Mufflers | FerrariChat
Mufflers
Discussion in '365 GT4 2+2/400/412' started by Highmiler, Jul 18, 2014.
  1. Highmiler
    Highmiler Formula Junior
    Dec 8, 2010
    414
    Missouri
    Greg
    Is there an aftermarket source in the US for the 4 Ansa mufflers on the 1984 400i?
    Greg
  2. dstacy
    dstacy F1 World Champ
    11,784
    GMT -5 & GMT +1
    Dave
    yes, they are called straight stainless pipes.
    Seriously most of us ditch those mufflers since they rust out like crazy. Run stainless straight back to a magnaflow, or similar, at the very back then weld on a set of tips.
  3. full_garage
    full_garage Formula 3
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
  4. maserich
    maserich Karting
    Mar 13, 2008
    169
    GT Car Parts in phoenix has the replacements for sale.
    I think they quoted me about $470. for each back muffler, with the chrome tips as original.
    I drove a nice 400i with the stock six mufflers and it was so quiet you couldn't tell it had a 12 cylinder in it.
    When I did mine, I ran straight pipes to the back mufflers and I am quite happy with it.
    It is a bit loud, but it should be.
  5. Part Time
    Part Time Formula Junior
    494
    Port St. Lucie, Fl
    Gary Shore
    Question for you guys that have deleted the mufflers ahead of the rear axle.....are you running 2 pipes per side to the rear ? Or a single pipe with a y pipe at the headers ?
    My '85 already has a y pipe joining both headers to a single pipe all the way to over the axle and a DynaFlow with single tip at the rear...also the side exits off of the headers are capped off.
    A future project is to change to twin outlets on each side....would there a gain of "sound" to switching to double pipes to the rear with a 2 in & 2 out muffler ?
    Just wondering out loud....exhaust is way down my list of projects....Thanks !
    Gary
  6. dstacy
    11,784
    GMT -5 & GMT +1
    Dave
    Hi Gary,
    My car has true dual exhaust, meaning it is 2 separate systems all the way back from the headers.
    I have seen the system like you describe but I think you'll find most of us are running 2 sets of pipes and mufflers behind the axels.
    Let me know how I can help.
  7. GT Jones
    GT Jones Formula Junior
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    Can anyone with a non-stock system post a video of their car at idle and while being revved?
  8. Part Time
    494
    Port St. Lucie, Fl
    Gary Shore
    #8 Part Time, Jul 20, 2014
    Dave....PO or possibly the EPA shop installed 1 cat conv per side with a Y pipe joining 2 headers on each side to one single straight pipe going to the rear and over the suspension. One of the first things I did was cut out the cats, (one was loose & rattling), but I still have the single pipe.....when I get to it, would it be better to run 2 pipes , one for each header, per side, back to the rear ?? Would there be a different sound running 2 or 4 pipes from front to back ?
    Gary
  9. dstacy
    11,784
    GMT -5 & GMT +1
    Dave
    Gary, you've got it. Run 1 pipe from each the cats back. So a total of 2 pipes, 1 per side, back to 2 "mufflers" or resonators behind the axles.
    Do a search on my posts. I listed the parts number of the stainless mufflers on my car. If you can't find it just let me know and I'll crawl under there and get you the part number.
  10. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,606
    Romulus, NY (Finger Lakes)
    Ken Battle
    Gary
    It looks like you have air pump and O2 sensor. Did you consider a cat without the air pump? I believe new cats do not need the air pumps.
    Ken
  11. Ak Jim
    Ak Jim F1 Veteran
    8,498
    North Pole AK
    I'm running 4 pipes from the front to rear.
  12. Part Time
    494
    Port St. Lucie, Fl
    Gary Shore
    #12 Part Time, Jul 22, 2014
    Ken...we have no inspection or sniffer tests here in sunny south Florida...so, no cats on the car, just 2 on the back porch chasing lizards ! The converters are already gone, the air pump wil be removed also.
    I am just thinking of doing 4 straight pipes to the rear or 2, if there would be a different sound...would it be worth doing.
    Thanks, Gary
    Thanks, Dave....I need to decide on the pipes first, if I stay with single, then I don't change anything.
    Jim...any difference in sound with4 pipes, or did you always have 4 to begin with ?
  13. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,686
    Seattle, WA
    Brian White
    What exactly do the o2 sensors do in a converted car? Did the euro car have o2 sensors?
  14. 400iGuy
    400iGuy Formula 3
    1,055
    Central Florida
    Al
    My '84 400iA has OEM Ansa mufflers I put on a number of years ago. I addressed the rusting muffler issue by using it regularly. They weighb75 lbs per side! A real pain to install by myself.
    The car had cats with 2 inlets and 2 outlets on each side plus the rearmost factory muffler. These them mated correctly to the factory rear pipes. It had O2 sensors connected to a Bosch electronic box under each rear seat cushion. It regulated the fuel flow in the K-Jet injection. All of this is long gone plus the air pump (a Ford part!). The engine/exhaust is now as it left the factory with the addition of an MSD ignition box replacing the noisy Marinelli box.
  15. rzinger
    rzinger Rookie
    Jun 17, 2014
    34
    Boston
    Dave
    Just procured a 412 automatic convertible - does anyone make a pre-formed pipe to run between the headers and the rear exhaust (to eliminate all the mufflers?). The engine is way too muffled! Right now I have four sets of midpipes per side running back from the headers (what I believe to be the stock setup - way too quiet, way too heavy,and way too prone to accumulating water). I may just have a local shop fab some but figured I would ask. Thanks in advance.
  16. Part Time
    494
    Port St. Lucie, Fl
    Gary Shore
    #16 Part Time, Jul 23, 2014
    Nothing pre-fab that I know off, but not difficult for your local muffler shop to do..look at my pics above in this thread, I already had the single pipe on each side, but I did have them cut out the cat converters and use the short stubby "y" to put 2 headers into 1 pipe all the way back. Behind the rear suspension the pipe kicks up and into a single muff per side with 1 outlet..it's a little loud, but ok for now.
    PS: you can see the shadow of the original mufflers above the pipe where they sprayed rust-proofing..the car came from Vermont.
    Gary
  17. new ulm 400i
    new ulm 400i Karting
    Sep 1, 2007
    116
    Taipei, Taiwan
    Lee Atkinson
    I went with a crossover system; from the headers, take the 2 pipes into a crossover 3.5x7" oval muffler (Magnaflow 11148) that exits with a single 3" pipe, then reverse that back with an identical muffler that goes back to the (2) pipes (1.75" each, I think) that will thread its way to the resonators...I get just enough boom to set off a few of the car alarms in the parking lot at 1500 rpm, any faster the whole thing evens out and is not at all quiet, but I can roll up the windows and not feel the car drone...
    The easy way ? Run 3" glasspacks under the car...I know this sounds like something you should do on a Chevy, but the original muffler design was practically this (there was a crossover after the first resonator, but for all practical purposes this is 4 separate exhaust lines that roar out the back and give the Ferrari that rock-and-roll sound...
    Getting mufflers to fit under the car is not easy, ground clearance is not generous on these cars....Lee
  18. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,686
    Seattle, WA
    Brian White
    Wow Part time...that exhaust is just SCREAMING to be redone. That engine deserves so much more.
  19. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    31,711
    MA
    Dick Fritz of Amerispec in Danbury, CT, installed new cats and removable "test pipes" <cough, cough!> for my 400i when I bought it. I installed the cats when I needed to go for emissions testing (before the car was 25 years old) and then could swap them out and replace them with the test pipes in about 45 minutes without using a lift.
    There was a noticeable improvement in the sound with the test pipes connected to one muffler on each side and the resonators by the tail pipes. Louder, but not objectionably so. I don't know how loud it would have been with only the resonators and no mufflers, but I would guess it would be uncomfortable for any kind of long drive of more than about 15 minutes.
    Fabricating the test pipes is not a difficult job and should be able to be done by any competent muffler shop
  20. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,686
    Seattle, WA
    Brian White
    #20 bjwhite, Jul 24, 2014
    Here is a picture of the exhaust on my 84 400i. Has twin inlet cats and o2 sensors with exhaust gas hoses going to the air pump up front. Then two outlets from the cats to a pair of "cherry bomb" type mufflers on each side. Then, continuing dual all the way out the rear (without rear mufflers) to the chrome tips.
    Honestly, I really like the way it looks without big backboxes (rear mufflers) hanging under the rear of the car.
    Yes, in the picture you can see a missing exhaust mount and hanger. From my records this exhaust was fabricated in the early 90s by a shop in California.
  21. Highmiler
    Dec 8, 2010
    414
    Missouri
    Greg
    Thank you for posting the photos showing the fit of these glass packs. I have about come to the same conclusion and can now see how they really do fit as I thought they might.
    Before I make this installation I am going to make a run on Flowmaster. Their "Series 50" is 3" thick but does not come with two 2' tubes in and two 2" tubes out though there is a column in their catalog called DD for such an application. Hopefully they will be willing to make up a couple, or four, in the DD layout.
    My '84 has two Ansa mufflers on each side, the third having been lost to space for the cats. It seems to me that one 20 to 30 inch muffler would be a more sanitary set up than the two 15 inch Ansas.
    Would anyone be interested in such a product if I can get Flowmaster interested?
    Greg
  22. dstacy
    11,784
    GMT -5 & GMT +1
    Dave
    Boy isn't it interesting seeing all the slight variations?
  23. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I'm pretty sure we haven't seen the half of it out there :D
  24. Highmiler
    Dec 8, 2010
    414
    Missouri
    Greg
    Does anyone know what is inside the Ansa cans?
    Do they keep the paths through segregated right to left or are they ordinary baffled cans?
    Greg
  25. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    #25 blkprlz, Jul 27, 2014
