So may connectors, so much confusion | FerrariChat
Discussion in 'Boxers/TR/M' started by JIMBO, Nov 5, 2019.
  1. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    As I am re-assembling the 512TR engine, I have run into a dilemma. There are 3 temperature senders in the coolant system. One is on each aluminum tube under the intake manifold and the 3rd is at the junction where the two tubes meet. All 3 sensors have identical 2 pin electrical connectors (see photos). The connector on the RH side is by itself and goes to the sensor on the RH tube, but the other two connectors exit the wiring harness at almost the same spot, so which one goes to the tube and which one goes to the junction? Does it matter at all? All 3 sensors are only a few inches apart. Any help would be appreciated. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    One is for the gauge on the dash, the middle one. The other two are for each ECU to know the temp of each bank. If you jump the two terminals and turn on the key see if the temp gauge maxes out. Thats the one that goes on the the center sensor. Jumping the terminals will do no harm so dont worry about hurting anything.
    turbo-joe likes this.
  3. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    Honestly it wouldn't make a difference to how the car runs if they were mixed up but if you want it right the middle one is for the dash gauge.
  4. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Thanks. The engine is currently on a stand, but once it's back in I will do as you suggest.
  5. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    How much difference can there be from 2 sensors 4 inches apart in the same coolant path?
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    it is not about the difference. it is because each ECU needs a sensor and also the instrument inside needs one
  7. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    There wont be a difference but since they chose to run two ECU's they had to have two of everything, crazy really.
  8. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    so very Ferrari
