SQUEEKY BRAKES driving me crazy | FerrariChat
Discussion in 'California/Portofino/Roma' started by Nick.C, Jun 29, 2020.
  1. Nick.C
    Nick.C Rookie
    Oct 14, 2019
    25
    nicholas chatburn
    Hi all..
    ok so last Time I posted about this, it was suggested new pads.
    bought brand new pads.
    Cooper greased them up. Even got the brake fluid bled and upgraded.
    by the way, this brake bleed Improved brake pedal feel, Massively
    Went from spongy to responsive and progressive. As it should be..
    however, I cannot get rid of light pedal braking squeal. I have stripped down the brakes several times now trying to cure it. Without success.
    Only time they stop squealing is when you really, really use them hard. but soon as they cool down a bit the squeaky returns.
    I suspect this is an expansion issue.
    would backing plates solve it ?
    it has been strongly suggested to me the carbon discs are at fault. Not worn as such, but maybe contaminated.
    amd I should swap to steel rotors.
    Which I quite liked the thought of.
    a lot cheaper I assume and I can save the CC for When the time comes to sell...
    along with a squeaky brake solution, does anyone know where I can buy steel rotors?OR
    backing plates for the pads.?
    eurospares don’t do them...
    Looking forward to hearing from you...
    Nick
  2. russellmcg
    russellmcg Formula Junior
    Aug 3, 2014
    479
    Houston
    Russell McGuire
    I have the same problem as you. I just purchased my 2011 California this weekend, but so far, the brakes squeak like crazy at low-speed stopping. I have yet tried to bed them, but hopefully, that solves it.
    I will be following this thread to see if anyone has suggestions.
  3. vjd3
    vjd3 F1 Rookie
    2,582
    Massachusetts
    Vic
    Carbon ceramic brakes have very little dust, but on my 2013 California 30, they would squeak from time to time. I found that rinsing the brakes (when they were cool) with water would cure the problem, for a while, until they got dirty again and they would squeak. You want to be very careful about using any sort of wheel cleaner on these brakes, last thing you want to do is damage those rotors, they cost a fortune.
    On my Cali T, the brakes never seem to squeak.
    SAFE4NOW likes this.
  4. Mafiaboy1975
    Mafiaboy1975 Formula Junior
    Aug 10, 2019
    258
    South Africa
    Mick
    CCM brakes squeak. Basically the trade off of low dust and light weight rotors.
    Try a few I speed stops to transfer some pad to the rotor. That helps sometimes.
    My real advice. Just get used to the squeak. Not much else you can do.
  5. Nick.C
    Nick.C Rookie
    Oct 14, 2019
    25
    nicholas chatburn
    Thanks guys...
    going to try the washing down method
    the high speed stops does not really work. Soon as they cool down, they squeak again.
    anyone use backing plates ?
  6. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    Fresh water rinse (when cool) is the only thing I have found to help. I use a regular garden hose with a jet nozzle. It seems to last a couple of days. I daily drive close to 500 miles per week.
    SAFE4NOW and Nick.C like this.
  7. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    744
    Nashville/Destin
    Steve
    Brakes are silent on my Cali T ?
    Did they make a change in the system or pads?
  8. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,899
    DFW, Texas
    Tom C
    Can someone please make a video of this squeaking.
    I read about it all the time. How loud/persistent is it?
    I get a little squeak from time to time, but nothing that would "drive me crazy."
    Full disclosure, I am a bit hard of hearing! :D
    T
    Nick.C likes this.
  9. russellmcg
    Aug 3, 2014
    479
    Houston
    Russell McGuire
    Steve had recommended putting some water on it and I just tried this. Pulled the car out with the brakes cold, washed them down with a hose, and then took it for a drive. Worked like a charm! No squeaking at all! Not sure how long it will last for but worth giving it a go.
    Mine was pretty noticeable. Enough where it was somewhat embarrassing as you pulled up to a stoplight.
    Nick.C and tomc like this.
  10. Nick.C
    Nick.C Rookie
    Oct 14, 2019
    25
    nicholas chatburn
    I will later today
    tomc likes this.
  11. Nick.C
    Nick.C Rookie
    Oct 14, 2019
    25
    nicholas chatburn
    Same here... very embarrassing. People keep asking what’s wrong with the car
  12. russellmcg
    Aug 3, 2014
    479
    Houston
    Russell McGuire
    Give the water method a go and hopefully it will help.
  13. Nick.C
    Nick.C Rookie
    Oct 14, 2019
    25
    nicholas chatburn
    Ok..
    so, the water method worked !!!
    amazing. Thanks.
    however, only for a day. After about 50 miles it came back.
    Maybe become I could only wet the outside of the discs and pads down. maybe if a reach both sides that would help...
    Makes me wonder if it’s dodgy Pad material or Contaminated ?
    not had chance to do the video yet though
  14. tomc
    Apr 13, 2014
    25,899
    DFW, Texas
    Tom C
    Partial success! The "squeaky brakes" complaint seems to pop up so often here and in so many different models that it has to be intrinsic to the carbon brakes that F uses. At least that's my guess.
    T
  15. XSpeed
    XSpeed Formula Junior
    Jan 6, 2019
    408
    SX
    either you get used to it or you get crazy. i did bedding and stops at every speed including 300 to 100. goes away for a while, then comes back.
    porsche had a video basically saying there is no cure.
  16. vjd3
    vjd3 F1 Rookie
    2,582
    Massachusetts
    Vic
    As I mentioned, my 2013 Cali 30 was prone to it, but it would go away (for a while) if I rinsed the brakes.
    My 2015 Cali T does not squeal at all and never has ... I keep the car garaged and only drive it in fair weather with waterless washes, so there are definitely plenty of miles on the brakes without rinsing and they have been fine. Perhaps they did make a change for the T.
  17. tomc
    Apr 13, 2014
    25,899
    DFW, Texas
    Tom C
    LOL. I suspect they made this video to send to dealerships, so that way when trophy wife/husband comes in to complain about brake squeal on their Porsche, they can show them the video and say "Sorry folks, our egghead scientists say break squeal is like COVID-19, no known cure!" ;)
    T
  18. vjd3
    vjd3 F1 Rookie
    2,582
    Massachusetts
    Vic
    Such a polite squeal from those Porsche brakes!
  19. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I dont know what changes to the brake system Ferrari did from Cali to Cali T but my car is a 2016 Cali T and it has Zero squeak.
    Completely silent.
