The rejuvenation of # 02986 | FerrariChat
Discussion in '206/246' started by Skippr1999, Mar 20, 2017.
  1. Skippr1999
    Skippr1999 F1 Rookie
    4,209
    Late last year I started my quest for a Dino. I was looking for a well preserved example that had been loved and cared for through the years which would not need a full restoration.
    By reaching out to this Forum, I was able to purchase a two owner, mostly original car.
    Over the past couple months I've spent approx, 150 hours improving the car and raising it to a higher level. I'd like to share the progress so far.
  2. Skippr1999
    4,209
    #2 Skippr1999, Mar 20, 2017
  3. Skippr1999
    4,209
    #3 Skippr1999, Mar 20, 2017
  4. Skippr1999
    4,209
    #5 Skippr1999, Mar 20, 2017
    Next came fluid changes, which leads to the next set of obstacles.
    The gearbox fill plug was seized. A torch, penetrant, and impact wrench did nothing but strip the nut. A friend finally got it out with a chisel and hammer by extracting the washer first. I'm sure this had something to do with the aweful color gear oil.
  5. Skippr1999
    4,209
    #6 Skippr1999, Mar 20, 2017
  6. Skippr1999
    4,209
    #7 Skippr1999, Mar 20, 2017
    With clean gear oil, I moved on the coolant, motor oil, and brake fluid. Coolant and oil went perfectly, but while changing a rubber brake line, a metal brake line was twisted in half.
    To get to the brake line junction, the heat shield separating the trunk from the engine had to be removed. Many screws and rivets later, it was out ! But, the heat shield was corroded in some places. So, the next repair was made.
  7. Skippr1999
    4,209
  8. Skippr1999
    4,209
    #9 Skippr1999, Mar 20, 2017
  9. Skippr1999
    4,209
    #10 Skippr1999, Mar 20, 2017
  10. Skippr1999
    4,209
    #11 Skippr1999, Mar 20, 2017
  11. Skippr1999
    4,209
  12. Skippr1999
    4,209
    #14 Skippr1999, Mar 20, 2017
    One thing I hated was the aftermarket side mirror. Luckily the original was included, but I had to open up the old screw hole which had been filled when the car got painted in 1978.
  13. Skippr1999
    4,209
  14. Skippr1999
    4,209
    #16 Skippr1999, Mar 20, 2017
    BoxerCrazy likes this.
  15. Skippr1999
    4,209
    #17 Skippr1999, Mar 20, 2017
  16. Skippr1999
    4,209
  17. Skippr1999
    4,209
    #19 Skippr1999, Mar 20, 2017
  18. Skippr1999
    4,209
    #20 Skippr1999, Mar 20, 2017
  19. Skippr1999
    4,209
  20. Skippr1999
    4,209
    #22 Skippr1999, Mar 20, 2017
  21. Skippr1999
    4,209
    #23 Skippr1999, Mar 20, 2017
