360 - Oil pressure gauge erratic while driving | FerrariChat
360 Oil pressure gauge erratic while driving
Discussion in '360/430' started by MR. JETSON, Oct 20, 2020.
  1. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    ScottS likes this.
  2. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,321
    Maryland
    Mark
    I'm not the sharpest knife in the drawer but it sure does look like something oughta be connected on that other pole.
    Are there any dingle-dangles a-danglin in the nearby area?
  3. Qavion
    Qavion F1 World Champ
    14,228
    Ian Riddell
    I'm surprised you were getting any reading without that second wire. What colour wire is currently on the sender?
  4. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,457
    Honolulu
    Kevin
    That is correct as is. There is nothing that goes on that blade connector. The senders do go bad. I had to replace mine a couple years ago as the reading was erratic too. IIRC ~10k miles.
  5. wbt
    wbt Karting
    Nov 28, 2014
    234
    New Zealand
    Wayne
    2 terminals on the sender, one for the gauge (a linear resistance proportional to pressure) and one for a warning light (on/off at a certain pressure). 360 dashboard is smart enough to determine when to light the warning lamp so the second terminal is unused.
    Common problem, replace the sender.
    SoftwareDrone and one4torque like this.
  6. Qavion
    14,228
    Ian Riddell
    I see that the case provides the earth for the sender. Make sure you are getting good contact both on the wire terminal and between the engine block and the case.
  7. Qavion
    14,228
    Ian Riddell
    #7 Qavion, Oct 21, 2020
    Interesting. According to the wiring diagrams, the 360 has a (single) grey/yellow wire attached to the sender (and must be attached to the sender's "G" terminal). On the 348, 355, 456, 550, Testarossa, 512TR, etc, the grey/yellow wire is connected to the "WK" terminal on the sender and goes to the warning light. The second wire on these cars is attached to the "G" terminal on the sender and goes to the gauge (only).
    albkid and armedferret like this.
  8. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    You guys are awesome!!!! But Ok, I’ll purchase the one on performance parts.... thank yo so much guys!!!
    armedferret and Qavion like this.
  9. Qavion
    14,228
    Ian Riddell
    If it's anything like the other cars, you will need a very big spanner (24mm ?) with a 10 foot extension and a blowtorch to get it free :D
    MR. JETSON likes this.
  10. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    What would be the procedure for this? Can I remove the left rear tire? Or will I have to disassemble some parts of the rear engine?
  11. armedferret
    Mar 24, 2018
    1,321
    Maryland
    Mark
    Sounds like my kinda party :D
    one4torque and Qavion like this.
  12. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Can we MEL it?
    Qavion likes this.
  13. Qavion
    14,228
    Ian Riddell
    I'll check my F360 DDG :cool:
    ... 3 days with no CAT III ops
  14. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Jajaj!
  15. RedNeck
    RedNeck F1 World Champ
    12,190
    The CSA
    Me
    Not sure why you would need to remove a tire....The normal procedure is to remove the oil filter and get at it with a 24mm wrench, but I found a 24mm thin bike wrench will get in there and loosen it without removing the filter, then you can back it out by hand. If it still acts up after the replacement then the stepper motor in the gauge cluster may be the culprit.
    Tool:
    https://www.thebikesmiths.com/products/park-tool-9164?variant=15851436572706&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=Cj0KCQjwuL_8BRCXARIsAGiC51AHdTpOUPFVde0GxDd0PJfYQsnH10k-DigReRIRx5ns5r8Rb0Z-TJAaAt7IEALw_wcB
    albkid likes this.
  16. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  17. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Do you have a pic of it???
  18. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Oh got it!!! That fits in there?? Seems like the area in the engine would not allow the tool to fit there
  19. RedNeck
    12,190
    The CSA
    Me
    Of the wrench? It's in the link.
  20. RedNeck
    12,190
    The CSA
    Me
    Also, get the silicone sender condom from ricambiamerica.com ....helps keep the heat off of it, which is why it tends to fail in the first place.
  21. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    armedferret and RedNeck like this.
  22. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  23. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  24. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  25. Qavion
    14,228
    Ian Riddell
    I've tried a number of penetrants to no effect, even soaking overnight. All they seem to do is make the sender more slippery (and makes your spanner slip off). The only way I could get mine off was with a heat gun and a good ring spanner stuck on the end of an open ended spanner for extra leverage (with a rag tied around the end to protect your hand). Are you familiar with the double spanner technique?
    When it finally lets go (with a loud crack), you will probably have a heart attack :D
