NEW V8 MID ENGINED MODEL (BIG BROTHER) | FerrariChat
Discussion in '458 Italia/488/F8' started by ajr550, Feb 28, 2019.
  1. ajr550
    ajr550 Formula Junior
    Apr 6, 2014
    978
    UK and Caribbean
    Andrew Roberts
    Can we put all info/views/comments on this model(due later this year)on this thread ?
  2. TomLikesCars
    TomLikesCars Karting
    Feb 27, 2019
    63
    Ireland
    Thomas Harris
    I'm not totally clued up on this car but going by the rumours, this standard V8/V6? model will have more power than any of the standard V12 models? That's a first isn't it?
  3. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,847
    France
    This one is the V8 - new top of the range rear-mid engine car (the next generation car following the current V8 range, 458/488/F8, expected to be a V6).
    Although presented as a special series (and initially supposed to be limited), the F40 was actually unlimited (with more than 1,300 produced) and also exceeded the power of the contemporary flat-12.
    polishhammer83 and TomLikesCars like this.
  4. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,644
    I've understood that the F173 will not be limited, however the platform may spawn a limited Icona variant which some suspect will be the new F40.
    polishhammer83 likes this.
  5. TomLikesCars
    Feb 27, 2019
    63
    Ireland
    Thomas Harris
    Not sure what I was thinking, it obviously says V8 in the thread title.
    So yes the Big Brother will have higher performance numbers than anything else in the current range? And expected in May?
    Sidenote: some fantastic insider and general knowledge on this forum!
  6. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,847
    France
    That's what has been leaked here indeed... The price will also match the level of performance, apparently.
    LARRYH and TomLikesCars like this.
  7. F140C
    F140C Formula 3
    Nov 25, 2016
    1,575
    Piedmont
    Marco
    @ScrappyB Yes, It won't be limited. From the Q4 2018 Results Earnings Conference Call:
    Louis Camilleri: "Enrico mentioned a car in the range that was - had super car performance that will be unveiled this year. The sales, the actual sales hitting the market will be in early 2020, so they do not affect the '19 numbers but clearly will have a big impact on the 2020 numbers as we anticipate the margin on that model will be considerably superior to the one on the 812"
    Max Warburton: "Got it. And Louis just to confirm..."
    Louis Camilleri: "Does that answer your question?"
    Max Warburton: "It does. It could be great to have a follow-on on the product question. Is it a series production car, it will have a full normal production lifecycle?"
    Louis Camilleri: "Yes."
    daflk, markonex, F2003-GA and 3 others like this.
  8. 1881
    1881 Karting
    Dec 21, 2016
    242
    Based on the 488 replacement thread, the F173 is a completely new platform....is the 'v6 true 488 replacement in 2021' going to use the same platform as the F173 (ie they swap v8 for v6) or is it another new platform
    Also it was said that the F173 is going to be significantly more expensive (base price around price of a well specced 812) ....if that's the case, what is the pricing expectation for the 812 replacement....presumably that will move up significantly too?
  9. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,847
    France
    The new "modular" platform should be the same for all models as far as I understand, that's the reason for being modular.
    The new BB will be the real high performance top of the range, as it is acknowledged the V12 and front engine layout are not best adapted for this purpose.
    So this does not tell anything about the 812 replacement in terms of pricing; but the definition might be more "GT" oriented for the V12 in the future.
    There could be 812 successor at similar pricing, with new V12 "Icona" to fill the higher price brackets.
    of2worlds and Doug23 like this.
  10. davide b
    davide b Formula Junior
    Mar 6, 2007
    442
    montecarlo
    davide
    may or june, not sure yet
    of2worlds and TomLikesCars like this.
  11. 1881
    1881 Karting
    Dec 21, 2016
    242
    Cheers, the modular approach makes sense
    Though still unclear about v12 positioning, will be odd that a v12 will sit below a v8 in terms of performance and price...which is going to be the case with the BB vs the 812...for the 812 successor can't imagine that it would sit alongside...just doesn't work for the v12 imagine...for every brand and throughout ferrari history (as far as I know) v12 was always on the top
    If they go above the v8 then has to be 1000 hp and close to 1mm price tag....which then again puts the question where will the hyper car be
    I am sure they thought about it, just curious how
  12. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,847
    France
    The multiple cylinder engines are not as efficient with the current technology - straight line performance is possible following the path of Bugatti but for sportiness a 12 or 16 cylinder is not able to compete with a V8 anymore.
  13. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,396
    Bournemouth, UK
    LaFerrari and the upcoming Aston Martin Valkyrie beg to differ!!! There is nothing wrong with a N/A V12, they are not that much heavier than a TT V8, if any at all.
    Makuono, stavura, Solid State and 2 others like this.
  14. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,847
    France
    To get the same power from a N/A V12 than from a turbo V8 one needs a far larger engine; typically production turbo engines are very far from what is possible while V12 are close.
    To increase the power from the F12 to the 812, the only way was to increase capacity from 6.3L to 6.5L - while to increase power from the 488 to the F8 was just some tuning, presumably with a lot left.
    When F1 allowed both turbo and N/A, eventually turbocharged engines were the only way although they had only half capacity allowed (1.5L vs 3L).
    TomLikesCars likes this.
  15. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,396
    Bournemouth, UK
    That is far from true. Many things had to be changed (titanium conrods etc). This is besides the point though, which is the weight of each configuration. Not to mention their driving characteristics.
  16. markcs
    markcs Karting
    Oct 23, 2016
    141
    Valkyrie/Cosworth engine is super light
  17. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,457
    How about a V12TT? Go smaller block, get the performance gains
    They just need to figure out how to get the exhaust sound just right
    cridom60 and F2003-GA like this.
  18. markcs
    markcs Karting
    Oct 23, 2016
    141
    Been told pista engine plus 300hp electrics
  19. crinoid
    crinoid F1 Veteran
    9,943
    LaCrinoid
    Uhhhhhhhh who is Max Warburton?
  20. TheMayor
    105,861
    Vegas baby
    Seriously? Yikes!
  21. therryzsx
    therryzsx Formula 3
    Dec 2, 2011
    1,286
    you don't like the idea? why?
  22. TheMayor
    105,861
    Vegas baby
    No I'm impressed. I have no idea why you would need it but it's going to be a rocket.
    What I meant by "seriously" is like "that's crazy!"
    bwshihtzu, LARRYH and F2003-GA like this.
  23. F2003-GA
    F2003-GA F1 World Champ
    13,373
    Sunbelt
    Bro
    Don't forget a 3 Million price tag can make things very light Now 400k price tag is a different story
  24. markonex
    markonex Formula Junior
    Jul 31, 2015
    644
    Italy
    Marco
    I firmly believe Ferrari will not put the Pista engine in the BB without tuning it a little more. That V8 could well produce 800 PS. BB will have something around 740-780 PS from ICE and 150-200 PS from EM.
  25. markonex
    Jul 31, 2015
    644
    Italy
    Marco
    Jelial likes this.
