OEM exhaust valves | FerrariChat
OEM exhaust valves
Discussion in 'FF/Lusso' started by HBstig, Feb 18, 2020.
  1. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    How do we disconnect the valves on the OEM exhaust to make them be open at all times?
    Sent from my Pixel 4 XL using FerrariChat.com mobile app
    LMH likes this.
  2. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Pull the vacuum hoses off the solenoids on the back boxes and plug them with a pair of screws or golf tees.
    But considering the fact that your car is a GT, why not install a Capristo valve controller? That way you retain the ability to run the valves in stock mode if needed be.
    otakki and LMH like this.
  3. BrntRubber
    BrntRubber Karting
    Feb 18, 2020
    111
    Farris Alnaqeeb
    Is there a significant difference in dB only using the valve controller or is an upgrade of the rear section also the way to go?
    Natkingcolebasket69 likes this.
  4. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Definitely no use of doing one without the other. Start with a controller and see how you like that. Then you can look into a box, x pipe etc. if you want more. If you get back boxes etc. a controller is nice. You may want to be able ti quiet it down occassionally.
  5. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    The controller is on its way, but I have no patience and I need them to be nice and open for this weekend's Enzo Ferrari's tribute event.
    Don't they have to be open when I remove the vacuum hoses? How do I get them to an open position? Thanks
  6. ridege55
    ridege55 Formula 3
    1,383
    Manhattan Beach, CA
    A bunch of us are driving to the Enzo event from the South Bay if you are interested. We are meeting up at 6:45am in Torrance. PM me if you are interested.
    I believe the valves fail open. Pulling the lines would leave the valves open.
  7. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    I am bringing a 4yr old and 1.5yr old. Believe me, you do not want to wait for me.
    ridege55, vraa and Il Co-Pilota like this.
  8. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    When there's no vacuum, the valves are open, the vacuum closes them. So no worries, just remove the hoses. Just make sure to plug them and the nipples on the solenoids to keep the system clean. The solenoids you can just seal with a bit of duct tape.
    otakki likes this.
  9. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Without the rear boxes the gain is marginal. Valves open
    At 3/4k rpm. The main issue with the ff sound to me is that inside is too insulated to it sounds better outside than inside.
  10. BrntRubber
    BrntRubber Karting
    Feb 18, 2020
    111
    Farris Alnaqeeb
    I found this video interesting and wanted to share. he has heard and used the full Novitec system in another video but as a daily he chose to only use the controller to keep the valves always open.
  11. otakki
    otakki Formula 3
    1,634
    Will keeping the valves open affect the engine performance? I thought back pressure has something to do power output for a naturally aspirated engine.
  12. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    You will lose some low end torque and response. There's no free lunch.
    otakki likes this.
  13. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,576
    Grant
    I have never noticed anything other than it sounds better. You can hear the difference here:- from 5mins in.
  14. ait_z28
    ait_z28 Rookie
    Jul 17, 2017
    23
    Will that trigger any codes on the system? or will the car be completely unaware of that.
  15. Altoria F
    Altoria F Formula Junior
    Jan 24, 2020
    437
    France
    P
    #15 Altoria F, Aug 29, 2021
    I wired off the exhaust valves of the F12 yesterday, zip tied + plugged the hoses and put caps on the actuators ports.
    It took me 1 hour with a simple hydraulic jack (bolted off the rear wheels).
    The sound is not so loud, less than I thought but present since idle as awaited.
    I didn't noticed any low end loss although I agree it should.
    I highly recommand this mod, very very pleasant.
