Mondial 3.2 Coolant Question | FerrariChat
Discussion in 'Mondial' started by Alden, May 12, 2019.
  1. Alden
    Alden F1 Rookie
    3,580
    Central Florida
    My great, Italian,talented, honest Ferrari mechanic nearby is retiring now. He is getting up in age. He did the last fluid change on my Mondial, I am going to do my own soon.
    I called him to ask what kind of coolant he put in my Mondial a few years ago and all he could tell me was:
    "It's the Shell long lasting brand for aluminum engines"
    Checked the service receipt, it just says "coolant."
    So....................What do think I have in there?
    Shell Rotella "red" type? I think this is the organic coolant like I use in my Jag with a supercharged aluminum engine.
    I can flush the system and put a different type in, but I really did not want to bleed the block and water pump. But I will, if I have to.
    Any advice appreciated.
    Alden
  2. EXCELSE
    EXCELSE Karting
    Nov 27, 2014
    105
    Belgium
    Scuderia Brughia
    Best is to stick with the green or blue stuff, because the modern long lasting coolants eat the solder away that holds your radiator together.
  3. Alden
    Alden F1 Rookie
    3,580
    Central Florida
    Ummmm......I was always told that the new coolants (orange or red) that are nitrite free, were better for our aluminum engines than the old green/blue, so I am looking at something like Shell Rotella red.
    I guess, since I can't be sure what is in there and you don't want to mix different types, I am going to have to thoroughly flush the entire system and add the new coolant.
    Alden
  4. EXCELSE
    EXCELSE Karting
    Nov 27, 2014
    105
    Belgium
    Scuderia Brughia
    New coolant is good for the engine but not for our type of radiators.
    Its also near impossible to flush our huge complex cooling system to prevent contamination between the 2 coolants.
  5. Alden
    Alden F1 Rookie
    3,580
    Central Florida
    Understood, but since I can't verify the type of coolant that is currently in the system, what shall I do?
    Alden
  6. EXCELSE
    EXCELSE Karting
    Nov 27, 2014
    105
    Belgium
    Scuderia Brughia
    what colour does it have now?
  7. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    Just drain out as much as you can, then fill the system with distilled water. Run that for a day, then drain it out. I've found the cheap Prestone from Walmart works fine, but you should replace it once a year. It's also much easier if you get the aftermarket drain and bleed plugs.
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,528
    San Carlos, CA
    Mitchell Le
    You can drain it enough so that little contamination would take place. It's not that complex of a system.
  9. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    279
    Winter Park, FL
    JK Stevens
    Use prestone green non diluted. I doubt you drive the Mondial that much and by having 100% in lieu of 50/50 will reduce corrosion and decay. One a year is optimistic but a bleed sillcock would be a good addition
  10. Alden
    Alden F1 Rookie
    3,580
    Central Florida
    Can't tell the color for now, I am going to drain, fill with distilled water, drain and fill with distilled again, then drain fill it with regular 100% Prestone green.
    KISS, right?
    Alden
  11. EXCELSE
    EXCELSE Karting
    Nov 27, 2014
    105
    Belgium
    Scuderia Brughia
    looks ,like a good plan!!!
