Mondial Window Motors.... | FerrariChat
Discussion in 'Mondial' started by Brian Marks, Mar 29, 2019.
  1. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    ’82 Mondial that suffered from PO neglect and the window motor (driver side) is completely dead. I’ve removed motor and freed it up, however even with a direct 12v to a battery there doesn’t appear any hope for this one.
    The question is are the 308 motors innerchangable with those I have just pulled out ?? I can’t tell from any of the books as the part numbers are certainly different any help or direction appreciated.
    SPAL (yellow plated) is currently abused patients and the other black Ferrari 308 is one listed on eBay
    ronfrohock likes this.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Send it to a motor repairer, they will probably be able to fix it.
  3. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    Problem solved - I found some NEW (higher torque) motors from G.T. Car Parts in Phoenix - thanks ! Plus some very knowledgeable info on taking out the winding unit and re-greasing which should make things far better going forward . https://gtcp.com
  4. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    279
    Winter Park, FL
    JK Stevens
    I love GT Car Parts! They just re-built my fuse/relay panel.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    While you have this in bits, have a look at fitting the window speed modification kit, look on Superperformance uk. Very cheap mod
  6. Brian Marks
    Brian Marks Rookie
    Feb 24, 2018
    17
    Cincinnati, OH
    BMTopSpeed
    Already a few steps ahead as I have secured a pair of those units from Ricambi America here in the US.
