Mondial Rear Windows stuck in Down | Page 6 | FerrariChat
Discussion in 'Mondial' started by soucorp, Oct 1, 2011.
  1. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    thanks Mike, i just don't understand it was working fine. i am wondering if its not something stupid. i looked at the fuse and there is power coming from centre wire of the plug. next i will take it apart.
  2. jgoodman
    jgoodman F1 Rookie
    3,266
    Central PA
    Jay Goodman
  3. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    going to try it this weekend. thanks
  4. Burch1
    Burch1 Formula 3
    May 26, 2012
    1,028
    Singapore/Carmel, IN
    Greg
  5. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    I wished mine was that easy, no movement or noise at all, it was totally dead. Tested the rear switch it was fine. Took out the window assembly with motor and connected it to the battery directly, still no movement. The weird thing is when I first got the car, everything worked beautifully for the first month.
    oh well... CHEERS
  6. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    same here Mike. It worked great. now no noise or movement. well I started taking it apart so will see.
  7. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    So I started taking the inside apart so I can try to fish the wire. After about an hour I finally had to take a break. I guess I will have to go by the wheel well, fortunately it's not the right side, then I would have to deal with the oil cooler. What a PITA, I have no more time today, I am leaving for a few days. Hopefully I will find the inspiration to do this.
    If Anyone has pics of the removal of the left side it will be appreciated.
  8. jgoodman
    jgoodman F1 Rookie
    3,266
    Central PA
    Jay Goodman
    I accessed it from the outside of the car, ie the behind the side air intake grill.
  9. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Hi Lino, the 1st page of this thread has a T left side with photos that may help.
    You sound like me now, sorry to hear that. I went thru your pain for a few days trying to figure out how I can take that damn rear window assembly out. I managed to take out the right side only, have not touched the left but yes, its a total PITA and a big waste of time.
    Now you see why I don't bother, just get my plexi-glass up when it rains and leave the top always down. I may get to it this winter if I'm bored with cabin fever.
    -Mike
  10. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    The T's vents are to small. I can't get through.
  11. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Ok, so after a few hours of messing with the bloody window I decided to bring it to my trusty shop. Stand by for the fix, I will find out this week.
  12. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    have you cleaned your switch thoroughly?
    I was having issues with my rear windows and gave it the contact switch cleaning 3x ..they work excellent now
    BTW recommend to silicon spray the seals of the top takes away a lot of resistance
  13. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi
    Yes tried that, I will wait to see what my mechanic says?
  14. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Well I got my car back..
    It turns out that nothing was found. My mechanic pulled the wire from underneath and plugged the motor direct to a battery and bingo motor works. I guess a bad contact.
  15. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #140 soucorp, Oct 21, 2013
    That's good Lino, so did you get a new switch, not sure what exactly your mechanic did to get it to work properly. I just bought a Volvo S40 rear window assembly that I will modify to see if I can get my windows going again after 2 years of trying... Hopefully, I will never have to worry about them failing ever again, lol.
    Best,
  16. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    I agree, Mike, that the Volvo S40 solution seems the best. I just dread the work; especially since I am in the middle of the second worse job on the Mondial, replacement of the heater ventilator motor. I am taking pics.
  17. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi Mike,
    Well it was a bad connection at the motor. Nothing more.
    Please post step by step pics of your project.
  18. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    Do ask, if you need help.
  19. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Thanks mikael82, I just received the Volvo unit 2 days ago, maybe will get to it this weekend.
    Lino, sure thing, there will be a nice photo write up when I get to it.
    Cheers
  20. robogeeks
    robogeeks Karting
    Sep 15, 2012
    112
    Hello everybody, our rear windows also go up and down very slowly and noisily, and a couple of times we have had to manually assist them. I was going to take out the mechanisms, clean them, and lubricate them, but after reading this thread I think if I am going to go to all the trouble of taking them out, I might as well replace them with the far superior Volvo units. Not only are they a better, more modern, more reliable design, they go up and down faster, and they go down a little farther than the stock units, so the window completely disappears into the frame when it's fully down.
    I just want to verify one last time the regulators I need. They are the rear window regulators from a first generation Volvo S40/V40 (1995-2004), is this correct?
  21. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Wow this regulator look like it was made to fit Mondials. I hope it fit well for you guys. And it's cheap. With MIke we'll sure have a good photo report. Can't wait to see it.
  22. mikael82
    Nov 18, 2007
    869
    Finland
    Mikael
    Hi,
    Yes, go ahead, change them... Taking regulators out is huge job. I had two Mondials and did lubricate and clean, every now and then. Now I only have one Mondial Cabrio, but new owner my 3.2 cab calls few times a year and allways I ask; "How is your rear windows?" fine he says. They are my first set and bit robust, later ones are sleaker in desing.
    Note that window can't drop inside sill, they get stuck, but stop bolt stops window rigth in the lip.
    You need Volvo S40/V40 first serries FRONT DOOR regulators, NOT rear door.
    btw.
    "how did I found them"
    I vent to neares supermarket parking lot and started mesuring windows, from door seal to top frame, so got full travel spot on. then I bought one and mesure it to fit. Don't get too light, it is a tight fit and be very carefull to see that all bolts toward mechanism because othevise mechanism gets stuck to cars frame, this is why you should test mechanism before you slam all back in. (with this volvo regulators, you can get window and mechanism out without going through enginebay, when they are instaled)
    I can take photos of hardware I used, so you all can get them work as smooth as posible, there are couple nice tricks.
  23. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    I got the volvo part still in the box in the garage. I'll probably won't have the time to work on it until December, sorry guys just extremely busy this month. But yes I will post the pics and how to when I get to it.
    Cheers,
  24. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    No worries Mike. Good luck!
  25. aspeystag
    aspeystag Rookie
    Oct 7, 2013
    1
    I have recently needed to repair a rear window motor on my 3.4t car , after spending more hours than should be needed to remove this thing and taking the thing to bits I found that the bearing on the drive side of the d.c motor had seized solid, after replacing this re lubricating the mechanism and putting it all back in the car everything is fine apart from the English winter weather
