458 - Throttle jerkiness - is there a fix? | FerrariChat
458 Throttle jerkiness - is there a fix?
Discussion in '458 Italia/488/F8' started by jordie999, Jan 14, 2020.
  1. jordie999
    jordie999 Rookie
    Jan 14, 2020
    5
    Justin Kay
    Hi - I need some advice. I'me looking at buying a 458 spider. I intend to drive the car regularly, not just for sunny days. I've heard from several sources that at slow speeds, around time, or even cruising trying to maintain a constant speed, the throttle is overly sensitive, which when your nailing it isn't an issue. I have been advised to find a car with cruise control, which I will, but have there been any software updates to resolve this issue. I am told it is a fly by wire throttle. Is there a cut off model year when the issue has been resolved? Thanks in advance....
  2. docf
    docf Formula 3
    Sep 14, 2008
    1,412
    Florida
    Gary
    Seriously not much of an issue. No fix to my knowledge.
    14RE458 likes this.
  3. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    I drive in automatic 95% of the time (ducks and runs). The trans shifts up into high gears very quickly, will hit 7th gear at 37 mph or so. When driving this way, throttle is very smooth. If manual shifting and in low gears at higher RPMs, it is a little jerky/sensitive. Mine is a 2015 model. No 'fix' that I am aware of, but no problem either as far as I am concerned. If it is a huge issue for you, I would suggest a custom tune. Surge/sensitive throttle is often caused by lean mixtures. Have the tuner fatten up the fuel delivery a bit and see what happens.
    14RE458 likes this.
  4. FFan5
    FFan5 Formula Junior
    Jul 7, 2018
    550
    I guess I'm lucky. Mine is really smooth. Now, it was super annoying on the highway going a constant speed because of the valves, but that goes away if you put in a valve controller or just plug the suckers.
  5. wthensler
    wthensler F1 Rookie
    3,501
    Gator Country, FL
    William
    Hahahaha - drive the car, don't let the car drive you. Seriously.
    It's a prancing horse, not a VW.........
    Borrow’d Mine likes this.
  6. FFan5
    Jul 7, 2018
    550
    Oh, one other thought, I've experienced this behavior in multiple cars that aren't' driven often and/or hard. If I don't drive the car for three weeks, it is a little jerky and unhappy until I put some miles on it and the engine smooths out again.
  7. Ianjoub
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    I'll guess this was directed at me with the auto mode. When I start using the paddles I start driving like a hooligan. Fun, yes! Likely to keep me out of jail in the long term, NO! I pick my spots and play accordingly.
    On that 'play' note I will likely rent the 1.6 mile road course at the Gainesville dragway sometime this spring. I'll post up to see if you/others want to come play.
    http://www.gainesvilleraceway.com/apcm/templates/trackinfo.asp?articleid=2546&zoneid=69&navsource=History Image Unavailable, Please Login
    DefunctNeurons likes this.
  8. wthensler
    wthensler F1 Rookie
    3,501
    Gator Country, FL
    William
    Absolutely!!! I’ll be your best buddy ever! We can trade cars.
    Ianjoub likes this.
  9. PJxxx
    PJxxx Karting
    Sep 14, 2017
    129
    PJ Cusano
    Try alternating your foot position/ contact point on the pedal. For example, if your contact point is close to the base of the pedal near the floor board, you should feel less jerkiness. At least that’s what I do and I feel like I can blip the throttle at will and control the response to meet my needs.
    Also, thin soled driving type shoes will help you as well versus clunky Air Jordans
    Bandit23 likes this.
  10. JasonN
    JasonN Formula Junior
    Sep 24, 2017
    298
    Jason
    This is not an issue. I read about it prior to buying mine but found the claim an exaggeration. It is more of an on/off feeling compared to my 812 but don't let it deter you. The 458 Spider is a fantastic car.
  11. jordie999
    jordie999 Rookie
    Jan 14, 2020
    5
    Justin Kay
    cheers, looks like an over exagerrated issue....
  12. Tarek307
    Tarek307 Formula 3
    1,348
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    totally exaggerated! i think throttle is normal like any car.
  13. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    Dear Terek,
    this is not my experience at all.
    May I respectfully ask you to make examples of the cars you drove and consider the same as a 458 in terms of throttle response?
  14. Tarek307
    Tarek307 Formula 3
    1,348
    Tarek Salah
    Mostly i drive Porsche 911's . Driving the 458 without hearing about "jerky pedal" i would have never even thought that..seems normal to me
  15. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    It is an issue, and there are tuners like openflash that can fix it. I am going to be talking to Shiv about getting mine to feel more linear. I cannot vouch for every 458 but everyone I've ever driven (which is a few) has it. I am more sensitive to things (comes with my condition) than normal so I tend to feel things that others don't (like a pebble in my front tire), but it is there and it is not an exaggeration, I wish it was.
    Need4Spd and Shadowfax like this.
  16. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    Yep annoying as it is its a normal trait. 458 and 488 both have a jerky pedal when in manual mode. It's not a deal breaker but it is a PITA. Pista is not nearly as jerky thank god so they've clearly been working on it. Ferrari will eventually fix it up one day. Bit like their crap media.....makes you wonder how on earth they've managed to get away with it in this day and age. Amazing really! I wouldn't use the jerky pedal as a reason not to buy a Ferrari but yes it is a problem. And for some to not feel it or even see it as a problem is equally astonishing.
    Need4Spd and DefunctNeurons like this.
  17. Ski Bum
    Ski Bum Formula 3
    Jun 19, 2012
    1,088
    This is an over-exaggerated issue, and can be controlled once you get used to the car. In the 458 series, the throttle on the coupe is more twitchy than the throttle on the spider. This is far less of an issue in the 488 series. (Yes, I've owned them all).
    Caeruleus11 likes this.
  18. hmfic1
    hmfic1 Karting
    Aug 15, 2011
    165
    Scottsdale
    Jerry
    drive the car in sport mode, no throttle issue at all. In race, yes it can get a bit touchy. Other then that I have no problem at all with mine,
    and have driven it all most 30k miles, Just a great car, you will love it.
  19. Corradosv
    Corradosv Karting
    Oct 17, 2016
    194
    Monaco MC
    That's interesting: I have owned myself a 964 (not a good comparison) and extensively driven many times a 997 GT3, a 991 GTS and a 992 Carrera (I am lucky with my friends' cars!) and found all of them like apples to oranges vs my 458, in terms of throttle response.
    Thanks for having replied to me: the fact that you, and possibly many others, find Porsche's and the 458 the same throttle wise, and the 458 in particular "normal", is surprising to me and, as said, interesting.
  20. simmadwn
    simmadwn Formula Junior
    Jun 10, 2016
    331
    San Mateo, CA
    James
    hi Justin - try reaching out to Shiv at https://www.openflashtablet.com/ ...he can definitely help you with that. I did it on my 458 and no jerkiness..good luck!!
    James
  21. I don't find the throttle to be twitchy -- either in the 488 or Pista.
    But damn, the brakes are way too grabby.
  22. lamborarri
    lamborarri Formula Junior
    Nov 15, 2015
    452
    I have driven and had many 458's from 10-15. I would say a good 30% chance of them were jerky and touchy on the throttle. They did get better after I drove it or completely gone. Not right away tho.
  23. ridege55
    ridege55 Formula 3
    1,385
    Manhattan Beach, CA
    Mine is a 2013 and definitely has that jerkiness. It's more noticeable in Race mode.
  24. Live2win
    Live2win Karting
    Sep 27, 2019
    177
    Pasadena MD
    David perkins
    5000 miles on my 2010 458, all in the last 5 months. At first I this gas pedal is so sensitive, after 1000 miles I got used to it. Now I can play with the pedal to get the pop and crackel on downshifts .
    drive the car , become one with the car can not due just driving on weekends . Once you do there is nothing better. You slip into the drivers seat and say ok let’s go this, the prancing pony with fo what you ask!!!!!It takes time to understand this car
  25. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    Agree Porsche's and Ferrari's throttle characteristics are indeed like comparing apples to oranges. Why certain others are unable to differentiate between these two is quite interesting indeed! Porsche's throttle being sharp, smooth, with precision modulation vs Ferrari which is basically the exact opposite in many ways. Thankfully Pista only has seen work in that area and now has only faint remains of this annoying trait. I found in 488 the jerkiness could never be overcome no matter how familiar or how much time was spent driving it. The throttle in that car was always a super fine balancing act between on and off in a bid to escape the kicking and bucking. It also had a negative effect by unbalancing the chassis in the corners particularly during fast on off throttle to brake applications. It would be nice to say one can work around it but I never could rid it properly and i sure tried.
