Seat belts stuck ? ABS BRAKE RELATED? | FerrariChat
Discussion in 'Mondial' started by sonfield, Dec 16, 2019.
  1. sonfield
    sonfield Karting
    Jul 17, 2008
    101
    Florence, SC
    I know I previously posted this but someone said maybe there’s a fuse or something related to the ABS braking system will explain why both front seat seatbelts will not release. Does anyone have experience with this
  2. JimboMondial
    JimboMondial Karting
    Dec 26, 2005
    73
    Portsmouth UK
    Jim
    my 88 uk abs mondial doesn't have any link to the seatbelts.
    Jim
    Sent from my Lenovo YT3-X50F using Tapatalk
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
    Why would it be linked at ABS system ?
  4. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    I've never seen any link between those and the ABS. The seat belts might be locked because they retracted too far. When that has happened, it's pretty easy to get them out: pull and release the belt from the spindle very fast and it will come out cm per cm. This might take a while, but you'll get there. 5 pulls a second and it will slowly come out more and more, but make sure the centimeters won't get back in :)
  5. ronfrohock
    ronfrohock F1 Rookie
    4,150
    MA
    Ron Frohock
    I found that I needed to pull it out very slow. I pulled as much belt out as possible, got a can of WD40 with a straw and a flash light and lubed the latch mechanism. Then carefully retracted the belt making sure it went back in straight. All has been fine since.
    gsfent likes this.
  6. djs308
    djs308 Formula 3
    1,131
    Long Island, NY
    David S.
    You were able to do that without removing the belt mechanism cover?
  7. ronfrohock
    4,150
    MA
    Ron Frohock
    Yup. Would have been better I’d I removed the cover but I was able to get it done with a flash light and a straw.
    djs308 likes this.
  8. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Thanks Ron. Having similar issues where the belt was just about completely locked up.
    Sprayed some WD40 from the top and removed the side panel against the door and sprayed down from there (no flashlight). It helped a bunch!!!
    Pulling the belt straight up and slightly to the rear seemed to free it up the most. I will do a few more pulls over the weekend and perhaps another light spray. But it is now very operational, so I can drive LEGALLY again! :)
    Regards,
    Jerry
  9. Alden
    Alden F1 Rookie
    3,544
    Central Florida
    Mine was doing the same thing, using silicone spray, pulled it all the way out, slowly, found a kink in the belt. Lubed the mechanism from the top with straw and flashlight, with the belt fully retracted per Ron. All is good now. Did not remove any covers, just loosened the side cover enough so I could pull it to the side to get some clearance so I could see what I was doing.
    Make sure you have the belt pulled all the way out, stuff some paper towels in the bottom of the cavity to catch any excess, you can remove the towels after a while with a long reach grabber tool. Don't want to get silicone all over your belts!
    Alden
  10. djs308
    djs308 Formula 3
    1,131
    Long Island, NY
    David S.
    I'd really like to give this a shot. Where is the cover actually attached? What's the easiest way to loosen it with out actually removing the thing (which I really would like to avoid)?
  11. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    I was referring to a side panel, which is under the window. It just came off with finger pressure at the front. I think there is a little clip, I didn't pay too much attention.
    Regards,
    Jerry
