360 - Oil pressure sender cross-reference? | FerrariChat
360 Oil pressure sender cross-reference?
Discussion in '360/430' started by dang2407, Apr 15, 2019.
  1. dang2407
    dang2407 Karting
    Apr 29, 2017
    169
    SW France
    Anyone found a x-reference to a 'cheaper' car that uses our oil pressure sender / transmitter part# 135940? Mine has just failed and I have a gut feeling that most of the £100 that I will spend on it will be F-tax...
  2. RedNeck
    RedNeck F1 World Champ
    10,025
    The CSA
    Me
    VDO makes the sender, there is a lower cost option from them, but I believe you need an adapter. I have the part number, just not handy at the moment.
  3. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    I’ve just bought a new one but a bit too previous as I cleaned the contact on it and it’s fine now.
    This is my second or third in 7 years and they are junk items. I did find an alternative VDO part but as above you need a bush to fit the thread and my OCD wouldn’t allow it,
    If you search in google I think you’ll find my thread from 5-6 years ago as I did last week. I can’t post a link as I don’t think this forum allows linking to any competition
  4. mello
    mello F1 Veteran
    5,043
    CA Bay Area
    Steve
  5. dang2407
    dang2407 Karting
    Apr 29, 2017
    169
    SW France
    Great, thanks guys. One more question, is there only a single wire going to it? There are 2 terminals so I thought 1 wire may have fallen off...
  6. RedNeck
    10,025
    The CSA
    Me
    Yes, 1 wire. One contact is the signal, the other is ground, connected directly to the body of the sender, DO NOT GET THEM MIXED UP.. The sender is grounded by the motor,you can use a ohm meter to check continuity to see out which is which. Might also want to consider this, may take some of the heat off the sender and prolong the life;
    https://www.ricambiamerica.com/135940-b-oil-pressure-sender-cover.html
  7. dang2407
    dang2407 Karting
    Apr 29, 2017
    169
    SW France
    For info, MerlinMotorsport do the VDO sensor with M18x1.5 thread, which I believe is what is required on the 360? Part # 360081030070
