Quick Jack Lift | Page 8 | FerrariChat
Quick Jack Lift
Discussion in '360/430' started by whatheheck, May 11, 2018.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I bought mine directly from manufacturer and it came with positioning handles and power unit carrier.
    I think you should contact Costco and the manufacturer as my understanding is its supposed to come with it per the owners manual.
    Dan
  2. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Ah, thanks. So you actually need two of these to lift the car, which is a little pricey once you also factor in the cost of the lift. Looks like this is a good solution for removing the wheels but it also looks like the jacks would obstruct the underside of the vehicle and get in the way of other maintenance work. Maybe you just use them when doing wheel/brake work.
    One thing I've seen that I'm considering is integrating a scissors jack into the floor so that the jack is flush with the floor surface when not in use. I like the QuickJack, but I have a track-prepped Miata that won't clear it without using ramps. The ramps work, but you need to store them in the garage (they take up a lot of space) and set them up each time you want to lift the car, which is somewhat of a hassle.
  3. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    Ya, a single bridgejack was almost as much as the quick jack. So, I went with the quick jack which is use on top of my 4 post lift, for doing wheels-off work, like brakes. Gives me a more comfortable working height than the QJ alone, but I also have more versatility for working on, say my Atv. And the Qj ramps tuck into the middle of my 4post lift for storage. Also likely better resale of a qj some day, than a bridgejack.
  4. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    How do you store the QJ jacks on your lift? I wasn't sure how to store them at first, but ultimately decided to store them upright leaning against the garage wall with straps looped around the tops to prevent them from tipping over (they also rest on a rubber mat so they won't slip out).
  5. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    The frames I purchased from the factory came with two positioning handles.
  6. I'm 360 Canuck
    Nov 21, 2015
    1,911
    Lars!
    I’ll see if I can get pics, but for now...
    I cut a couple pieces of 2x8 wood to go across the empty area between the 4 post. They can be slid around freely, or just lifted out. One is toward the front, the other toward the back. I store the qj ramps flat with one end on each 2x8 piece.
  7. 65ffrcobra
    65ffrcobra Rookie
    Jun 6, 2018
    10
    Gary Evans
    I am spoiled I know but having a 2 post and a 4 post lift I don’t understand why anyone would want this as opposed to a 4 post or 2 post. Unless you move residences all the time. My 2 post is my go to for sure but the 4 post is nice for stacking, portable with castors. 2k will get you a new 4 post I paid like $1200 for mine used in new condition
  8. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Sounds like a good solution. I'd love to see pics if it's not too inconvenient. Thanks.
  9. Dicecal
    Dicecal Formula 3
    1,854
    Phoenix, AZ
    Rob
    Because those of us that have purchased this unit, don’t have the ceiling height for anything else (MOTO)
    Mimmo Blue likes this.
  10. RWC58
    RWC58 Karting
    Oct 14, 2018
    154
    Columbus Ohio
    Robert W Crooks
    So as I've read the 8 pages I might have missed whether this works with a 458.
    Thoughts ?
  11. I'm 360 Canuck
    Nov 21, 2015
    1,911
    Lars!
    Let’s try
    note: this is just for storage of the ramps. when used, they are placed on the black 4post lift ramps and aligned with the correct jack points on the car.
    the foam pads have nothing to do with it, I just keep them under my tires during the winter to hopefully minimize flat spots
    MaranelloDave likes this.
  12. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    That's great, thanks for posting. That is a good use of the space between the ramp tracks.
    A couple of further questions: How did you mount the wood boards to the jack? Also, where did you get that utility tray at the left end in the picture, the one holding the rubber blocks?
  13. I'm 360 Canuck
    Nov 21, 2015
    1,911
    Lars!
    the inside of my lift ramps have a 2-3" lip all the way along, so the boards just sit on that. maybe your lift is different?
    this is mine: http://directlift.ca/pro-park-8.htm
    you can see the "lip" in the pic for the pro-jack 3500.
    the utlity tray (jack tray) came with the lift. its steel and is meant to hold some other kind of jack....so i don't really use mine.
  14. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Ah, yes, I do have that flange on both sides.
    Mine didn't come with the jack tray and I had to purchase the plastic drip trays separately. Wish I had the jack tray (for free) as it looks pretty handy for storage.
    Anyway, thanks for sharing all this info!
    I'm 360 Canuck likes this.
  15. KBR54
    KBR54 Karting
    Sep 23, 2017
    154
    Sylvan Lake Alberta Canada
    David Garratt
    Watch Dans video he uses a Quick-jack lift on his 458 and shows the steps to lift the car
  16. Dicecal
    Dicecal Formula 3
    1,854
    Phoenix, AZ
    Rob
    I’m pretty sure Quick jack says you must keep the individual jacks parallel to each other. The way Dan does it, is not parallel. I also believe Quickjack stated you can also position the jacks across the bottom of the car, as long as they remain parallel. That may be the better way to do it if they reach all the way across.
  17. hassan jarrar
    hassan jarrar Rookie
    Dec 11, 2018
    5
    TheMBOD
    I have never had the guts to lift my F12 using a floor or hydraulic jack. So thinking about getting a Quick jack but still nervous about damaging the chassis. Any chance of that heppenning? Thanks,
  18. Dicecal
    Dicecal Formula 3
    1,854
    Phoenix, AZ
    Rob
    As long as you place the lifting blocks in the jack points on the chassis, you should have no problems.
  19. staatsof
    95,828
    Fuggetaboutitland
    Bob
    I think it's good to remember that this is not really a single piece, mechanically unified listing system but really two independent lifts unified by a single hydraulic pump.
    So if one of them has air or hydraulic cylinders that operate a little differently the car will get lifted or lowered somewhat differently. Mine showed up with one bad cylinder that had been man handled and I had to replace both schrader valves on the air cylinders so QC is not the greatest. But it works fine now. The mechanical lock mechanism really needs to be watched closely to be sure it's actually engaged before letting the pressure off (which you should always do!) I wish they shipped these with the hose assemblies pre-assembled and everything fully bled. They could easily do that at the factory and it would make assembling this much easier. We had a devil of a time getting all the air out of ours and lifting these ramps vertically to get the air to come out is no fun. It's actually dangerous.
    So always be careful using these pair of lifts and you'll be OK. But all then all lifts require caution.
  20. Glassman
    Glassman F1 World Champ
    Crawling under the car with just the Quick Jack holding it up is insane.
  21. staatsof
    95,828
    Fuggetaboutitland
    Bob
    With the arms locked why?
  22. jcurry
    23,966
    In the past
    Jim
    Not having the jacks parallel can place asymmetric loads on each jack, e.g. a side load which will also create unsymmetric vertical loads on the jack. Not good.
    I have used the transverse placement before to lift a 911. Works fine.
  23. ragtop1
    ragtop1 F1 Veteran
    5,233
    Ontario
    Larry Warren
    The only problem is that you can't remove the wheels for tire changes, brake work.. etc
    whatheheck likes this.
  24. Dean Palmer
    Dean Palmer Formula Junior
    May 21, 2010
    407
    St. Petersburg, FL
    Dean Palmer
    Image Unavailable, Please Login The QuickJack system has worked well for me and has worked on the 430 as well as the Ford F-150 Crew Cab with no special requirements.
  25. staatsof
    95,828
    Fuggetaboutitland
    Bob
    I wonder if it weighs a lot less? The quickjack is made in China and it's $1K or less. This lift needs a big price cut.
