458 - Pothole wheel damage on lip | FerrariChat
458 Pothole wheel damage on lip
Discussion in '458 Italia/488/F8' started by FerrariCognoscenti, Jun 19, 2021.
  1. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    Driving today and hit a pothole, made a loud noise. The wheel is fine, not dented, tire is keeping air and is fine, but it gouged the lip of the wheel and looks to be only cosmetic. What are my options to repair it?
  2. RayJohns
    RayJohns F1 Veteran
    7,403
    West Coast
    Ray
    Get yourself a few nail files from Sally's beauty supply and go to work. Then some touch up paint.
    Duplicolor has a Toyota silver that matched the silver perfectly on my 355 wheels, so well it made curb rash pretty much vanish. If you need the code, I might be able to dig up the exact paint code #
    Ray
    Ivinsea likes this.
  3. Chizz
    Chizz Formula Junior
    995
    Atlanta
    You can also call your nearest high end car dealer like Porsche. They have a company that repairs these on their trade-ins. I’ve had this done in the past before trading in a car.
  4. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    That wheel needs to go to a repair shop. It is bent, 100% sure.
    Get a new tyre. You don't get that kind of wheel damage without a "snakebite".
    Viperjoe likes this.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,239
    Frederick, Maryland
    Brian Brown
    The damage to the rim lip is so minimal that I doubt that the wheel is bent. It just had a chip in the paint!
    You can jack up the corner of the car with the wheel damage and manually rotate the tire/wheel to see if there is any radial run-out in the rim lip.
    The tire doesn't even have a scuff mark on it, there is no way that it has any damage, let alone require replacement.
    Ivinsea likes this.
  6. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    These wheels are pretty soft. They get bent with no visible damage. Suit yourself.
  7. Mafiaboy1975
    Mafiaboy1975 Formula Junior
    Aug 10, 2019
    258
    South Africa
    Mick
    That’s an easy fix by a mag repair place they can strip the wheel and repaint it.
    Here is SA it’s about $200 to fix.
    I cannot see if your wheel is diamond cut.
    If it is that’s also a easy fix but know you will have to take some of the face of the wheel off with a cutter.
    Personally this happened to me and I just had all the wheels redone in a solid color.
    Once you cut the face the pattern does change and on for eg the 458 wheels you can get about 2 cuts out it before you notice a big difference in the design. The rounded painted grey inner will go from a nice round end to a point an inch our so down the wheel spoke so to speak so I prefer not to have wheels cut where this can happen.
    I agree if you it a pot hole it will get a buckle. Easy to check. Drive at high speed. Say 100mph +. If you feel a vibration you have a buckled wheel or out of round tire.
    As far as the tire is concerned. If there is no visible damage internally and externally you are probably ok.
    whatheheck likes this.
  8. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    A wheel that is out of round does not have to shake. It needs to be measured.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,239
    Frederick, Maryland
    Brian Brown
    If a wheel has even a moderate dent in the rim lip you will not feel a shake at speed, as the balance of the wheel has not changed. A severely bent rim will show up mostly at slow speeds and diminish with higher speeds.
  10. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    If you are like me that has no experience repairing wheel curb rash and then repaint perfectly to match wheel color I suggest you just take it to a reputable repair shop as Mick / Mafiaboy has suggested.
    Here's mine when I hit curb on my front wheel on my California T.
    Before and after photos.
    Wheel repaired like nothing happened, perfect color match by a professional wheel repair shop for $200.00. Cheap!
    All done perfectly while I sip coffee.
    Dan
    evo3 and Thecadster like this.
  11. Gh21631
    Gh21631 F1 Veteran
    8,339
    East
    Call Wheels On site, they are in Sterling. They do good work. They can also remove it and ensure it hasn't been bent if you take the car to them.
    Thecadster likes this.
  12. BJK
    BJK F1 Rookie
    Jul 18, 2014
    4,792
    CT
    The outside, or front of the wheel barrel is supported by the spokes. You need to look at the back of the wheel, which is NOT supported by the spokes, to see if it is 'flat spotted'.
    I hit a pothole, wheel looked fine from outside, no air lose. Pulled the wheel off and clearly saw a 6" flat spot of rim barrel. ;)
    xBox likes this.
