RH Spider fuel pump leaking - Bosch source? | FerrariChat
Discussion in '360/430' started by DanNE, Jun 4, 2020.
  1. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    658
    Hello, I smelled gas in the car (2003 Spider) and the RH pump has gas leaking on top. So the car is in the garage and I'm looking for a fuel pump.
    Does anybody have the Bosch p/n for the RH pump? I saw 0580313088 as being a possible Bosch part number but haven't been able to confirm it on this site.
    Thank you!
  2. Fixjets777
    Fixjets777 Karting
    Oct 16, 2016
    96
    Treasure Coast, Florida
    Jeff
    I just replaced the right fuel pump on my 2007 F430 spider for the same reason. I bought part number 239811 RH Complete Fuel Pump and 181681 Pump Fastening Ring Nut Gasket (O-ring) from Scuderia Car Parts. They had the best price by far: fuel pump $320, o-ring $19.
  3. Fixjets777
    Fixjets777 Karting
    Oct 16, 2016
    96
    Jeff
  4. DanNE
    Jun 7, 2013
    658
    Thanks that's very helpful. The prices are quite good, are the parts labeled as Ferrari or Bosch? If Bosch pn then the cost should be around $140 from what I find...
  5. Fixjets777
    Fixjets777 Karting
    Oct 16, 2016
    96
    Jeff
    Pump came in genuine Ferrari packaging.
    DanNE likes this.
  6. DanNE
    Jun 7, 2013
    658
    The Bosch part number is:
    0580 313 088
    Or
    0580313088
    It's not available in the USA but in the UK it goes for about $140 USD plus shipping (which ran me another $20 or so).
    When I replaced this today I also checked the markings on the old pump which was leaking and it was the same number.
  7. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    Is there a cross reference part for the left pump with the fuel level sensor?
  8. DanNE
    Jun 7, 2013
    658
    I don't know because my left one was ok (not leaking) but I suspect it to be Bosch as well.
    Next time I tinker with the car I will check or if you have access to your left side pump take a picture of the top.
  9. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    Looks like the cross reference for the the left with the fuel sender is 0580313052
  10. DanNE
    Jun 7, 2013
    658
    Very nice find thank you!
    Would you guys replace it as a preventive measure? My left is not leaking but maybe why not?
  11. DanNE
    Jun 7, 2013
    658
    Quick note for 2003 Spider the Bosch PN I found on the original pump is 0580314061
  12. shad99
    shad99 Formula Junior
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
    At $150 for a new updated pump I sure would. I replaced the right pump and left one started leaking during testing of the right!
    BTW, I ordered a left pump from EBay and received the correct updated pump. It did not, however, included the tank level sensor. My existing sensor works fine so just a swap and good to go. Something to keep in mind when ordering the Bosch unit
    DanNE likes this.
  13. DanNE
    Jun 7, 2013
    658
    Which pump did you order for the left if you recall the part number? I took the number right off the old pump. I also could tell this side was never replaced because there are the factory check paint marks that are lined up on the cover ring. When I did the right side I found the same paint mark and there's no way to tighten back to the same mark :)
  14. shad99
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
    I ordered Bosch part# 0580313052. Interestingly, the picture shows the white plastic (old) version with the level sensor. The part received was the yellow polypropylene (updated) and no level sensor.
  15. DanNE
    Jun 7, 2013
    658
    Mine showed a slightly different number on the current pump and searching for the image of 0580314061 pulls up this picture which appears to be right (?)
    gsworld2014 likes this.
  16. jag-oo-r
    jag-oo-r Formula Junior
    424
    So, if I read this thread correctly, are these two bosch part numbers the left and right pumps? And do they fit both the 360 and 430? Coupe and spider?
    0580313052
    0580314061
    Sent from my SM-G970U using Tapatalk
  17. jag-oo-r
    424
    Dan, could you please share your source? My right side fuel pump is doing the famous leak. I'd like to get one ordered, and would love to have your source. Cheapest in finding is around $375 plus frt.
    Thanks!
  18. knocker
    knocker F1 World Champ
    Jul 10, 2017
    12,301
    Sydney Aus
    Adrian
    I bought my upgraded pumps from eurospares uk about $200 a side, if it’s a spider I hope you have the ports under the roof [emoji51]
    jag-oo-r likes this.
  19. jag-oo-r
    424
    I do indeed have the ports, thankfully! This is how I confirmed the leak last night. Right side only (for now), left-side was dry.
    I then cleaned it up really good, roughed-up the plastic, cleaned again with acetone and then slathered some JB Weld in it last night.
    I left the port cover off, so that I could inspect it after driving it, which I did this morning. 40-minute drive (mostly freeway). No moisture around the area whatsoever. I'm confident that'd hold for some time (but I'm ordering a replacement pump this morning).
    The smell of gasoline persists however. I'm guessing that the port-cover being off has everything to do with that, and that once today's sun moves some warm air through the area, and then I reinstall the cover, all will be back to normal. But in the back of my mind I keep thinking about the rollover-valve I read about. There is no question the pump was leaking, as they famously do. What's the likelihood I have a two-headed problem here? ;-)
    I'm looking at eurospares right now and they're 243eu, or about $290usd. Plus frt, of course, but this is cheaper than I had found previously, so thank you!
    I'm getting ready to pull that trigger, unless someone chimes-in in the next hour or so with a better source.
    Thank you all for your responses.
    Johnv10 likes this.
  20. knocker
    Jul 10, 2017
    12,301
    Sydney Aus
    Adrian
    #20 knocker, Sep 10, 2020
    Hi there, it was suggested that I replace the rollover valves at the same time as the pumps and I did so, apparently they deteriorate due to heat over time . I wouldn’t drive the car personally, replace the fuel pumps and rollover valves first mate .
    Apollo 11, jag-oo-r and EastMemphis like this.
  21. jag-oo-r
    424
    Thanks, everyone, for your responses.
    I've ordered the parts from EuroSpares.... no option for "Expedite"!!! hahaha. I'm anxious already. There are only so many good weather days left here.....
  22. PCarRI
    PCarRI Karting
    Feb 23, 2020
    221
    Rhode island, USA
    #22 PCarRI, Sep 11, 2020
    This is hilarious. I literally just yesterday ordered the fuel pumps from Eurospares as well!
    Was the LH fuel pump on back order for you too?
  23. PCarRI
    PCarRI Karting
    Feb 23, 2020
    221
    Rhode island, USA
    Incidentally I woke up to an email from them today saying they are shipping the parts out immediately! I asked them to take off the pump that was on backorder (who has the patience for that?!) and they did it right away. Very impressive service and prices, will undoubtedly buy from them again if the parts come in as expected.
  24. jag-oo-r
    424
    Mine allowed me to put it in the cart and checkout. But after ordering they told me that the LH was backordered.
  25. rkrkrk
    rkrkrk Karting
    96
    CT USA
    Bumping this. Eurospares seems to charge a bit of a premium for these. Any other reputable retailers in UK recommended?
