Smog check help | FerrariChat
Smog check help
Discussion in 'California (Southern)' started by fullmonty, Feb 2, 2021.
  1. fullmonty
    fullmonty Formula Junior
    264
    LALAland
    Mel
    Looking for help, am located in West Los Angeles, the shop I used to go to for service closed due to the owners unfortunate medical situation. my 97' is showing a check engine light, needs a smog check this month at a Star station, has fabspeed exhuast and Tubi. Thank you. Mel
    miketuason likes this.
  2. fatbillybob
    Aug 10, 2002
    28,909
    socal
    You are screwed. You already fail if fabspeed headers. Contact Plugzit. He might have parts to swap out for smog testing and be willing to do the swap if he has time. He is pretty busy.
  3. kartboy1234
    kartboy1234 Formula Junior
    Nov 10, 2014
    723
    Palos Verdes, CA
    Michael L
    If the check engine light wasn't on the you'd probably get away with it. But the check engine light changes everything
    Sent from my GM1917 using Tapatalk
  4. msark
    msark Formula Junior
    Feb 18, 2017
    284
    Southern California
    Have you used an OBD reader to see what caused the light?
  5. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,201
    Beverly Hills, CA
    Jay
    have Karl at Black horse on Robertson and reset it, see if it comes back on
  6. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,675
    Los Angeles
    Ferrari-tech
    Depending on the fault ( could be numerous things) if you can clear the light and set the monitors, aftermarket exhaust etc. shouldn't be a problem as most smog shops don't know what stock looks like.
  7. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    Once you get the check engine light fixed, go to KCM SMOG in Carson, he does not care what exhaust system you have, nor would he know the difference, as long as your car passes the threshold, your good, my car passes no problem 89 328, Tubi exhaust. He may or may not put your car on the dyno drum, mine has to be on the drum in order to pass. Good luck,
    Thank you
  8. turbolou
    turbolou Rookie
    Jan 24, 2012
    39
    Lake Forest California
    Lou Czarnota
    What you have said here publicly could cause that smog station to lose their license & a hefty fine. Lets hope some smog Nazi doesn't read this.
  9. ginoBBi512
    3,535
    SO CAL
    GINO RUGGIERO
    I did not think of that, highly unlikely, but maybe you can have the mods remove it for me, he smogs my car every 2 years, never had a problem, the cars either pass or they dont.
    Thank you
