Repair of the Fake leather straps 458 trunk | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by docf, Dec 17, 2017.
  1. f355spider
    f355spider F1 World Champ
    18,043
    They look great, I think most concours judges would probably miss that they were not stock...as the difference is subtle.
  2. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    Took mine to local horse saddlery, was I think $25, used my oem buckles. Or as others have done a shoe repair shop.
  3. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    i hear tons of ppl getting these straps done at saddlery or shoe repair stores for like $20-40 for a set and reusing their original hardware but every time I call, the quotes I'm getting are like $1-200!
  4. docf
    docf Formula 3
    Sep 14, 2008
    1,414
    Florida
    Gary
    Tim I got mine back about 1 week ago from a Saddle shop here in Central Fl. for $31.00 for the 2 straps (black) 458 Italia. Did specify my own hardware. Replaced the rivets with #10-16 x1" Black Trim Screws (Dormins).
  5. Keith Darby
    Keith Darby Karting
    Nov 12, 2017
    103
    Keith W. Darby
    Any updates on the leather straps. I purchased the tool bag strap from Ricambi but now I need the other 2. (360) I have the old straps with hardware and could ship.
    Thanks,
    Keith Darby
  6. Keith Darby
    Keith Darby Karting
    Nov 12, 2017
    103
    Keith W. Darby
    Any updates on availability of the reproduction straps ? (360) I have all the hardware and deteriorated straps that I could send if that would help.
    Thanks,
    Keith
  7. velocegiallo
    velocegiallo Karting
    101
    California
    Ghostdiver likes this.
  8. TCfromUB
    TCfromUB Rookie
    Nov 20, 2013
    10
    How do you access behind the rivets after drilling them out? A bit confused on this. Straps on my 458 just broke, man that’s junky.
    CH_348 likes this.
  9. CH_348
    CH_348 Karting
    Nov 10, 2016
    66
    Zurich, Switzerland
    Chris Steinacker
    I am also wondering how to mount the new straps after having drilled out the old ones:
    Just ripped one of my straps and decided to also replace them with nice new, black leather straps.
    But before I get them out I’d really appreciate some Tipps on how to install them best.
    Thank you very much for letting me know how you guys managed to do that!
    Gesendet von iPhone mit Tapatalk
  10. Lovedriving
    Lovedriving Karting
    Jul 14, 2018
    108
    Toronto, Canada
    Eric D'Amours
    Resurrecting this thread...any tip on how to remove the rivets? Would a metric hex tool do the job?
  11. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    I used a drill bit slightly smaller than the shaft of the rivet. Drill out the center and they should come out.
    Lovedriving likes this.
  12. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
  13. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,420
    Santa Clarita, CA
    If you’re talking about the pop rivets, they are available in numerous sizes at any hardware store.
    If you’re talking about the rivets that hold the buckles in place, those can be installed at any shoe store.
  14. Lovedriving
    Lovedriving Karting
    Jul 14, 2018
    108
    Toronto, Canada
    Eric D'Amours
    Was talking about removing the rivers that hold the straps to the tub.
  15. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,420
    Santa Clarita, CA
    After you remove the panels inside the frunk, drill out the pop rivets with a slightly smaller drill that the rivet. You can go up one size drill if you need to. Then pull out the remainder of the rivet, from the backside, with a pair of flush dikes.
    The new rivet will fill in any irregularities in the hole.
  16. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    A strap just broke on my 458.
    I’ll drill out the old rivets and have new straps made. Can I use pop rivets to install the new straps, so I don’t have to take out the panels in the trunk? Are the panels in the trunk easy to remove?
    Advice much appreciated.
    Andres
  17. Circle K
    Circle K Karting
    Dec 21, 2017
    154
    KC
    Order online or go to local fabric store
  18. docf
    docf Formula 3
    Sep 14, 2008
    1,414
    Florida
    Gary
    You can find straps as noted above online. I went to a bridle (saddle shop) and had them made for me. I also removed the buckle etc from the original & had them sewn into the new straps. After removing the rivets I used self tapping screws and small washers to complete the job!
  19. lawteam
    lawteam Karting
    May 15, 2009
    74
    Palm Beach Gardens, FL
    Evan Fetterman
    BRIOSO likes this.
  20. abstamaria
    Feb 11, 2006
    2,668
    Andres
    How do you attach the new straps? Is it easy to get the trunk (boot) inner panels (a tub?) out in a 458?
    Andy
  21. RED HEAD
    RED HEAD Karting
    219
    London
    H
    I’d like to know too please
  22. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,867
    France
    It just broke in my 488 - I'm lazy so I attached the broken part on top of the remaining riveted one with a short wood screw; it results in a slightly shorter strap (not noticeable) and the "repair" is hidden by the pouch.
  23. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,437
    I had a batch made for my 599, I think they are all the same. Happy to give them away at what the cost me.
