Mondial Oil Pressure Gauge and Sender | FerrariChat
Discussion in 'Mondial' started by aabryan, Apr 15, 2020.
  1. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    I promised I searched around (and will definitely take direction) for this...
    My oil pressure gauge (1988 US mondial coupe) is not reading anything.
    2 questions (kinda 4)
    Is the red warning light on the oil pressure gauge for pressure or level?
    What is the part number on the sender? is there a cheaper cross part that works? is there a different sender for a US gauge (in PSI?) vs the AUS (in Bar)?
    Andy
  2. Ricambi America
    Sponsor Owner
    122592 if threaded with 18X1.5MM
    125340 if threaded with 16x1.5MM
    aabryan likes this.
  3. conan
    conan Formula Junior
    Nov 13, 2011
    389
    The red light is connected to a pressure switch, separate from the pressure sender.
  4. Steve Magnusson
    26,698
    Have you unplugged the single wire from the oil pressure sensor and touched it to (bare metal) ground with the key "on"?:
    If the trouble is the sender, the gauge needle should move to maximum.
    If the gauge needle doesn't move = bad sign for the gauge or its wiring.
  5. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    Thanks for the tip Steve! I'll give it a try! Coincidence, just found a reference to your post about installing a standalone gauge... looking for it now.
  6. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    Thanks... so no red light... I know I have some pressure, just not how much! I was told it was for pressure, but was worried it was just level.
  7. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    So gauge wen to max. It's the sender!
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
    Level comes off the connection on the dip stick, if i remember correctly it shows on central console ? Try unplugging and see what lights up.
  9. conan
    Nov 13, 2011
    389
    The red light in the oil pressure gauge comes on when the switch (below the plenum and on the base of the oil filter) short to ground. That is, when ignition is on and engine off, the red light is on. Mine was short to battery by electrical failure in the lamp socket. Maybe it never worked from the factory since I had to remake the lamp socket to not cause a short to battery. The switch was also broken ...
  10. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    Not sure I follow you 100%. It does come on with the ignition, but goes out after startup.
  11. aabryan
    aabryan Rookie
    Apr 23, 2012
    38
    I believe that is correct. I actually don’t have the center console panel... so I don’t have a level light. Just the light in the oil pressure gauge.
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
  13. conan
    Nov 13, 2011
    389
    Yes, that is correct. As soon as oil pressure builds up, the switch releases the ground connection and the light goes out.
    aabryan likes this.
