Nitrogen Use and Tire Aging | FerrariChat
Discussion in 'Technical Q&A' started by 2dinos, Jan 2, 2020.
  1. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,002
    I'd imagine this was discussed at some time
    If you get rid of the ~21% O2 - - - The logical advantages:
    Displace moisture which will reduce tire warming pressure rise
    Displace moisture which will reduce corrosion risks / issues in rim
    Reduce O2 which will reduce corrosion risks / issues in rim
    The ~21% O2 in our atmosphere will support slow & fast oxidation ie rust & burning. Soo, will it give any benefit to tires aging out? If tires start do degrade in X years, will using N2 give X+? years? Any data on this? Or anybody care to share any observations?
    Even adding one year would be great. Maybe if done when tires are as new as possible? I've come across lots of negative stuff. Waste of $ etc etc. But the F cars are pretty precious, and doesn't sound horribly expensive relatively speaking. Typically we go for the best oils, waxes and don't give it a second thought.
    Thanks and Happy New Year !!
  2. Llenroc
    Llenroc F1 Veteran
    5,479
    Colorado
    Vern
    What about the O2 on the outside of the tire? They tend to break down on the outside not the inside from what I have seen.
  3. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    Sunlight is hard on rubber!
  4. energy88
    energy88 Three Time F1 World Champ
    32,076
    West of Fredericksburg, VA
    Most people wear out the tires before dry rot becomes a dangerous problem. Assuming that dry rot manifests itself at about 10 years and if there is plenty of tread left on the tire at that mark, then the miles driven per year is likely low (2,000 to 4,000 miles per year). An incremental 2,000 to 4,000 miles at the end of the tire life is probably not worth it to most people. An extra year before mandatory tire replacement becomes necessary probably depends on the extra cost of the N2 over 10 years versus ordinary air.
    What is the charge for N2 and how readily available is it?
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    There's no reason to pay any upcharge for filling tires on a street-driven car.
    BOKE likes this.
  6. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
  7. NoSpeedLimit
    NoSpeedLimit Karting
    Sep 6, 2013
    185
    I would use helium or hydrogen, since these gases would also reduce the unsprung mass.
  8. energy88
    32,076
    Hydrogen, no. As one of the simplest elements, it requires very robust containers and lines to prevent it seeping thru the container walls. This is a major fuel tank problem on hydrogen powered vehicles.
  9. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,728
    Just East of Weird
    Bob
    Not to mention the isty bitsy problem that hydrogen is highly flammable...
    Sent from my iPad using Tapatalk Pro
    carguyjohn350 likes this.
  10. crinoid
    crinoid F1 Veteran
    9,948
    LaCrinoid
    When McLaren stole the plans from The Scuderia Ferrari, Ferrari had been using nitrogen to air up the F1 tires and McLaren argued they didn't see much reason to do it.
  11. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Re use of hydrogen, see this pic.
    Molecular hydrogen is touchy stuff. From what I've read, hydrogen powered cars will need H2 to be sequestered, physically or chemically.
    T
  12. tazandjan
    39,141
    Both hydrogen and helium are tiny molecules, as someone mentioned, and tires filled with them would leak like a sieve.
    We used nitrogen for tires in the USAF, but those tires see huge changes in temperature and outside pressure on every flight and go from 0-140 knots near instantaneously and from no load to carrying huge weight loads. Not quite the same environment as a car.
    EastMemphis likes this.
  13. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    I have a nitrogen bottle in my shop for filling shocks and still don't bother putting it in my tires.
    Smiles and 2NA like this.
  14. tomc
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Small correction (apologies, one time chemistry major! [emoji2]), helium is an atom. Hydrogen is found in molecular form, H2.
    But, as Taz says, they're very small, I'd guess the smallest among elements in their standard states. Hydrogen diffuses through solids quite easily, assuming it doesn't react first...T
  15. tazandjan
    39,141
    Tom- Affirmative, and I have a chemistry degree. As you said, helium is pretty much inert, which is why it works well in balloons, dirigibles, etc. Just a bit hard to find.
  16. tomc
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Cool. Didn't know you were a fellow Chem major! [emoji2]
    There used to be a large helium "mine" up near Amarillo. Pass more than a few Helium Roads in towns of the Panhandle. Not sure how active those reserves are anymore...T
  17. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Nitrogen in a street car is snake oil. But believe whatever you like.
  18. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    When Ferrari race team member Nigel Stepney stole the plans from Ferrari and gave them to McLaren (McLaren didn't steal anything, although they were in possession of stolen data - a pretty important difference), the FIA itself revealed through extremely sloppy redaction of the hearing transcripts that Ferrari had been using CO2 in their F1 tires, not nitrogen.
    At that time, nitrogen was already pretty commonly used by race teams worldwide for it's dry nature when used, allowing more precise control of hot pressures. The absence of moisture is the only single benefit to nitrogen vs. regular compressed air which contains moisture.
  19. Ak Jim
    Ak Jim F1 Veteran
    9,572
    North Pole AK
    Isn't the earth almost out of helium?
  20. tomc
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    My understanding from people who are more involved in that area, yes, there is a shortage. Whether it's a domestic or world wide supply issue, I am not knowledgeable enough to say...T
  21. energy88
    32,076
    I believe it is pretty much self-sustaining from radioactive decay underground. If it were that scarce, I would expect that it would be too expensive to use in party balloons.
    It can also be extracted from other substances, but I would image that is super expensive depending on economies of scale.
    During my days in the oil & gas industry, I recall that the Federal Government would require helium associated with drilling and petroleum reserves be required to be reported annually which was a PIA.
  22. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    Gordon doesn't CO2 destroy most rubber? When we use seals in Oil and Gas we use different seals, viton, buna, Kalrez etc. depending on the CO2 content since it usually swells the seals
  23. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,939
    energy88 likes this.
  24. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    In the broadcast business where high power transmitters are routinely used, the transmission lines, typically 6" in diameter or bigger waveguide, nitrogen is used to pressure the lines because it is dry. The risk of flash over from the center conductor to the outside conductor is unacceptable using any gas other than nitrogen because of moisture. A flash over can cause a fire inside the transmission line and the effects are truly bad.
    tomc likes this.
  25. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I don't think anyone is suggesting that nitrogen has no useful purpose...
