Rear Suspension Behavior | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Highmiler, Mar 26, 2016.
  1. Highmiler
    Highmiler Formula Junior
    Dec 8, 2010
    414
    Missouri
    Greg
    Spring has sprung here in Missouri so I took my 400i out for a warm up today.
    I noticed something I've noticed before when the car has been sitting in the garage for the winter. That is that the rear suspension ride is stiff as a skate board's. It feels as the rear shocks have frozen up.
    I won't know about this year for some weeks but in previous years the car's ride smooths out with use and a full tank of fuel.
    Has anyone else run into this or am I just forgetting the 400 ride characteristics ove the winter?
    Thanks,
    Greg
  2. 400iGuy
    400iGuy Formula 3
    1,055
    Central Florida
    Al
    I had this problem with my '84 400iA and it didn't resolve it's self with driving. I fixed it by replacing the accumulators. There are Mercedes accumulators that are much less expensive than the Ferrari units (if you can even find them). They required reworking of the mounting brackets and a fitting allow for the smaller Ferrari hydraulic fitting to connect. It's been a while since I did this. I'll look for specifics on the Mercedes part numbers, etc.
    Al
  3. 400iGuy
    400iGuy Formula 3
    1,055
    Central Florida
    Al
    #3 400iGuy, Mar 26, 2016
  4. Highmiler
    Dec 8, 2010
    414
    Missouri
    Greg
    #4 Highmiler, Mar 26, 2016
    I suspected something like this but did not notice an accumulator in the service manual. From the photo and having just read the manual I think I recognise the part.
    Is there some way to adjust this thing or is it "factory sealed"?
    Greg
  5. 400iGuy
    400iGuy Formula 3
    1,055
    Central Florida
    Al
    Factory sealed.
    Al
  6. Highmiler
    Dec 8, 2010
    414
    Missouri
    Greg
    I can get the body to move about one inch by pushing down on either rear fender corner. It is a two arm push only. I do not have to put all my 194 pounds into it.
    How much do your cars move?
    Greg
  7. Part Time
    Part Time Formula Junior
    494
    Port St. Lucie, Fl
    Gary Shore
    Greg...my original 85 with 12k miles rides stiff...orig suspension, old dry tires....i can barely get any corner to move when pushing down...(without bending metal)..once on the road, not bad, firm but not teeth jolting.
    And I remember vettes and mustangs I had that rode really hard.
    You could dip the rear end in a tub of WD40 ....!
    Gary
    ps: I lived in Florrisant before moving here....I remember cold winters.
  8. Highmiler
    Dec 8, 2010
    414
    Missouri
    Greg
    Thanks!
    As you can tell, I am trying to evade throwing parts at this issue.
    My TRX tires are only a couple years old. I hope the car rides stiffly because it was built to run 150 MPH all day long and so would need the taught ride.
    When I get back home in a couple of weeks I'll run the car harder and longer. My garage is maintained at 55 F and cold fluid could account for the stiffness. It takes those TRXs more miles to roll smoothly than I'd put on prior to my original post. So maybe the fluids act the same way. Once everything is fully warmed up I'll report back.
    Thanks again,
    Greg
  9. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,606
    Romulus, NY (Finger Lakes)
    Ken Battle
    Greg
    To test if hydraulics are okay it is quite easy to remove bolt from front end of the ride height adjustment piston. With engine running at idle stroke the piston in and out slowly. Car will go up and down slowly, slower up than down. This will tell you if all the hydraulics are okay. I made a slight ride height adjustment by loosening the lever clamped on the roll bar; be sure to match mark before you loosen it or you can get real lost where is was!
    Ken
    p.s. You may want to wear a gas mask doing the job if you don't have cats!
  10. Highmiler
    Dec 8, 2010
    414
    Missouri
    Greg
    Thanks Ken I'll do that in a couple of weeks.
    Greg
  11. Ak Jim
    Ak Jim F1 Veteran
    8,499
    North Pole AK
    Has anyone replaced the hydraulic rear leavening system with coilovers? I had my load levelers rebuilt a couple of years ago. The rebuild lasted about 18 months and then the back of the car was down in the weeds again. I just got the coilovers and will install them soon.
  12. godabitibi
    godabitibi F1 Veteran
    6,282
    Papineauville, Quebec
    Claude Laforest
    Could any air system be installed instead of hydraulic?
  13. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Hey Ken, that's what I did to get it up an additional 1/2" :D
    Oh, No :eek: Did Jeff Lablonde do the work or Koni racing?
  14. Ak Jim
    Ak Jim F1 Veteran
    8,499
    North Pole AK
    It was the first name you listed. I guess I screwed up pretty bad based on your post?
  15. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I'd send a shout-out to him to get his take on it.
  16. PeterMercedes
    PeterMercedes Rookie
    Feb 17, 2014
    25
    Peter
    Bruce,
    Does this mean that Koni Racing in USA is a source for getting the hydraulic levelling rear suspension units on the 400i rebuilt?
    Peter
  17. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I ran across this info. years ago Peter & filed it for 'when' I'll need to rebuild mine, contact them for info.:
    http://www.koniracing.com/services.cfm
    But I also remember a while back someone mentioned that Koni no longer rebuilds ours, so it wouldn't hurt to contact them via website to see if that's still the case.
    Tim Stanford has a huge reputation here in FL & he's used Jeff Lablonde for his rebuilds, it wouldn't hurt to speak to Tim to get more supportive info. from his perspective:
    Tim Stanford Foreign Cars Inc in Fort Lauderdale, FL | 287 SW 33rd St, Fort Lauderdale, FL
    And I'm curious if AK Jim's taken up discussion with Jeff on his latest developments...
  18. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,577
    #18 wrxmike, Apr 9, 2016
  19. 400iGuy
    400iGuy Formula 3
    1,055
    Central Florida
    Al
    #19 400iGuy, Apr 9, 2016
    Nice write up. Thanks for posting it. Too bad we don't know who wrote it so we can ask questions (and get a clear copy of the drawings!).
    Toward the end of this document he mentions needing to keep the self leveler hydraulic pump going, eliminating the possibility of doing all 4 rear shocks. I think a possible solution is to remove the oil pump drive (#5 in the diagram). This part goes into a slot on the front of the cam connecting the cam to the pump. After removing this and bolting the pump back on the front of the engine everything will look original but the pump will no longer be driven by the camshaft.
    Al
  20. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I thought the exact same think :D
    Sounds logical to me, that would be the move.
  21. Highmiler
    Dec 8, 2010
    414
    Missouri
    Greg
    Last week I had a chat with a friend who has a V-12 Mercedes rag top. He blames the rough ride after lettling his car sit on its Z rated tires for more than a day or two. They get a flat spot on the bottom and it takes a while for them to round back out.
    I had my 400i out yesterday when the temperature was 90+F and had no issues with roughness. Apparently ambient temperature does effect these TRX tires.
    Also, the ride was smooth but firm. The Ferrari does let you know about road surface conditions that our Suburban absorbs. Bottom line is I do not think I have a problem after all.
    Greg
  22. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,551
    SF Bay Area, CA
    Ruben
    Hi Greg,
    FWIW, my car (also an 86 412) behaves much like you described earlier: the body isn't really movable when pushing down on a corner of the car, but once moving the ride is quite pleasant. It's by no means a Cadillac floaty ride, but in my eyes is a very good compromise between a stiff controlled suspension with some compliance to suit the car's GT nature.
    I've never thought my suspension had a problem... and itsounds like yours is showing similar behavior.
    Best of luck and enjoy!
    Ruben
  23. John Wetzig
    John Wetzig Rookie
    Aug 2, 2012
    45
    Allentown PA USA
    John Wetzig
    I just completed an unpleasant rebuild of my rear shocks and replacement of the springs. Could someone with a Series 1 car on TRX wheels and tires measure the distance from the ground to the inside of the wheel cut-out and post it? I'm getting approx 24 1/2". Thanks.
  24. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    25 1/2". Yours must look low and im betting you're sad.
    Series 1 with stock untouched suspension.
  25. John Wetzig
    John Wetzig Rookie
    Aug 2, 2012
    45
    Allentown PA USA
    John Wetzig
    Sad for sure. We're exploring some remedies and will let everyone know how they turn out.
