sneaky door pin!! | FerrariChat
sneaky door pin!!
Discussion in '308/328' started by albert_k, Dec 23, 2019.
  1. albert_k
    albert_k Rookie
    Nov 20, 2019
    36
    Albert Khasky
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    It will get a bit cold when the door falls off- then go back down the road 80 yards and pick up the pin
  3. albert_k
    albert_k Rookie
    Nov 20, 2019
    36
    Albert Khasky
    or i could just tie a string to it and drag it along?
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Consider yourself lucky. If it slips right down again, leave it be.
    The rest of us normal people, the pins refuse to come out even at the biggest hammer is applied. I almost lost that battle and even though I won in the end, I would never want to fight that one again.
  5. Martin308GTB
    Martin308GTB F1 Rookie
    4,231
    Black Forest Germany
    Martin N.
    #5 Martin308GTB, Dec 24, 2019
    Push it back and add circlip like on the other two pins, which are installed upside down.
    Best
    Martin
    Crowndog likes this.
  6. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Hit it with the grease gun first - might make it an easier job
  7. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    I think you have already a stainless pin here....lucky you. Like said above put a grease gun and push it back in place.
    Guido
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
    Might be a good idea to lube the pins.
  9. Martin308GTB
    4,231
    Martin N.
    Except, that they don't rust, I don't think, that stainless is a good idea for such an application. Too soft. If not permanently lubricated, they will wear faster than the stock highgrade steel pins. If lubricated well, the stock pins won't rust solid. I hit mine with the grease gun once in two years. No problems.
    Except the upper pin on the driver's side, which meanwhile shows a little bit of play. I hope, it's the pin, which is worn and not the hinge bores. I have new ones on my shelf since years, but I cringe, when thinking about doing the job :)
    Best
    Martin
  10. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,257
    Montana
    Kim
    #10 308 milano, Dec 25, 2019
    You will be AMAZED at how many profanities you can string together in a sentence!
    :) Bottom pin, not bad at all but the top Pin is another story. Was able to put a nice chip in the edge of the front fender. Took a month of letting touch up paint dry then reapplying and light polish to fix.
  11. Martin308GTB
    4,231
    Martin N.
    Now, that I read it once more..... :)
    Sorry for this on Christmas.
    Best
    Martin
  12. albert_k
    albert_k Rookie
    Nov 20, 2019
    36
    Albert Khasky
    It easily tapped back in place… Not sure if that is a good or a bad thing… Curious though what makes you think it’s stainless as I have no way of telling
  13. theunissenguido
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    http://www.superformance.co.uk/308/body.html see door hinge pin. Was stainless in the past. When looking at the picture, looks normal steel to me now.
    Did they change the metal in the mean time ?
    Guido
  14. Martin308GTB
    4,231
    Martin N.
    Maranello Concessionaires always supplied high grade steel.
    Maybe Superformance accepted the fact, that stainless is too soft for this application.
    But SF is no reference for me anyway.
    Best
    Martin
