Need Advice R compound tires on 360 starfish rims | FerrariChat
Discussion in '360/430' started by SEAN@TEAM AI, Jan 4, 2017.
  1. SEAN@TEAM AI
    SEAN@TEAM AI Karting
    Sponsor
    Sep 22, 2006
    201
    Charlotte, NC
    Sean Smith
    Is there a good R compound setup for the 360 Starfish rims that avoid setting off ASR while running in sport mode?
    Already have extra set of rims on hand. Would like to track the car in sport for awhile to get acquainted with the car.
    Any advice from those with experience would be very much appreciated.
  2. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Just get Bridgestone RE-11 tires in OEM sizes. They are very grippy for street tires and predictable at the limit. They are close enough to R compound without the drawbacks.
  3. stevecomp
    stevecomp Formula Junior
    Mar 1, 2013
    743
    South Australia
    Steve
    Advan A050 best grip you can get after slicks 👍
  4. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    399
    RE11 is NOWHERE close to a R Comp tire.
    RE71R yes.
  5. DougDish
    DougDish Karting
    223
    Northern NJ
    Doug
    I run with RE-11 on my OEM Starfish 360 Wheels at the track.
    I also run RE-11 and RE-71R on my BMW at the track.
    Based on these experiences I have the following opinions.
    The RE-11 provides audible feedback as you approach its limit.
    It has been a good value and reliable option.
    Drive in sport mode and ASR only engages if I take too much curb.
    Has been a good option for learning but as others have said not close to an R Comp.
    The RE-71R is super sticky.
    Have been told by right seat instructors that it is the closest thing to an R Comp.
    I have been able to drive faster than others who have more car just because of my tires.
    The audible feedback is minimal.
    The tire wears quickly - really quickly, costing more $ per track day.
    Not available in OEM size for the 360.
  6. gbutler
    gbutler Formula Junior
    Jun 9, 2005
    542
    Charlotte, NC
    Glenn Butler
    I noticed the RE71R's are available in OEM size for the front, but come in 275/35/18 instead of the OEM 275/40/18 for the rear. Can anyone comment on the effect the lower profile tire would have on ASR, etc? Has anyone ran this combination on their 360?
  7. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    OK, so I overstated the RE-11s, but they are quite good.
    Is the RE-71R the Bridgestone analog of a Sport Cup 2? I see Bridgestone recommends against use in colder temps.
  8. DougDish
    DougDish Karting
    223
    Northern NJ
    Doug
    I have found that any summer tire does not react well below 40 degrees. Driving on dry pavement at this temp feels like ice.
    Would also like to hear if anyone has tried the RE-71R in 275/35/18 for the rear.
  9. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    402
    FL
    David
    I ran toyo RA-1's and they were pretty good with a stradale spec alignment. I also ran Hoosier's one time, but they needed much more camber than that. They were fast, but corded in one day. It's been a while, but I think it was the ratio of the front to rear diameter that was important in not throwing off abs or traction control. Toyo and Hoosier were the closest to factory at the time.
  10. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    Are the Michelin power super sports available on stock 360 starfish?
  11. DougDish
    DougDish Karting
    223
    Northern NJ
    Doug
    Let's make sure we are all on the same page.
    The OEM Starfish size for a 360 Modena is
    Front 215/45R18
    Rear 275/40R18
    Here in NJ I source my tires from Tire Rack.
    Their listed options for OEM size in Ultra High Performance Summer are:
    BFGoodrich --- G-Force Sport Comp-2
    Bridgestone --- Potenza RE760 Sport
    Bridgestone --- Potenza RE-11
    Kumho --- Ecsta PS31
    I've been through the RE-11 so which if any of the other three is better?
  12. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,587
    RE-11 is no longer available
    what now?
    they were awesome
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Yokohama Advan A052 in 235/40-18 and 295/35-18, maybe?
