Starting from hot 246GTS | FerrariChat
Discussion in '206/246' started by Bobj, Jun 7, 2015.
  1. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    My car always starts from cold - never had an issues, no matter how long it is left
    A couple of times recently however I have stopped for 5 mins after running it for 20-30 mins (e.g. getting petrol) and it had trouble restarting. It did start after letting it cool but obviously this is annoying. Any ideas?
  2. Chairs and Flares
    Nov 15, 2011
    41
    Missouri
    Michael
    There are many threads on hot starts you might want to review. It seems that everyone has a "procedure" for hot starts; you're not the only one who has experienced a problem. I find that letting the fuel pumps work for several seconds and then depressing the throttle about 1/3 to 1/2 while cranking usually does it. Good luck.
  3. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    Switch to a gear reduction starter, no more problems!
  4. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    Thanks!
    Sorry what is a gear reduction starter?
  5. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,325
    Iain
    A gear reduction starter will greatly reduce the effort required to turn the engine over. The original factory unit draws a huge current and turns over very slowly. During a hot start it is quite easy to quickly drain the battery if you are not careful with the factory set up. A gear reduction starter plus a new alternator with inbuilt regulator will be like a breath of fresh air.
    These people can supply a unit suitable for the 246 and I've used them on all my cars Starter Motors - WOSPerformance There are other similar solutions out there, especially from the US but by the time you factor in import duty etc they often work out to be more costly.
  6. LARRYH
    LARRYH F1 Veteran
    9,625
    virginia usa
    A few years ago I had the same issue and switched to a gear reduction starter works great now ..
  7. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    Great thanks, I don't get the impression that it's not starting because it's not turning over fast enough or that the battery is drained. On the occasions the issue occurred, after I let it cool it was fine. I assumed it was a problem with the carbs, maybe vaporising the fuel?
  8. dm_n_stuff
    Dec 10, 2003
    43,692
    26.806311,-81.755805
    Dave M.
    vapor lock is a possibility, especially if letting the car cool helps. Sooo . . . leave the engine compartment open to cool faster when you're stopped, or, do the 1/3 to 1/2 depressed gas pedal.
    And, add a gear reduction starter. The added rpms, plus less drain on the batter greatly aids in the starting process.
    Certainly you can get by without one, but yours, if original, is creeping up on 45 years old and may need a rebuild, or to be replaced to optimize your starting.
    D
  9. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Correct, the fuel bowls are directly above the engine especially the one over the thermostat housing. It evaporates very quickly in these circumstances.
    In my opinion the way the engine fuel system is designed it should be self venting and no vapour lock issues should occur.
    for me its a starting technique and always has been. The GR starter is a good option and greatly assists in engine turnover and less drain on the battery. It all helps but isn't a 100% cure
  10. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    Great thanks guys, I checked and they aren't particularly expensive so, as you say anything that helps is better than an embarrassing hour kerbside
    Any particular brand or supplier you would recommend (I'm based in the UK). Is it something I could fit myself?
  11. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    The Dino has a continuous flow fuel system short of the last bit of line to the carb, so letting the fuel pump run before trying to start should help because at least the fuel in the crossover line will be cool.
    I also open the engine cover after stopping so I don't get so much heat soak, as dm_n_stuff suggested.
  12. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    I think it also helps to keep the tank topped up; circulating a small volume of fuel doesn't help.
  13. NYC123
    NYC123 Formula Junior
    Jul 15, 2006
    466
    when I had my dino I remember I had a different procedure for starting warm vs cold. Once I learned this procedure it was never a problem. The only problem is I don't remember what that procedure was !
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    What ignition system are you using?
    The stock AEC-103A Marelli perhaps?
  15. Mark Shannon
    Mark Shannon Formula 3
    1,236
    Surrey, UK
    #15 Mark Shannon, Jun 9, 2015
  16. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,797
    Southern California
    As some of you that have read posts from me about my ignition system in the past knew about the issues I had. We rebuilt the ignition back to complete stock including an NOS S125BX Marelli distributor and Winterburn CD ignition unit (I love this unit. I can't say enough good things about it. It is effectively a new Dinoplex without the issues. Truly a plug and play replacement and designed for a points system). We also installed iridium NGK spark plugs as per Corbani's recommendations. We rebuilt the DCNF Weber carbs. Since then I have had fantastic immediate start ups from cold (even after sitting a couple of weeks), straight to unassisted idle. When driven in Calfornia heat, it has no problem restarting when hot. I find that putting the gas to the floor really helps on hot restarts but doesn't really need it but is good insurance to not flood the motor. I mention this only because my experience has been great with a stock points ignition system. With the iridium plugs it has never fouled.
    Freeman
  17. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    Great thanks! will try that! I don't know what starter it has (the car is at our weekend place at the moment) but it doesn't have a choke - (unless I've managed to not notice that in the 15 years I have owned it - which is unlikely but not impossible...)
    I usually try to keep not very much fuel in it as I don't use it that much and I don't like the idea of running it on old fuel so I try and fill it with fresh stuff when I drive it
  18. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,797
    Southern California
    There are some people on this board that have a lot of experience with the DCNF carbs such as Rob Calisi. Since we rebuilt my carbs I never use any choke (not hooked up). In the past, before the carb and ignition rebuilds, I had to use the choke to start it but we found that it was some clogged idle jets. Normally you shouldn't have to use the choke. Now my Dino goes straight to a smooth 700RPM on start up cold or hot. If your Dino is stock with points, my suggestion is to get your Dino to start up and run correctly with the stock components before changing anything as a baseline. I am by no means an expert. I speak from my own personal experience with my Dino working on it myself with my friends that I trust.
    Freeman
    P.S. If your car goes long periods between driving I would put in a fuel stabilizer or racing fuel. Racing fuel doesn't get old and varnish like normal fuel.
  19. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,634
    Toronto / SoCal
    Rob C.
    Thank you Freeman for the vote of confidence but my experience has come from a very systematic approach of trying to understand how each component in the fuel delivery system works and how its operation contributes to the bigger picture of fueling the engine.
    In the case of the Dino I don't really buy the theory that the carbs overheat and that the fuel bowls evaporate empty. While this may physically happen, it is good practice to turn the key until the fuel pumps run and you can normally hear a change of sound when the carbs are full. Once the carbs are full a cold engine normally needs a bit of a priming which is achieved through a few pumps of the throttle to get some raw fuel into the intake via the accelerator pump. When hot, the engine will need less fuel so opening the throttle part or full without pumping is the way to go. The first opening will squirt fuel in (unavoidable because of the accelerator pump) but then as the engine turns over it will draw mainly air until it fires.
    This is not a Honda where you just turn the key and go. Starting one of these cars has a certain sense of occasion and it is to be savored. Understanding what the engine needs when it is hot or cold makes a big difference to avoiding problems with starting.
  20. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Here is how I installed mine, the photos show you how compact the gear reduction starter is
    http://www.ferrarichat.com/forum/206-246/265858-dino-diy-replacing-starter-gear-reduction-unit.html
    Ignition needs three things; fuel, O2 and spark
    While fuel is an easy path to go down many times the Dino's weak spark can produce similar problems which is why I asked about your ignition system.
    Are you running a stock Marelli box?
    I have two Dinos; one with and MSD and one with an original AEC103A which failed after a few years and replaced by Permatune, which was not much better. The MSD has had absolutely no starting issues in 10 years of ownership and it really doesn't care which type of spark plugs I use (copper/platinum, Bosch/NGK). The AEC103A and the Permatune can be finicky in hot start situations.
  21. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    Thanks, I have changed the plugs a few times and it generally seems to start much better with new plugs (currently it has ngk iridium I think) but the do seem to get black and tarnished very quickly even when it seems to be in a good state of tune
    I keep meaning to clean the old ones and swap them back but I can never be bothered
  22. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    In my opinion for what its worth is the Iridium plugs are no good for the Dino or it depends solely what ignition system you are using. Some swear by them so it seems they are not the definitive answer to plug fouling.
    Certainly with my set up these plugs are useless, standard NGKBP7ES are perfect.
    Recent re-jetting of the carbs have transformed the car considerably as the dino wasn't designed for the modern fuels we get today.
