mondial wheels | FerrariChat
mondial wheels
Discussion in 'Mondial' started by ddiggler, Dec 2, 2020.
  1. ddiggler
    ddiggler Karting
    Nov 24, 2017
    77
    doug nelson
    I have a 86 Mondial. Found a beautiful set of TSW wheels I like. Currently have a 17 inch wheel. Does anyone have an 18x8.5 with a 40 mm offset on their Mondial? If not does anyone know if that size wheel would fit. Thinking a 245/40/18 tire should be close to stock diameter. Any insight would be great. Thanks. Doug.
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,646
    Argent/Brasil
    Guido
    17" is the best on this car. With 18" you have to put thinner tires, witch you will feel in the ride.
  3. srephwed
    srephwed F1 Veteran
    7,070
    street,md
    fred brown
    I have 360 modulars on mine. starfish rims look pretty good also. Some folks buy 4 front rims and it is plug and play. I like the fat rears so I had 1/2 inch cut off the back flange. Not a big deal and looks pretty cool. I also installed adjustable coil overs from a 348 and lowered it a bit. Good luck Image Unavailable, Please Login
    paulchua and JLF like this.
  4. ddiggler
    ddiggler Karting
    Nov 24, 2017
    77
    doug nelson
    Damn. Those look great. What is the offset?
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    the whole wheel fitment game can take a lot of effort. I have two mondials both of which I have at one point stock 360 f/r rears on. I don't have the 360 wheel specs off hand but you can use those as a refence to compare to the wheel spec you have. IIRC the stock 360 rear is a 18x10? so you are fine on the width. There is a lot of room back there for width if the offest works. And don't get too caught up in the offset 25MM is 1" the difference between say 50mm and 25mm seems like a lot but in the real world it isnt. Most F cars need the wheels pushed further out IMO so playing with the offset is possible, there are always spacers you can use etc. What wheel did you find BTW?
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    +1!
    ronfrohock likes this.
  7. srephwed
    srephwed F1 Veteran
    7,070
    street,md
    fred brown
    Sorry I don't know the numbers. They are a set of stock 360 staggered wheels. Fronts are fine. I actually ran the rears a while and they would only scrub on a hard bump. Had 1/2 inch cut off of the back. Be very careful because if any more is cut the rim will hit the shock. Also had to use 360 lugs which are much longer. Then cut 1/2 inch off rear lugs and threaded them deeper. Yes it was a royal pain but I believe it was worth the effort.
  8. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    stock starfish wheels are
    F 18x8 32MM offset
    R 18x10.5 39 MM offset
    Ive got two sets unmodified on two mondials and no issues, so if the wheels you found are close to that spec they will fit.
    I personally think they rears fit perfectly, if I had the time I'd suck the fronts in a little bit (mill off the mounting hub) but they are close enough for now.
    You can also find some tire size calculators online to play with the profiles and widths if you like how the 17" fit on your car it will tell you the diameter and then you can play with the 18" wheel to find a tire size that replicates what you have.
  9. SaratogaCA
    SaratogaCA Formula Junior
    Sep 11, 2016
    319
    Saratoga, CA
    Sam T.
    I had starfish rims on mine. They looked fantastic, but when the tires needed replacing, I opted for the original look. I still have the starfish wheels, and can sell them to you if interested.
    HK Mondial likes this.
  10. Longstone Tyres
    Longstone Tyres Formula 3
    Sponsor
    Feb 2, 2006
    2,020
    Dougal
    Just saying you can still get proper Mondial tyres
    https://www.longstonetyres.co.uk/classic-car-tyres/ferrari/mondial.html
    I'm not saying don't do it of course, its up to you, but its worth being aware that if you fit 17" and 18" wheels the smaller side wall diminishes the amount of knocks and vibration from the road that your tyre is able to absorb, so you will not get as nice ride on an 18" wheel as you will with a 415mm TRX wheel. The TRX is pretty clever technology, and of course Micheln quality.
  11. theunissenguido
    Jan 21, 2004
    2,646
    Argent/Brasil
    Guido
    390 mm TRX wheels !
  12. Longstone Tyres
    Sponsor
    Feb 2, 2006
    2,020
    Dougal
    Yep they're cool
    Wingnut and moysiuan like this.
  13. bjwhite
    bjwhite F1 Rookie
    4,805
    Seattle, WA
    Brian White
    348 wheels are my favorite on the Mondial. I think they look better on the Mondial than they do the 348 to be honest!
    JayG, RicSinger and davem like this.
  14. RicSinger
    RicSinger Formula Junior
    359
    Rancho Santa Fe
    I totally agree @bjwhite unfortunately they don’t fit my 89 t (I’ve been told) if they did Ide love to get a set.
  15. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
  16. RicSinger
    359
    Rancho Santa Fe
    dkyranakis, paulchua and spicedriver like this.
  17. Mondi Cab
    Mondi Cab Karting
    Oct 9, 2019
    170
    EU
    J.Schulz
    ellum likes this.
  18. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
  19. RicSinger
    359
    Rancho Santa Fe
    Hi @JLF I will contact these guys and see if we can make it happen
    Thakn you
  20. ddiggler
    ddiggler Karting
    Nov 24, 2017
    77
    doug nelson
  21. bjwhite
    bjwhite F1 Rookie
    4,805
    Seattle, WA
    Brian White
  22. bjwhite
    bjwhite F1 Rookie
    4,805
    Seattle, WA
    Brian White
    I always liked this 328 wheel look as well.
    dkyranakis likes this.
  23. DavidB
    DavidB Rookie
    Mar 14, 2009
    14
    David Barnes
    I agree with the Tyre guy. TRX are a fabulous tyre and cannot be beaten for high speed touring.
    There is plenty of side wall. They are comfortable. They grip.
    The whole business about low profile has so much bull **** attached.
    Unless you are on the track you will not find a better tyre than TRX.
    Also as a general comment the best look your Ferrari will ever have is the one
    it came out of the factory with.
    DavidB 1988 Mondial 3.2 Sydney Australlia.
    Ademir 70 likes this.
