Mondial t discs (rotors) - Alternatives and upgrades | FerrariChat
Discussion in 'Mondial' started by Capri335, Dec 4, 2018.
  1. Capri335
    Capri335 Rookie
    Jun 18, 2015
    26
    Grindelwald, Tasmania. (Australia)
    Hi guys
    after about 15 laps at our local raceway (Barbagallo) at Wanneroo in Perth, Western Australia, my front disc rotor cracked. It had one hairline crack in it before racing and I conferred with a friend about it before deciding to go ahead an put it on the track. Barbagallo Raceway has a high speed down hill to the final corner (90deg right). So 200kph (120 mph) to 60kph (35 mph) in just a few seconds, is hard on the brakes.
    Yeah I know that it could have been way worse, and maybe in hindsight I shouldn't have gone on the track, but oh well.
    The other side is now also showing hairline cracks where before none could be seen. I don't really know what these rotors are as they were on the car when bought (last month).
    So now I am searching for alternatives or upgrades at a reasonable price. I don't think that OEM spec are value at $600. Does anyone know what else fits? As it is a race car, I am not really bothered about originality.
  2. 2cam
    2cam Formula Junior
    Aug 28, 2014
    743
    Austin, Texas
    MikeS
    Yikes!
    paulchua likes this.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Have a look on superperformance uk site, £130 front and 150 rear each disc, also caliper repair kits plus range of pads and everything you need. U R 1 very lucky man it did not put you off the road.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Also look at Eurospares, they are £90 and £150 on offer
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Sorry to hear this!! Let us know what you ended up doing! Best wishes
  6. Capri335
    Capri335 Rookie
    Jun 18, 2015
    26
    I have a couple of Girodisc rotors on the way. They work with the std caliper, and should be a lot better. Also the rotor itself can be replaced later without buying the hub, which is alloy. US$900 / pair, but lighter in weight.
    I didn't go the Superformance route because they didn't know if the upgrade fitted the Mondial T (listed as Mondial 8 only) and recommended F355 Challenge kit, which I know won't fit. Actually going through this exercise taught me how little resellers actually know. The best resource I found was the EBC UK catalogue, and it is very comprehensive.Unfortunately it can't be downloaded, but is very useful. It shows most Ferraris (and nearly every other car), Disc info, caliper type, and pads in 3 grades. I took screen shots of the Mondial t for future reference.
    Karsya Eins, porphy, gsfent and 3 others like this.
  7. Capri335
    Capri335 Rookie
    Jun 18, 2015
    26
    So over the Christmas break I got the hubs re-greased (thanks to posts on here) it wasn't too hard. I then went about making a proper venting system for the discs. This was one of the hardest jobs that I have done on any car. Due to the shape of the hub and the fact that there are no disc covers it is hard to find something to mount it all to. I fashioned a piece of 2mm aluminium over the hub as a base and held it down with the ground bolt and 2 of the hub bolts. I then had to work on a way of getting the air in without fouling the wheel. I reckon I put the wheels on and off 20 times each! The first effort went in the bin it was so far out. Eventually I got there with a lot of persistence. I had to put in a plastic tube and deform it with a heat gun so that the wheel didn't rub. I reckon I spent a full week on this mod.... just hope that it is worth it! The hardest part was getting it to clear everything when on full lock (inwards) as it compresses the hose and puts pressure on the vent.
    I really thought the other side was gointg to be easier.... it wasn't. Same deal. This photo is before I added the plastic and the wheel was rubbing on the hose, although you wouldn't think so. The wheel weights were the real problem.... adding the tube and deforming it cured the problem.
    . Image Unavailable, Please Login
    This is what is behind the disc...
    Wade likes this.
  8. Capri335
    Capri335 Rookie
    Jun 18, 2015
    26
    I also had the discs and pads Cryogenically treated. It is supposed to add 2 - 3 times the life to the rotors. $170 treatment Vs $900 rotors, made sense to me.
  9. Capri335
    Capri335 Rookie
    Jun 18, 2015
    26
    The original rotors are Brembo. They are marked on the outer edge. I spoke to the Australian rep, and he said they weren't made for this... They definitely overheated, that blue colour is the give-away.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Hard to see the details but if you have bolted the alloy onto the brake carrier, be sure you put a thick steel washer either side of the alloy so it does not squeeze and come loose
  11. Capri335
    Capri335 Rookie
    Jun 18, 2015
    26
    I've used 2 bolts on the hub carrier and the earth bolt.
