Original Wheels for '73 US Daytona | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by GSJFerrari, Dec 4, 2015.
  1. GSJFerrari
    GSJFerrari Formula Junior
    381
    Stuart, FL
    Greg Jones
    #1 GSJFerrari, Dec 4, 2015
    Hi,
    On a '73 US Daytona here, it has Cromodora mag wheels (attached photo). Could you please tell me if this is correct and/or mainly is it acceptable for judging, or if they're supposed to be Borrani wire wheels, etc?
    Thanks,
    Greg
  2. Daytonafan
    Daytonafan F1 Rookie
    Oct 18, 2003
    2,748
    Surrey, England
    Matthew
    Cromodora 7.5X15" are the standard wheels. Borranis were an option. I suspect there are rather more Daytonas on Borranis today than were first delivered with them.
  3. 375+
    375+ F1 World Champ
    13,606
    #3 375+, Dec 4, 2015
    Cars delivered to USA and Germany had hex nuts. Attached is a photo showing what I believe are the two correct styles; one with Cavallino for Cromodora and the other for Borrani.
  4. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    hex nut is NOT correct, don't remember anything other than 8 sided
    which is it going to be ??? 6 or 8 sided... in your text you say hex which is 6 sided yet the photo shows 8 sided nuts... :=)
    the correct nut is 8 sided... if going with correct text would be an "octo" nut or whatever is correct for 8 sided nut
  5. 375+
    375+ F1 World Champ
    13,606
    Octo-nut, I stand corrected.
  6. TTR
    TTR F1 Veteran
    5,842
    Riverside, CA
    Timo
    First, I think they are called OCTAGON (8-sided) nuts.
    Can't be 100% certain since I wasn't there when they all rolled out of factory gates, but IF I was judging and noticed Borrani-logo nuts on Cromodoras, I'd probably want to see additional documentation.
  7. 375+
    375+ F1 World Champ
    13,606
    How about OCTAGONAL and leave it at that?
  8. TTR
    TTR F1 Veteran
    5,842
    Riverside, CA
    Timo
    Works for me :)
  9. Dogdish
    Dogdish Formula Junior
    Dec 27, 2005
    367
    Denver
    #9 Dogdish, Dec 5, 2015
    Timo, works for me also
  10. TTR
    TTR F1 Veteran
    5,842
    Riverside, CA
    Timo
    :) , but are you sure your ratchet is big enough to break the nut loose, even if it's just 6-sided ?
  11. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    That looks hex to me.
    Some sort of deep comp knock ons for 9'' + wheels maybe.
  12. George Vosburgh
    George Vosburgh F1 Rookie
    It looks flat to me.....
  13. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,821
    Santa Fe, NM
    #13 Bryanp, Dec 5, 2015
  14. wizig
    wizig Karting
    Jul 8, 2006
    90
    Leawood KS
    This topic is discussed in an episode of Chasing Classic Cars titled "Green is the New Black" (Season 6, Episode 10). After a restoration, a Daytona had points deducted at Cavallino due to the wrong knock-offs. In that case they used eared knock offs (that appeared to be from a Boxer), but in a post-judging discussion, they discuss the proper ones.
  15. Longstone Tyres
    Longstone Tyres Formula 3
    Sponsor
    Feb 2, 2006
    2,019
    Dougal
    Here is the stuff that Borrani currently make for the Daytona Borranni wheels and spinners They currently only make spinners to go with the Borrani wheels. It is also quite complicated, so if you need to know more about the Borrani wheels and spinners i suggest you give us a call and speak to Simon, he is our in house Borrani nerd.
  16. BigTex
    79,368
    Houston, Texas
    Bubba
    To the OP's point, I think wires on a Daytona are going to exhibit stress failure, eventually.
    That's a lot of horsepower to put thru them.
    The US DOT at some point in the '70s took a dim view of the spinner ears, I think it was after the Ben Hur chariot race scene.
    At that point all of the manufacturers had to rethink the hardware, giving rise to the HUGE nuts.
    Either configuration you need a huge wrench and socket to work them as on the 512BB, and later the TRs....
    HTH.
    :D :D :D
  17. BigTex
    79,368
    Houston, Texas
    Bubba
    The 512BB and BBi, making no effort to please our DOT, ran the eared knock offs a bit longer....
