New Aircraft: Celera 500 revealed for real | FerrariChat
Discussion in 'Aviation Chat' started by Jacob Potts, Aug 28, 2020.
  1. Jacob Potts
    Jacob Potts Formula Junior
    Dec 11, 2008
    352
    Pueblo, CO
    Jacob Potts
  2. jcurry
    23,964
    In the past
    Jim
    Definitely not a new or unique design, but always interesting.
  3. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    Do you know what an elephant is? It's a mouse designed by an FAA committee. This airplane looks like a hodgepodge of design elements by an FAA committee.
  4. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    I would hate to be flying that thing in heavy traffic. What would those square intakes act like at high AOA. Downward and outward vision ?? Did three guys design their own different pieces of the empennage?
  5. tazandjan
    39,128
    Bob- They definitely missed area ruling. High mounted, small intakes like those always suck at high AOA. Even though the vertical stabilizer looks plenty high enough, they still added a strake for stability at high AOA.
  6. Tcar
    Tcar F1 Rookie
    It's a turbocharged diesel V-12 engine, not a turbine.... does that matter for AOA????
  7. jcurry
    23,964
    In the past
    Jim
    Why would you area rule on a subsonic aircraft?
  8. jcurry
    23,964
    In the past
    Jim
    This is merely a take-off of a couple existing designs, dating back to the Germans (Dornier) in WWII. most recently look up VK30.
    technom3 likes this.
  9. tazandjan
    39,128
    Jim- Area ruling works on subsonic aircraft just like it does on supersonic aircraft. There is just less fuselage area in the airflow to create drag. On airliners and executive jets, the compromise in passenger space is the reason you do not see it, plus the added expense of the complicated shape.
    T- Diesels do not need air to run?
  10. jcurry
    23,964
    In the past
    Jim
    I think this airplane is designed to carry passengers too. ;) I can’t think of any GA airplane that is area ruled.
  11. tazandjan
    39,128
    Jim- Yup, that was the joke with that pudgy fuselage.
    Jacob Potts likes this.
  12. ChipG
    ChipG Formula 3
    May 26, 2011
    1,759
    Santa Monica, CA
    it's a little like a single-engine Piaggio with no windows
  13. jcurry
    23,964
    In the past
    Jim
    Or a Learfan that was over-pressurized
  14. Ak Jim
    Ak Jim F1 Veteran
    9,547
    North Pole AK
  15. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
  16. donv
    donv Two Time F1 World Champ
    26,042
    Portland, Oregon
    Don
    Look at the fuselage aft of the wing on a Falcon 900.
    dino69 likes this.
  17. tritone
    tritone F1 Veteran
    7,195
    On the Rock
    James
  18. Alpintourer
    Alpintourer F1 Rookie
    Jul 20, 2013
    3,823
    The Low Country
    Dave Steven
    Maybe Goodyear would buy a few for their corporate fleet. Looks like a Blimp with wings!
  19. Etcetera
    Etcetera Two Time F1 World Champ
    23,887
    C6H14O5
    This thing is the answer to a question no one was asking.
    donv likes this.
  20. afterburner
    afterburner F1 Rookie
    3,468
    Switzerland
    Urs STEMMLER
    ... This doesn't look very "laminar".... and always strange when each flying surface has a different plan form from all the others...
  21. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    Exactly. It looks like 4 different people were designing 4 different things with no effort to coordinate anything. The intakes look completely out of whack and out of place. The entire thing appears to be a day dream sketch by someone waiting in the doctor's office. In my old mind, I can see turbulent airflow at a high angle of attack breaking off the wing and flowing up and back over the fuselage into those intakes. The whole thing looks impractical to me but what the hell do I know..
    Jedi and Tcar like this.
  22. afterburner
    3,468
    Switzerland
    Urs STEMMLER
    ... more than most people alive when it comes to flying machines :D
    Jedi, islerodreaming, donv and 2 others like this.
  23. jcurry
    23,964
    In the past
    Jim
    With a piston engine the issue is cooling. There are ways around that. Even if it were a turbine there are other planes that show it can work, e.g. Cirrus SF-50.
  24. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    Huh ?
  25. jcurry
    23,964
    In the past
    Jim
    You seem to have an issue with the intakes. I was assuming your mention of turbulent flow was in regards to air flow into the intakes. This is a piston powered airplane, so the issue is how much flow (for cooling), not so much whether it is turbulent or not. They do have cowl flaps which I assume are meant to help increase air flow at low speed/high AOA. There are other methods that could be employed to increase flow at high AOA, e.g. supplemental intakes.
    If you think turbulent flow is an issue for turbine powered aircraft then I offered the SF-50 as an example of an airplane with aft, top mounted intake that is flying on a certified airplane.
