Repair of the Fake leather straps 458 trunk | FerrariChat
Discussion in 'Technical Q&A' started by docf, Dec 17, 2017.
  1. docf
    docf Formula 3
    Sep 14, 2008
    1,352
    Florida
    Gary
    Can't believe Ferrari still using cheap fake leather straps in luggage compartment that secures tire compressor on one side & tools on the other side in the 458. They break without touching where the 2 rivet's on ea. side go through the strap onto trunk material.. Anyone know where to order real leather straps and can I just drill out the rivets and replace with some hex screws or tap for hex bolts.
    whatheheck likes this.
  2. virendra
    virendra Karting
    230
    Hong Kong
    virendra anand
    In 20 plus years they still can't fix the sticky interior. maybe they need to learn from the Germans or Japs about certain parts and technology, after all they do use DENSO / SANDEN for aircon condensors and alternators.
  3. virendra
    virendra Karting
    230
    Hong Kong
    virendra anand
    They break as they use a small dia rivet with a washer to secure a 4 cm wide strap that becomes brittle over time. I have seen a few cars with a rectangular stainless steel plate that has 2 holes to squeeze the strap between the body and the rivet.
  4. docf
    docf Formula 3
    Sep 14, 2008
    1,352
    Florida
    Gary
    I'm leaning toward drilling the rivets out, going to saddle shop to have them make the leather straps in satin black. Not sure how to secure the straps yet. My straps broke distal to the rivets & were not brittle. Straps appear to be reprocessed something, but not leather.
  5. woody byrd
    woody byrd Formula Junior
    687
    cary, nc
    woody byrd
    #5 woody byrd, Dec 18, 2017
    The straps that hold the owners manual in the trunk of my 599 had just worn out after many years. I checked on replacing them at Ricambi. I think they were around $175 and had black only. I called around and found a Shoe Shop that made them for me. They took the buckles off the old straps, and replaced the exact looking in leather for $35.
    whatheheck and docf like this.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,629
    CT
    John Kreskovsky
    Just look for a leather shop and tell/show then what you want. I had the leather strap that hold the 355 tool kit down duplicated that way for $20.
    syata, whatheheck and docf like this.
  7. docf
    docf Formula 3
    Sep 14, 2008
    1,352
    Florida
    Gary
    Well went to a saddlery today and they will made the straps for me out off "real Leather". Understand this stuff is called leather, but is made from animal waste by products into a slurry , then heated into layer then cut to size! Debating on using Alum. or plastic rivets at this point. Never expected this on the 458.
  8. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    22,965
    Honolulu
    Kevin
    I am kinda shocked that the 458 has these also. In my 360 I had a set made from a guy that advertises on ebay. He is in England but is a pro so the distance wasn't a problem. It sounds like you found a local solution which is good! I can try to dig up the contact info if you need it let me know. I found a pic of mine that he made. i was very pleased with the product and he shipped the correct size rivets also. They are metric. I think the closest Standard size is 1/8 IIRC... maybe 3/16?. I messed up a couple on install and had to use what was available to me locally. Aluminum is the way to go on these IMHO. If you are doing it yourself, and if the trim parts are like a 360 pay attention and carefully mark where the screws go that you remove. There are a couple different lengths and shoulders on them.
    In this picture you can see the backing details that are behind the carpet panels. These are what engage the rivet.
  9. docf
    docf Formula 3
    Sep 14, 2008
    1,352
    Florida
    Gary
    Thanks for the reply Kevin. Where did you get the backing plates as I did not note any on the 458 what so ever and it certainly is a good idea. I only need 4 and would be most grateful if you could direct me as to where to purchase them. I recently sold my 03 360 which I liked very much. I had the spare tire option which had what I thought nice leather appointments to secure the tire,books,tools in the trunk and literally one day when the temp got down they self destructed in front of my eyes. Luckily the 458 only has 2 straps (4) pieces total. Unbelievable Ferrari used this same material.
    I was thinking of possibly using black nylon rivets in place of the black Alum. ones as much easier to replace if needed, hold should be secure as they are only securing a small compressor & tire gel on 1 side and a small cheap tool kit on the other side. These items are on a small shelf to aid weight distribution.
    Should get my straps post Christmas. Various rivets Friday. Hopefully you can help me to locate the backing plates. Your straps look very nice.
    Gary
  10. Kevin Rev'n
    Nov 29, 2009
    22,965
    Honolulu
    Kevin
    The plates are part of the assembly in a 360 so I just re-used my old ones. If there are none in the 458 then perhaps the carpet panels are made differently.
  11. docf
    docf Formula 3
    Sep 14, 2008
    1,352
    Florida
    Gary
    Maybe Kevin they are there and just didn't check it out. It was a job drilling out those old rivets. They seemed a lot more like Stainless than alum.
    Anyway thanks for the update.
  12. timwu12
    timwu12 Formula Junior
    919
    TX
    Hey Kevin, if you're able to dig up the contact info on the guy who made these for you in England, I'd really appreciate it!
  13. Ghostdiver
    Ghostdiver Formula 3
    1,326
    Southeast Texas
    Wally Hollar
    A family member recently got into leather crafting and makes some pretty good stuff. I sent him a pic of the straps to see if he can duplicate them.
  14. Kevin Rev'n
    Nov 29, 2009
    22,965
    Honolulu
    Kevin
    Here is the guys eBay store.
    https://www.ebay.co.uk/sch/stevecobra21962/m.html?item=112052114062&nma=true&nav=SEARCH&orig_cvip=true&rt=nc&si=dv4AEcUVdjvUYWcDPvHeZTuA2C4%253D&_trksid=p2047675.l2562
    He is easy to communicate with. He might need you to provide some dimensions for your specific straps. I cant find the email dialog we did outside of ebay so i cant find his personal email but you can get it from him by asking.
    Cheers and Aloha, Kevin
  15. Kevin Rev'n
    Nov 29, 2009
    22,965
    Honolulu
    Kevin
  16. Ghostdiver
    1,326
    Southeast Texas
    Wally Hollar
    I sent pics to the guy who is interested in this and he said it's not a problem. My straps are not broken but I may take them off and send them to him to see what he can do. If anyone is interested in doing this now, PM me.
  17. docf
    docf Formula 3
    Sep 14, 2008
    1,352
    Florida
    Gary
    My project is going well. As soon as my straps for the 458 are finished post Holiday's)will post some pictures. As there only 2 straps (4 substraps) it will now be down hill. Decided not to have the mounting holes tapped by the Saddler in the straps. Have purchased a set of punches on Amazon for the 4-5-5mm holes necessary. Will used a protractor to measure the off set of the double screw set needed for ea attachment. Instead of using rivets will use black trim screws (8 #8 or #10's) . Screws are much better than rivets I think and attach securely in the back plates. Tried a few today, easy to work with, look very good. Worse part of the project was drilling out the rivets. I swear they must be stainless.
  18. andrewecd
    andrewecd Formula Junior
    Dec 17, 2006
    539
    Andrew
    I bought 2 leather belts, cut to size, trimmed ends and punched new holes to suit etc.
    docf likes this.
  19. docf
    docf Formula 3
    Sep 14, 2008
    1,352
    Florida
    Gary
    How much did the cost and how long to Make Andrew?
  20. f355spider
    f355spider F1 World Champ
    17,913
    Japs?
    "Jap is an English abbreviation of the word "Japanese". Today it is generally regarded as an ethnic slur among Japanese minority populations in other countries, although English-speaking countries differ in the degree to which they consider the term offensive. In the United States, Japanese Americans have come to find the term very controversial or extremely offensive, even when used as an abbreviation."
  21. Ghostdiver
    1,326
    Southeast Texas
    Wally Hollar
  22. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    870
    Georgia
    Mark Gronsbell
    Those look great. Contact information would be helpful. Thanks
  23. Kevin Rev'n
    Nov 29, 2009
    22,965
    Honolulu
    Kevin
    The finished edges on these look superior to the ones I posted before and have installed on my car. A little farther from the stock look but it is a better result!
  24. Ghostdiver
    1,326
    Southeast Texas
    Wally Hollar
    I'm working on that with him now. As soon as he gets his pricing worked out, he will move forward with the growing list of requests.
    I warned him that there would be a demand if he could replicate these....
  25. Ghostdiver
    1,326
    Southeast Texas
    Wally Hollar
    Qavion likes this.
