New Owner 1982 Giallo - Questions, pictures and my adventures | FerrariChat
Discussion in 'Mondial' started by swong46, Nov 21, 2017.
  1. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    Hi all, got my car not too long ago and super excited to learning how all this Ferrari stuff goes. Owned four Alfas of model years 1965-1974 and still have two of them; do mostly all my own work on them so looking to do the same here.
    I'd like to have this thread to post my adventures (ups and downs) on the car. In summary so far, this is what I know about the car:
    1 - Bought new in Vegas
    2 - Went to my local F mechanic's neighbor and best friend
    3 - Given to their mutual friend in exchange for building all cabinets for #2's new kitchen, dreamed of winning 2004 Monterey Concours but unexpectedly past (sad story)
    4 - #3's wife sold to car to contractor who did window repairs on their house, local mechanic no longer wanted to work on the car due to the spirit of his friend
    Here is where it all gets fuzzy.
    5 - Have Carfax first page of car done by Valencia Auto Wholesale in San Francisco
    6 - Someone consigned the car to be sold at the 2010 Portland Silver Auctions
    Now it makes sense again.
    7 - On display at Papa's Toys Car Collection in Oregon until 2016
    8 - I saw the car for sale in 2016, almost bought it, hesitated and regretted; it went to PA. Spent the next 18 months looking for a coupe I wanted and this same one popped back up.
    9 - Well, now I have it. Out of all the places in the world it could go, I took it from PA back to the same city where #2, #3, #4, and local mechanic (still operating) live.
    Trying to find out more from Silver Auctions still, but pretty neat story!
    paulchua and Roward7 like this.
  2. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    Posted this on the Pic of day thread, but will put here too. Removed the co-molded F430 key and epoxied in an old style key. Will make another one soon in yellow to match! If anyone wants one let me know. Making one for another member on here.
  3. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    Now for some questions.
    Realized the oil was not changed since probably 2008-2010, so I just did that last night. Fired it up this morning and used a mechanic's stethoscope for the first time. Found a vacuum leak on the lower hose of the tee shown below in green (not my photo) which is tied to the left hose and runs back into the body. Didn't get a chance to poke around too much but where does it go and what would happen if I drive the car like this until I fix it?
    Also heard a ticking and whirling, found that it comes from the alternator, seems fine for now. And lastly, a louder whirling from the two rear cam sprockets only. How scared should I be of this? This is all with the stethoscope and after I used some belt dressing on the accessory belts. I had a PPI done from Scuderia Performante in PA and they didn't report any strange sounds.
  4. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    That looks like the vacuum hose to the brake booster in front. Check this out before driving. Sometimes it is the hose that is leaking where it is connected to the one way valve. See if the leak dissapears by tightening the hose clamps. Next is to change the short tube that is closer to rhe engine and therefore subjected to more heat, age faster.
    /Peter
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,408
    Menlo Park, CA
    Paul Chua
    Don't know about cam sprockets, but alternator a common problem and thankfully easy fix. Get the alternator fixed, refurbished, or replaced...not too expensive. 2-300 bucks... Congratulations!!!
    AUDIO RESEARCH likes this.
  6. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    It's defn. the lower hose of the "T" I can see the hose is cracked at the barb. Doesn't seem like there is enough slack to cut and reconnect.
  7. AUDIO RESEARCH
    AUDIO RESEARCH Formula Junior
    Feb 11, 2009
    392
    PHILIPPINES
    LUIGI RAYMUND LIRA
    Hi ,
    Congratulations on your new acquisition. When was the timing belt , belt tensioner , drive belts replaced . Most probably the car did not get regular use . Since the car had its last oil change in 2010 , if it were my car changing the timing belt , bearing Tensioner & drive belts will be on top of my list . Then replace the coolant as well , check the brakes and flush the old brake fluid and check the condition/ age of the tires . Then the cosmetics will be the last thing I’d do .
    I like the color of your car as well .
    Best regard,
    Luigi
    paulchua likes this.
  8. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    Thanks Paul and Luigi. I've replaced the wheels/tires for now; $2000 for TRX nah...
    Scuderia Performante replaced the tensioners and belts this past April. I've already planned out myself to do all the other fluids and coolant lines very soon.
    AUDIO RESEARCH and paulchua like this.
  9. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    My alternator failed. It's fairly easy to remove and replace. In my QV, it was a BOSCH unit. Nothing exotic, and nothing that you can't find in other cars of the same era.
    I had a local generator/alternator repair shop rebuild it for $115. It took 3 days, and when I got it back, they had also cosmetically refurbished it -- it look brand new (probably better than new).
    Sid
  10. AUDIO RESEARCH
    Feb 11, 2009
    392
    PHILIPPINES
    LUIGI RAYMUND LIRA
    Im glad the belts/ tensioner were done already . Before I forget check the condition of the fuel hoses as well ( specially the big hose that connects the 2 fuel tanks ) .
  11. mustbenuts
    mustbenuts Karting
    May 14, 2017
    70
    Lancaster, PA USA
    GR
    Congratulations! I'm in the process of restoring an 82 that came from TX to PA. A lot of these pieces get around. Cool that your's ended up back "home".
  12. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    You could put a slightly longer vacuum hose on the engine side and get some slack to be able to cut the hose on the brake booster side.
    /Peter
  13. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Congrats Pero! You will find more vacuum leaks and old rubber after such time when it came new from the factory :) Have a lot of driving pleasure and be safe! Like Paul already mentioned check your fuel lines and definitely replace all the rubber between your tanks!
    Brooklands likes this.
  14. MalcQV
    MalcQV F1 Rookie
    Oct 11, 2004
    3,292
    Manchester, UK
    Malc Holden
    Congratulations. I really do like yellow mid-engine V8 Ferraris.
  15. kevinkw
    kevinkw Karting
    Apr 19, 2009
    115
    Seattle, WA
    Kevin
    Congrats on the Mondial buy. There are a couple of us newer coupe owners here, finding things, fixing things, trying to restore these very cool cars to their original glory. Also past owner of 3 Alfas, 2 GTV6s, and still own S4 Spider.
    On the key, what did the old original ones look like? I also got a plastic one for the ignition, the door one is original and pretty worn.
  16. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    Thanks all! Just went for a short drive, not too powerful but real smoooth.
    These are my original keys, probably the same as yours.
    WilyB, 2cam, paulchua and 2 others like this.
  17. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    That's a very nice picture BTW !
  18. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,639
    Argent/Brasil
    Guido
    Congratulations ....soon you will get the fever : mondialitis its called. :D Even in your dreams you will be working on the car.
    Is that an originale Giallo ? Very rare a yellow mondial. I like that color.
    Guido
    Mechanical Dad and paulchua like this.
  19. MauroV
    MauroV Karting
    Jun 24, 2013
    154
    Italy
    Mauro
    I might be wrong but from my research they never did Mondials in yellow. Mine was yellow when I bought it but eventually it needed work and I've returned it to the original blue azzurro. But looking at these pics, perhaps I should have left it yellow :)
  20. 2cam
    2cam Formula Junior
    Aug 28, 2014
    749
    Austin, Texas
    MikeS
    I hadn't seen one prior to this either. However, the auction for the car had a picture of the car's ID tag which was clearly stamped, "Giallo". Nice!
    Oh, and that is a great picture of the keys, gloves, and hood emblem! :)
    2cam
  21. MauroV
    MauroV Karting
    Jun 24, 2013
    154
    Italy
    Mauro
    Mine said yellow on the UK V5 registration document but when I checked back to the original import documents held by Maranello it said Azzurro. Plus behind the door cards it was definitely blue. :)
  22. Mechanical Dad
    Mechanical Dad Formula Junior
    Aug 30, 2016
    381
    East Aurora NY
    Josh
    Congrats on the purchase! Another 8 in the mix !
  23. swong46
    swong46 Karting
    Jun 24, 2015
    137
    Bay Area, CA
    DenisB and Jeka like this.
  24. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    Its great to see a new Ferrari owner learning about his car by doing the work himself! Congrats!
