Mondial T Valeo advice | FerrariChat
Discussion in 'Mondial' started by MMT, Apr 14, 2016.
  1. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi All
    The T is in the workshop, I found a technician who has SDI program. So it goes, connect it up to the valeo ECU no communication, installed new valeo ecu we have communication and indicating the potentiometer faulty as well the clutch light is on the dash , replace potentiometer started on neutral and clutch light off (good). when gear selected there is no reaction no take off.
    The technician is concerned about adjusting the rod from the gear stick to clutch actuator, this what he had to say.
    When the clutch actuator is in safe mode, the clutch in engaged and there in no play. but when the actuator is out of safe mode , how much free play should there be on the arm.
    How many turns clock or anticlock required to adjust so not to damage the actuator.
    like to thank everyone in advance.
    Cheers
    Michael
  2. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Hope you get the right person to fix it now. If no one knows let him (or you) call the F Dealer. They should know this or at least find out from their Classic department.
  3. alexion
    alexion Formula 3
    1,379
    New York
    #3 alexion, Apr 18, 2016
    I don't think the actuator is adjustable, or at least should not be adjusted. Try the 30amp fuse in the trunk attached to the Valeo ECU.
  4. socalmondial
    socalmondial Rookie
    May 26, 2016
    2
    SoCal
    That is very good news. To have to convert to a manual trans would have been terrible.
    How were you able to find a new ECU? Continued good luck.
  5. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi all
    Tijn , I originally took the car to F/dealership on the basis they had SD1 ecu but NO, they hardly any information on it, it was there for over 4 month they did 0. promises and promises..
    Alexion, is you car valeo as well, are sure it not adjustable at the rod, when engaging gear there no up n go just revs. its driving me mad.
    Rookie, as for the ECU, I found it locally as new, I'm glad didn't go ahead with the manual conversion I had to listen to Hank...
    I have a spare hydraulic Actuator I may replace I don't want to but it looks like last attempt.
  6. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    Personally I would make a complaint at Ferrari headquarters. In the end if a F specialist needs help/information his only option is to turn to Ferrari.
    I raised a complained or 2 and they were very fast in straiten it out. We are potential buyers for a new F and Ferrari knows that the older segment cars is the first step to a longlive Ferrari ownership.
  7. jimzdancewicz
    jimzdancewicz Karting
    Mar 1, 2015
    152
    Berwyn, PA
    James Zdancewicz
    Michael. Are you talking about the actuator on top of the trans? Where did you get it? Mine is sticky and doesn't always find neutral when starting. (Need to turn key back and forth).
    Also, per most other feed back most of the issues are electrical and the components seem to be rock solid.
    Let us know how to you make out.
    Jim Z
  8. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Yes, The actuator on top of the gear box it selects all gears but no go just revs, Initially the clutch light was on, so we replace the valeo ecu and then the potentiometer so clutch light off, but still have the issue with gears no go, its drive me MAD, so the technician wants to replace the actuator as he cant find and other issue relay, power, all good.
    If anyone has any recommendation I'm all EARS..
  9. jimzdancewicz
    Mar 1, 2015
    152
    Berwyn, PA
    James Zdancewicz
    Michael - I spoke with my mechanic Tony who i think is advising your mechanic. He seems to think since you replaced the Valeo ECU that you need to go though the "Valeo Leaning" sequence again. There are directions in the manual for that procedure. Have you done that?
    Let me know.
    JZ
  10. open roads
    open roads F1 Rookie
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Hey guys. It's nice to see the forum working.
    These cars are so rare, that there was going to be a learning curve. With some F dealers not even on it. It's the enthusiasts that will work it out.
    Good luck to you. Hope you get her out on the open roads again soon.
  11. SonomaRik
    SonomaRik F1 Veteran
    I like the Valeo and was always wondering what the long term viability might be. As stated, I believe unless Ferrari Spa is involved, this may only be an enthusiast fix.
    Hopefully, it is more rock solid after the 'learning sequence' is attempted.
    r
  12. alexion
    alexion Formula 3
    1,379
    New York
    Michael do you have the Valeo manual? If not,send me your email.
  13. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi Alex, I have forward you a message.
  14. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi Jim
    Yes, big thanks to tony has been helping out, Sal (technician) has put it through the learning sequence, where he engages every gear and move it around but the seems it did not help.
    He swap the old actuator and installed new actuator, and still the same there no movement in the actuator or not making any sound.
    Thanks Again
  15. socalmondial
    socalmondial Rookie
    May 26, 2016
    2
    SoCal
    Is your tech sure that the ECU is OK? Was the ECU a new one or used one? That's usually the problem and not the actuator.
    Hopefully you find the problem without spending on unneeded parts. Good luck.
  16. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi Rookie
    Its a new Valeo ecu and new potentiometer, yes I agree id rather keep my new actuator for future if need be, he did swap the old actuator with the new but still same issue so he refitted the old on.
    Regards
    Michael
  17. alexion
    alexion Formula 3
    1,379
    New York
    Still no luck, Michael? I have a feeling this issue is something simple and electrical that is being overlooked. You have replaced all mechanical components that don't usually break and the ECU...I feel like its a sensor, relay, fuse, or lose wiring somewhere in the system.
  18. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi Alex,
    I think you're 100% correct , its most probably a simple problem, need to go over it again double check. see how we go, it seems so close but it's taking a while.
  19. davraz
    davraz Rookie
    Sep 26, 2016
    1
    Do you have the technical documentation of the Valeo system? My Ferrari Mondial T is down for 2 years and the ferrari dealership is unable to find fault
  20. alexion
    alexion Formula 3
    1,379
    New York
    I do. Tell us a little bit more about yourself, location, car, etc. Send me a pm with your email address.
    Alex
  21. MMT
    MMT Karting
    Apr 3, 2014
    80
    Australia
    Michael
    Hi Davraz
    I'm sure Alex will forward you any tech info, he's a great help, feel free to share the car issue happy if anyone can help.
    Michael
  22. dapower75
    dapower75 Rookie
    May 27, 2018
    6
    France
    Philippe
    Good evening !
    I live in south of France, and I just bought a Mondial T of 1994, with a Valeo System. I called Ferrari France, but they don't have any manual of this system.
    @alexion: is it possible to send me the technical documentation ? I don't find how to send you a private message. Many thanks !
    Dapower75
  23. alexion
    alexion Formula 3
    1,379
    New York
    Hi Dapower -
    What’s your email address?
    In order to connect to the Valeo system, you must have an SD1 computer.
  24. dapower75
    dapower75 Rookie
    May 27, 2018
    6
    France
    Philippe
    Hi Alex. Thanks for your quick return. You have my email on private message.
    Best regards.
    Philippe
  25. sixcarbs
    sixcarbs F1 World Champ
    10,438
    SF
    Congratulations!
    Please share pics, VIN, and other details. Is it a cabriolet or a coupe?
