Steam Power??? | FerrariChat
Steam Power???
Discussion in 'Aviation Chat' started by Bob Zambelli, Jan 4, 2020.
  1. Bob Zambelli
    Bob Zambelli F1 Rookie
    Nov 3, 2003
    3,498
    Manning, SC
    Robert G. Zambelli
    Interesting to say the least!
    energy88 likes this.
  2. energy88
    energy88 Two Time F1 World Champ
    27,189
    West of Fredericksburg, VA
  3. jcurry
    21,600
    In the past
    Jim
    Read up on Hiram Maxim.
  4. Gatorrari
    Gatorrari F1 World Champ
    15,944
    Georgia
    Jim Pernikoff
  5. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    7,917
    Shoreline,Washington
    Robert Parks
    While I was an instructor I invited a guest instructor/expert to class to explain the operation of a gas turbine/ jet engine. He woke the class up with a loud and clean explanation. " Well, it's pretty simple. SUCK, SQUEEZE, BANG, BLOW ." We then broke down the four basic elements with diagrams of a gas turbine and we were off running.
  6. jcurry
    21,600
    In the past
    Jim
    While I understand the explanation with regards to a gas turbine, I think it is more appropriately applied to an ICE.
  7. Gatorrari
    15,944
    Georgia
    Jim Pernikoff
    If someone wore a t-shirt that just said "Suck, Squeeze, Bang, Blow", they'd probably get arrested!:D
    tritone likes this.
  8. Rifledriver
    34,138
    Austin TX
    A gas turbine is defined as a continuous combustion internal combustion engine while piston and rotary engines are defined as intermittent combustion internal combustion engines.
    I have heard suck squeeze bang blow applied to both and can't find fault with it. Its how they work.
  9. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    Absolutely, Same physics apply to the ram jet and pulse jet, just different methods to make it work.
  10. jcurry
    21,600
    In the past
    Jim
    It wouldn’t be called a ram jet if it sucked;)
  11. Rifledriver
    34,138
    Austin TX
    Now thats funny.
  12. tazandjan
    38,087
    Unless it is a turboramjet like the J-58 was incorrectly called.
    Note one big problem with steam power is the weight of the water for aviation applications.
  13. Rifledriver
    34,138
    Austin TX
    Nearing the end of steam car development they were trapping the exhaust and recondensing and reusing it. Steam engines go through so much water, recycling it would make the weight issue less of an issue. Still I agree steam, as much as I like aspects of it isn't practical for aviation.
    Howard Hughes had an engineer make him a steam car in anticipation of production for sale. He set a bunch of parameters in terms of range, time required to get a head of pressure etc. so that it could be viable transportation. The guy succeeded and built a prototype. Howard drove it and loved it. He asked some direct questions how various needs were met. Turns out the entire body work was a disguised condenser. Howard saw the danger of that and had the car destroyed.
    Have a look sometime at the late production Dobles. Quite the automobile.
  14. ixlr8
    ixlr8 Formula Junior
    Aug 24, 2015
    303
    Eastern Shore- Virginia
    Jim
    Jay Leno has several Dobles, I stumbled across a few interesting U-tube video's he did on the car/engine/boiler. I think he said the engine, when starting from a stop, could produce about 1000 lb-ft of torque. It needed to as that car weighted about 4000 lbs.
  15. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,775
    IgnoranteWest
    All this reminds me of an internet detour through automotive subcultures spawned from those crass Chevy window stickers that said
    "Chevy:
    Eatin Fords,
    ****tin Rams"
    And my submission was:
    "White Steam Cars:
    Eatin Dobles,
    ****tin Stanleys"
  16. Gatorrari
    15,944
    Georgia
    Jim Pernikoff
    In around 1924, the Lima Locomotive Works developed a system like that for steam locomotives that became standard on most of the late-model steamers. They called it "superpower" but I don't really know how it works; all I know is that it was compared to turbocharging on piston engines and afterburning on jet engines, because all three systems re-use exhaust gases in some form. It required a larger firebox, which in turn required four wheels at the back of the locomotive, behind the big drive wheels. The 4-8-4 wheel arrangement, using superpower, was typical of all the late-model fast steam locomotives that pulled the railroads' crack passenger trains until replaced by diesel-electric streamliners. Most of the larger steam locomotives operating on excursion trains today are of this type.
  17. donv
    donv Two Time F1 World Champ
    24,106
    Portland, Oregon
    Don
    I knew Hughes had a Doble, but I didn't know he tried to build his own car. Bill Lear also tried to build a successful steam car in the late 1960s.
    The Dobles are simply amazing cars, even today. At one point, I really wanted one-- until I listened to Jay Leno talk about what he has to do to keep his running.
