The rejuvenation of # 02986 | Page 12 | FerrariChat
Discussion in '206/246' started by Skippr1999, Mar 20, 2017.
  1. Skippr1999
    Skippr1999 F1 Rookie
    4,495
    Image Unavailable, Please Login Image Unavailable, Please Login When you look at the rough condition of this old water pump that still works, I can’t help thinking about all the newer water pumps that routinely fail. They made things so much better way back when....
    The corrosion on the thermostat housing and water flow parts is significant enough that I’m replacing those parts too.
    Another order placed with Dinoparts
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #278 synchro, Oct 26, 2019
    Keep it. Just in case.
    Your photos show a great reason to change the coolant annually including a Water Pump lubrication package. Again, I have never heard of the Dino water pump being an achilles heal
    (in my Maserati Bora it was though)
    Do the new castings have the same Dino production numbers in them?
    Several folks go to Tom Shaughnessy's parts bin for good used OEM
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Skippr1999 likes this.
  4. Skippr1999
    4,495
    Apparently I’m not “in the know”. I ordered repros from Dino parts. As always, I keep the oem parts. My objective has been to keep the car as original and true as possible, but make all the systems reliable and functional.
  5. racerboy9
    racerboy9 F1 Rookie
    2,637
    You could have all those pits welded up and filed down if you wanted to preserve the part.
    Ken Ivey likes this.
  6. Skippr1999
    4,495
    Thanks for the suggestion. I’ll definitely keep the parts so that could be done in the future. At the moment, I’m just going to fit new parts and get her back on the road.
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    mine was the same and it fell apart, the oxidation was to far gone to weld.
    Best to replace as you will always be looking over shoulder waiting for a plume of water !!
  8. Skippr1999
    4,495
    I hear that ! I want confidence in the car and driving enjoyment. The concourse trophies can be for someone else. Although I do strive for “correctness” where possible.
    DinoLasse and qvee like this.
  9. Neelfryer
    Neelfryer Formula Junior
    Jan 11, 2017
    344
    Beverly Hills
    Skip - looks great - I still want to send you my car for a month or two .. lol - John
  10. Skippr1999
    4,495
    Thanks John. That would be great. Drop ship her on over to escape the fires and I’ll promise a really thorough Italian Tune-up!
  11. Skippr1999
    4,495
    #289 Skippr1999, Oct 31, 2019
  12. Skippr1999
    4,495
  13. Skippr1999
    4,495
    While doing the water pump, I’m going to go ahead and replace both long coolant hoses and heater bypass hose. Might as well have a totally fresh and reliable cooling system.
    NYC Fred likes this.
  14. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Fiddly but relatively easy job to replace the seals, check the pre load to the bearings are in spec while you are there.
    If out of spec then you may need to replace the shim plate thickness accordingly.
    tony
  15. Skippr1999
    4,495
    Thanks Tony
  16. Skippr1999
    4,495
  17. Skippr1999
    4,495
  18. racerboy9
    racerboy9 F1 Rookie
    2,637
    I had some of those made up in stainless. They usually are pretty corroded.
