin Formula 3
    Jan 16, 2007
    2,335
    Lyon (FR)
    R. Emin
    Schumi likes this.
  16. DrFunk
    DrFunk Rookie
    Nov 22, 2023
    26
    Ian Kirkman
    just wanted to say, that i have 2 powered vitaloni mirrors that i am installing in my 78' 308 and this is exactly the post i have been looking for. Thank you so much!!
    Tojo and raemin like this.
